I am building another one...
My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LNē Pots, LD GFX-R1 Dice/LNē Pots,
LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
LD PC-V8 Watercooling Cases: LINK
LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
www.ldcooling.com
Find US on Facebook
It gets soooo addicting huh!? is this for you or a friend? Good luck man! What gas ya gonna use?
Heatware | Ebay:Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
IMHO Waste is a computer going to a landfill having done actual computations less than 90% of it's life. 90% of the computers powered on right now are idle or powered off; what a waste! [/B]
Is it a coincidence that your wifes pc is called Uranus?
I am using r402a.
tnx
www.ldcooling.com
Find US on Facebook
Nice & compact built ., The ?controller? in the picture is dixell ? Give it one-two shots bro [front and rear view ]
Pics...
tnx
www.ldcooling.com
Find US on Facebook
Vaccuming...
tnx
www.ldcooling.com
Find US on Facebook
Where did you find that controller/ theremometer and how much did it cost?
http://dixell.com/page.php?sid=c1176...ageid=PRODO003
its the xr10c
Fold for XS!
You know you want to
i like the condens all copper(tong's out like a dog...)
i see that u have a lot of space!!! maybe too much?
succes!
q
Almost finished...
tnx
www.ldcooling.com
Find US on Facebook
Using foscopper brazing rods without flux would make your joints look even nicer.
Loved your system,what captube size and lenght do you use?
PS:What torch do you use?
Regards
R404A DD -55C
R404a/co2 Cascade
I'm using 0,7mm captube 215cm long and R402a gas... I have oxygen and acetlyene and brazing rods with white flux...
tnx
www.ldcooling.com
Find US on Facebook
can u post a pic of your torch setup?This is because i would like to buy one oxi-acet kit.
Thank ya
R404A DD -55C
R404a/co2 Cascade
that is a very nice job
awesome !!! LittleDevil@ are u make this cases by your own ?
Very usefull the incase dixell temp-controller also.
My friend makes me cases... In the future i will use rosfrei for cases
tnx
www.ldcooling.com
Find US on Facebook
Very nice job one day i hope to build my own to. I have a mach-1 that i am going to fix and hope it work out but anyway very nice job.
What is normal low side and high side pressure under full load, gas is R402a.
tnx
www.ldcooling.com
Find US on Facebook
normally ya want almost same pressures as refrigeration charts.Originally Posted by LittleDevil
i havnt used r402a but with correct capillary line and gas charge would expect few c's off with spec sheet, other wise undercharged.
In saying that if you can keep that compressor at around 0psig it should be at its best.
Specially casue they are LBP compressors and ment to run around that.
Idle temps...
Load temps...
Pressure load...
tnx
www.ldcooling.com
Find US on Facebook
is it good pressure or not... is it captube too short 0,7mm 215cm..
tnx
www.ldcooling.com
Find US on Facebook
Wow that's a super clean build you have going there... Keep up the great work, nice unit!
Im using shorter for r402Originally Posted by LittleDevil
In last unit used 1,8m of 0,7mm cap. Start off with 2,1m and keeped reducing till i was happy with results... This way it holds load much better !
what sort of suction line temps do you have say 8" before compressor Littledevil and Blaster at idle and load.
Some ppl like short, some longer works better??
i know that r290 is different refrigerant
shortest i eva tried is 2.4m and also tried up to 3.6m
2.4-3m all seems good, hard to say which is best though.
capillary line are weird hey.
humm maybe ur using 0,8 mm cap tubeOriginally Posted by kayl
long cap I get bigger delta from idle and load temps, and with my Opt170 running both cores at 1,66 vcore it really needed that shorter cap tube
system was tunned for that cpu![]()
