Results 1 to 16 of 16
Thread: Bench DD.
    Jul 2003
    Finland
    Bench DD.
    Ok. I havent actually done any systems in a while so it was time to do something.
    The system is SC12CLX, LU-VE condenser+fan, Honeywel AEL1 CPEV, and a nice litle evap. R402a.
    The evap is rather small. The base is 44m and the height is about 25mm. Base and top is about 3mm and the layers are 2.5mm. I conected the layers with grinder.
    Lowest 0w temp with the valve fully closed was -63c and the best loaded with 180w load tester was -44c.
    And here are the pics:
ID:	44007   Click image for larger version.
ID:	44008   Click image for larger version.
Name:	vähän ylempää.jpg
    cool cool cool!
    Jul 2003
    Finland
    And some more.
ID:	44010   Click image for larger version.
ID:	44011   Click image for larger version.
ID:	44012   Click image for larger version.
Name:	höyrystimen juotto.jpg
ID:	44013   Click image for larger version.
Name:	höyrystimen juotto2.jpg
    cool cool cool!
    Jul 2003
    Finland
    And more..
Name:	höyrystin juotettuna.jpg
ID:	44017   Click image for larger version.
Name:	ekat mallaukset.jpg
ID:	44018   Click image for larger version.
Name:	lämmönvaihtimen juottaminen.jpg
ID:	44019   Click image for larger version.
Name:	venttiilin juotto.jpg
    cool cool cool!
    Jul 2003
    Finland
    And the last pictures
    cool cool cool!
    Apr 2005
    Denmark
    Wow, it's a nice unit you have got there!!
    What material is the suction line made of??
    And then please can you tell me what purpose the superdeheater got?? I haven't figured it out yet
    Are you selling the evaps, I might be interested..
    X2 3800+ Manchester E4 LDBHE 0601 UPMW "N" @ 2950 MHz @ 1,408 V @ 24/7
    Vapochill SE
    DFI NF4 ultra -d
    X2 3800 + @ 3617 MHz
    Jul 2003
    Finland
    That suctionline is made out of stainless steel. I used the de-superheat coil just to fight vibrations on this system. It isnt actually needed since the condencer is more than enough on its own.
    I might sell few of these evaps
    Quote Originally Posted by Leverpospade
    cool cool cool!
    -100C Club Member
    Feb 2004
    australia
    WITH A GRINDER
    do you rotate the copper rod when using the grinder??
    thats a nice idea on the suction line hey.
    Jul 2003
    Finland
    No the evaps were machined with some automatic and very expensive equipement All I did with the grinder was grinding the small pieces off every layer to make connect them. But it is possible to make evaps like this with a grinder. It takes some time and you might need to make an jig/wise for the grinder and then feed the copper manually.
    cool cool cool!
    -100c Club Member
    Mar 2005
    Poland
    Hi
    Can You post more pics of the ready unit (specially with CPEV linking) ?
    You aren't using fans on condenser ??
    Regards
    Peter
    Jul 2003
    Finland
    This is propably the only picture of the valve uninsullated. It has the inlet tube anready brazed and the line connecting it to the evap can be seen in the picture too. And yes there is a fan and it is working even tough you cant realy see it spinning in the pictures. The fan is integrated to the shroud
    cool cool cool!
    -100c Club Member
    Mar 2005
    Poland
    What is that silver substance on the suction line ?
    What tube You have used after condenser (to CPEV) and from CPEV to evap ??
    Jul 2003
    Finland
    That silvery stuff is just duct tape The tube from filter-to-valve and valve-to-evap is soft copper capillary 2.5mm ID and 4mm OD.
    cool cool cool!
    Nov 2005
    /Land/Spain
    I work very pleasant hatemi. Who could have a compressor of those.
    Is the flexion tube of 3/8, not?
    greetings luf1c3r
    Jul 2003
    Finland
    THanks. The flex tube is like 10mm ID even tough it is supposed to be 3/8.
    cool cool cool!
    Admin
    Mar 2003
    North Texas
    Have you finished this cooler yet? I am curious if you like the setup.
    I have lightened the picture below and notice the feed line is not connected to the cpev yet.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    Jul 2003
    Finland
    Yes we finished the cooler last saturday. The setup worked pretty well IMHO. 180w loadresistor @ -44c is not bad Without load the evap was -48c with the valve in that same setting, but it was already flooding back to the compressor. We'll see how my friends opty likes the cold
    Heres a picture of the unit halfway insulated and evaccing. The picture is not that good but you can propably see the valve where we left it.
    Oh and the base is just 37 x 37cm square
Name:	eristykset kesken.jpg
    cool cool cool!
