03-11-2006, 11:38 AM
#1
Xtreme X.I.P.
New Memory Tweaker for Intel Chipsets
MemSet is a memory tweaker for:
-INTEL 815 845 855 865 875 915 925 945 946 955 965 975 P35 P45 X38 & X48.
-INTEL Core i7. (Timings and frequency Reading only)
-AMD K8 ddr & ddr2.
-AMD K10 ddr2 & ddr3.
-NVIDIA NForce2, NForce 650i & 680i.
-VIA KT266/333/400/600.
Here is the 4.1 version (for 2000 /XP /Vista /Seven 32&64 bits): MemSet.zip
For Processors with Integrated Memory Controller:
-AMD Phenom DDR2 & DDR3.
-INTEL Core i7 DDR3. Change timings on Core i7 CPU is possible with GygaByte, eVGA ,DFI and Biostar motherboards.
(Memory Configuration space are locked in the bios on others motherboards).
The 1.3 version: CPU-Tweaker 1.3
And here is a little soft which allow to access PCI registers on all boards,
Extended PCI registers on K10 and MCHBAR on Intel chipsets: BAR_Edit 3.1
You can read and write with it,and save the reading in a text.
(see datasheet before use)
You can find some timings explication here.
If you find a bug,Reporte me please.
Reason: Update
03-11-2006, 11:45 AM
#2
X.I.P.
Wellcome to XS Felix
Nice find
03-11-2006, 11:54 AM
#3
That's very nice. Will try it out on my P4GD1.
__________________
03-11-2006, 12:18 PM
#4
Xtreme Cruncher
very nice, maybe create a database of what all the options actually do and stuff as I don't understand half to the new ones on the i915...
I set them all to lowest possible values and my pc restarted itself lol...
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
03-11-2006, 12:40 PM
#5
Xtreme X.I.P.
Is it a particular value made that your pc restart itself?
03-11-2006, 12:47 PM
#6
i get a 404 not found when I click the link
__________________
|Asus| P4P800-E Deluxe | vDimm mod
|Intel| Pentium M Dothan 730 1600 MHz | 2760Mhz (230x12) | 1.55v | SWAC (Stock Wimpy Asus Cooler)
|Kingston| HyperX BH5 | 512MBx2 | 2-2-2-5 | 1:1 | 3.25v
|ATI| Radeon X850Pro | 585 Core | 621 Memory | Silencer 5
|Western Digital| 1x36GB Raptor | 1x120GB | 1x250GB
|NEC| ND3500-AG | DVD+-R: 16x | DVD+-RW: 4x
1M SuperPI: 26Sec
| 3D '01: 33,598| | 3D '03: 14,371 | | 3D '05: 6,561 | | 3D '06: 2,573|
03-11-2006, 12:59 PM
#7
Xtreme X.I.P.
I restore the link.
But,for example,if you get 5 at "Read Delay" on channel A and B,put 4 or 6 on channel A and B,
not the higher or the lowest value.
And don't change all values at same time (sorry for my english)
03-11-2006, 01:14 PM
#8
A Wierd question  :
Is this one the Intel wersion of the A64 tweaker?
If Yes, Then Great Job felix
#9
Xtreme Cruncher
it may not be a problem, maybe my ram just couldn't handle it
I'll try them all in more detail now
__________________
03-11-2006, 01:22 PM
#10
Xtreme X.I.P.
It's the same for "refresh cycle time":if you got 12 on channel A and B,don't put 30,it's not recommendable.
And Be careful to always put the same value on Channel A and B.
#11
Xtreme X.I.P.
looking good, it should help a lot with the new cpus from intel
__________________
03-11-2006, 01:25 PM
#12
Xtreme Cruncher
they all seem ok if I relax the timings so im guessing the ballistix couldnt handle all the tightest timings (even if only at 175fsb)
__________________
03-11-2006, 01:26 PM
#13
nice work buddy, works great on P5WD2-E Premium
03-11-2006, 01:31 PM
#14
XS_THE_MACHINE
sweet nice program dude!
03-11-2006, 01:35 PM
#15
Originally Posted by FELIX
Oh,there is a probleme with 915?
Sorry,I remove the soft and see what it is...
Abit AG8 (915) works ok
03-11-2006, 01:37 PM
#16
coucou FELIX
haven t received my 780 es
so i will test when i can
__________________
Signature removed.
Links in signatures to unapproved and/or unaffiliated sites is not allowed.
Re-read the Forums Policies & Guidelines.
Signature edited by IFMU
03-11-2006, 01:39 PM
#17
Xtreme X.I.P.
I edit my post,finally no problem
03-11-2006, 01:55 PM
#18
Any chance of a 64 bit version ?,or am i doing something wrong ?
03-11-2006, 02:12 PM
#19
which intel cpu is 64 bits ?
__________________
Signature removed.
03-11-2006, 02:15 PM
#20
Xtreme X.I.P.
Sorry,no possible to make a 64 bit version for the moment.
03-11-2006, 02:19 PM
#21
Works great! Thanks much!
__________________
2004 NBP Acura TL
- Fujita F5 CAI - Comptech Catback Exhaust - UR Crank Pulley - P2R Spacer - TEIN S-Tech Springs w/ Tokico Blues -
[XC] gomeler
Cars are meant to be driven and then painstakingly cleaned and maintained.
03-11-2006, 02:51 PM
#22
I got a 865 chipset but It says I have a 965P?
__________________
Asus P5B-deluxe | E4300@3200mhz | 2x1024MB 400Mhz 4-4-4-12| Asus X1950Pro |
03-11-2006, 03:08 PM
#23
Xtreme
Nice! I hope it does work on Aopen 975 for yonah
well, they have emt64. Actually, I have seen both definitions. One states it is not true 64 bits like amd64 but they can still support 64bit os. The other says that it is basically the same with the exception of a few instructions.
__________________
03-11-2006, 03:10 PM
#24
Xtreme Cruncher
you have 875p dont you???
have you installed chipset drivers and 875p and everything?
__________________
03-11-2006, 03:15 PM
#25
Xtreme X.I.P.
Sorry,I correct that.Download the version on the first post now
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
