This the best max screen I got from my venice.
http://valid.x86-secret.com/show_oc?id=63613
I'm sure it can go higher, but I need to tweak my rig.
I have the same result for 1.77v, 1.80v and 1.84v. The chip can run from -26°C to -21°C it would always max out at 3500MHz. Weird isn't it? Something holding me back!
Can some one advise a bios and what to disable in it?
I'm runing 310p with a single 256MB stick 2T and use a PCI display card.
I tried to disable everything wich isn't useful, exept SATA, is it known to have an influence?
Thanks for your help guys
UPDATE
Using PATA drive gived me a far better score, but switching bios wouldn't help at all![]()
http://valid.x86-secret.com/show_oc.php?id=66032
This time I saw an improvment going from 1.77v, 1.80v and then 1.84v but none at 1.9v I thought temperature might be holding me back. I think die was around -22C for 1.84v vcore.I uncap the chip and give a try.
First I had problems to get a good contact. But reinstalling the stuff at least 3 times I managed to get good bios temperatures. Then I started to boot window; computer shuts down chip was dead
It was a hell of a chip, one of those that can prime for hours at 3GHz with a good watercooling system.
I will never no if it would have done 100% oc And won't be able to bench with it![]()
