Guys
Odd divisor correct acts pretty much like a down clock ratio dependant on the CPU multi and the ram ratio you are running. You can with a 9 or other odd cpu multi think you are running 300fsb 1:1 when in fact your ram is running a lot lower.
Issue is no benching programs read your ram speed correctly when you have this option enabled as they don't take the registers it sets into account.You can only see a change in bandwidth measured.
I asked Ryder to comment on how to work the actual ram speed out as he has a nice clear way of explaining how this all works.
Over to you Rydeeee![]()
