Official Team Group cronus I/A series bench report
Well, folks, let me introduce the one of best Team Xtreem line,
Model / Speed:PC4000 DDR500MHz
Capacity: Dual Channel Mode
CL rated: 3
Team Group part number: TXDR2048M500HC3DC-I,
Official description:
" The Team Xtreem Cronus series is a line of high-performance memory modules bringing you advanced speed grades, and low latencies(3-3-2-8), and
especially designed for performance enthusiasts who want to challenge to the limits of performance without worrying about data loss or corruption,
mysterious intermittent errors and display problems, or worse-the dreaded BSOD!
The modules are based on the Infaenoen/Aenoen memory IC, a new generation chip produced under o.11 micron processing. This memory IC
achieves very high frequencies (more than 500MHZ, against a standard of 400MHZ), at a low voltage(less than 2.75V under 500MHZ operation).
In order to achieve maximum performance, the SPD of Xtreem IA series is specially designed under 500MHZ CL=3-3-2-8 in dual channel mode. In BIOS
on motherboard, only FSB item needs to be changed from 200MHZ to 250MHZ.
The ‘Xtreem IA’ series ensures extreme performance without the fear of unexpected interruptions. And, remember, each Xtreem module (as with any
TeamGroup ram module) is lifetime- and satisfaction! - guaranteed.
*Warranty Void in cases of manmade failure or natural disasters."
So, that's see the module standard and Some overclocking stabilities bench:
The Ram set:
for the official timing is 3-3-2-8.., I did not do that though, but do this instead
(if you don't believe 2.25v can do that. I have another all set of re-test with volt-meter
with screen
on that. here:
http://www.xtremesystems.org/forums/...ad.php?t=92519)
Now I think you even don't wanna believe:
DDR510 CL2-3-2 with 32m pass and 3d05, 06 passed.
3d mark: 05, 06
Thank you for your reading.
OPB
- You may not post replies
- You may not edit your posts
Forum Rules
