A friend of mine from www.aquapc.com, bring from the CEBIT a sample for review of the Zalman VF900 Fatal1ty (with read leds) - of course the retail box will be diferent - big with Mr. Fatal1ty marketing and full of useless things
Here is 2 photos:
I presume that, except the leds, the perfomance is equal to the performance Zalman VF900-Cu, the max rotation speed is exactly the same (2400rpm).
Here is a photo monted in a SLI-DR with a X1900XT Crossfire Edition
1st - The assembling is quite simple if you RFM- diferent from previous Zalman video card coolers
No screw-driver is necessary and you will get a perfect contact with the core at the 1st atempt ..bravo Zalman nice work![]()
2nd - noise, an abysmal diference - at full speed (2400rpm) is very aceptable / at low speed (around 1200rpm) is vaguely audible - what a huge diference from the vacuum cleaner noise of the ATI stock cooler![]()
3rd - perfomance
Here is the temp with ATI Stock Cooler after testing artifacts for 2min
- 70ÂșC on core (penultimate sensor)
- 67ÂșC temp on PCB near voltage regulador (critical area)
- 56Âș C on memories (I think)
And now with Zalman VF900-CU on, also after 2 mins. of artficat scan - fans at around 75% (near 2000rpm)
- 48ÂșC on core (a 22ÂșC gain)
- 59C near the voltage regulador (a 9ÂșC gain)
- 38ÂșC in memory area (18ÂșC gain)
I was so amazed with the decrease in the temperatures that I repet the test again - but thats true ..core never passed 49ÂșC
Once again Zalman did a very nice job, maybe it is time to ATI start talking with Zalman experts before doing such a dreadful stock coolers
In conclusion : an absolutely essentital upgrade for all ATI X1900 and and X1800 owners.
Pros:
- Silence
- Big improvements in temperatures (not only in core, but also on PCB and voltage regulator)
- Nice-looking (altought I dont like leds)
- Small (with expert or crossfire DFI / Asus no problem with SLI or CF)
Cons:
- None (except that is not yet largely available in the stores)
Next: overclocking test and testing with 7800GTX 512MB![]()
This is Pedro Rocha, over and out[/SIZE]
