Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Thread: Opteron 146 @ 3520MHz (Air)
    Registered User robocopy's Avatar
    Sep 2004
    Sweden
    Opteron 146 @ 3550MHz (Air)
    Hi there,
    Played with my Opteron 146 this morning.
    Outsidetemp: -11C
    CPU: around +5C
    Rig:
    Opteron 146 (CABYE 0540FPAW) 1.728V
    Tagan 530W EasyConnect
    DFI Lanparty SLI-DR Expert
    1GB G.Skill LE
    Zalman CNPS7000B-Cu + tablefan.
    http://valid.x86-secret.com/show_oc.php?id=62848
    Have a great day! //turez
    Intel i9 12900K | Asus Z690 Apex | 32GB Corsair DDR5 5600C36
    Asus Strix 2080Ti | Asus Rog Swift PG279Q | 2xWD Black SN850
    Corsair AX1200i | Lian Li O11DXL Dynamic | EKWB Custom loop
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    Amazing clock
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
    Jun 2003
    Portugal, Lisbon
    Next time put the case inside the snow
    Nice oc
    "God...i know she's dead :'( but keep her soul alive because in my heart she will never die :'(" VoRtAn_MaDgE
    Nc te eskecerei avó! :'(
    Aug 2005
    Germany; Niedersachsen; Schaumburg; Bad Eilsen
    Nice.
    What is the max stable clock?
    The max of my 144 is 3,15, aircooled too, but stable is only 2,8g with 1,52v on a MSI Neo2.
    I know my english isn´t the best ...
    my pc
    oVerkill.OC - Technic3D
    May 2005
    Paris (France)
    that is "chilled" air but not "normal" air
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Yep, really amazing !!!
    Rip off that sucking IHS, build up yourself an IGLO and put in Your PC with a long wire connection. You'll get 3.7 easily.........
    Nice chip mate.
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Nov 2004
    Vietnam
    OMG, "Air supper cool"
    Oct 2005
    very nice chip, but dont you think almost 1.7v is pushing it? even if your temps are reasonable its not fantastic for the chip
    Opteron 170 @ ??? CCB1E 0550 VMPW 678L50
    DFI nf4 Ultra-D
    2x1gb G.Skill HZ (Back from RMA)
    BFG GeForce 7800 GT (Back from RMA)
    74gb Raptor
    Seasonic S12 600W
    Thermaltake Big Typhoon
    Jan 2006
    Nice result, its a war now I will rip my IHS of and go for 3600 on air.
    I assume by the temps that you do not use your IHS.
    Sep 2005
    The Netherlands
    Nice result for AIR
    Get IHS off en put some Phase or DI on it
    Epox 9NPA+ Ultra - Opteron 146 0530 APMW
    Infineon BH-6 2x256mb - Tagan 480W-U22
    Gainward 6600GT Vmodded - Kingston HyperX BH-5 2x256mb
    Infineon BH-6 280MHz 2-2-2-5 @ 3,77V - 3602MHz - PhCh mem Project
    Jan 2006
    that is trap!in Swiden played with advantage with those temperatures xD
    Mar 2005
    Molde, Norway
    When you've gotten off that HS try burning it in for a while if you haven't. F.ex run two instances of "toast burn-in" (two separate exe's.)
    Great cpu and cooling solution btw!
    Dec 2005
    Warsaw, Poland
    Winter is very good for overclocking.
    Low temperatures and open the window
    Congratulations
    Nov 2005
    On da battefield
    Nice.
    You might get a few degrees lower if you have the neighborhood kids throw snowballs at the thing....
    Sep 2005
    The Netherlands
    You peeps have luck if you live in Finland or something
    It's here in the Netherlands arround 0c atm too
    Dec 2005
    nice clock man
    crazy temps over there in swe! :p
    DFI LANPARTY UT nF4 Ultra-D [6/23 BIOS]
    AMD Opteron 148 [CAB2E 0546GPMW] [257x11.0 @ v1.500] & Zalman CNPS7000B-CU
    OCZ EL Platinum Rev. 2 2x512[207FSB @ 2-3-3-6 @ v2.80 1T]
    DFI Ultra-D [6/23 BIOS]
    eVGA 7800GT [470 / 1100]
    Western Digital Caviar SE 250GB Serial ATA
    Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
    Jan 2006
    Austria
    nice work!
    btw: we had -14 °C in Austria last Week but I had no time to clock
  18. #18
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Definetely great clocks! Rip the IHS , helps a lot ....
    What TCase has that Opty of yours?
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
  19. #19
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    I have a Opty 146 CABYE 0540FPMW and so far I tested 3004 MHz AIR with 24°c ambient prime 8 hrs and SpI 32M STABLE, but I recognized PSU is holding me back, it doesnt make the 12V rail and the HDD turns sometimes off ,
    so Im going for a Tagan U15 PSU (btw I see you have a Tagan too, which one?)
    Bios my arss.....
    Hipro5
  20. #20
    I am Xtreme
    Aug 2003
    Quote Originally Posted by terrordemon
    It's 100% 24/7 safe. I benched for hours on hours with 1.9-2.05v through my 146 and it still runs just as well as it did out of the box on water.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  21. #21
    Ebay Hater
    Aug 2004
    Denmark / UK
    That would be to say before you chipped the core and destroyed some little crumby things
    In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
  22. #22
    Sep 2004
    Sweden
    Quote Originally Posted by Aerosupra
    I got the 530W Easyconnect. A great agg with very stable voltages.
    Tanks everyone for your answers!
    BTW: I'ts around -11C right now. Time for benching ;D
  23. #23
    Jan 2006
    (Offtopic) You wont have your X600xt WR for much longer, Perry_78 :@
    Is your card v-modded by the way?
  24. #24
    Sep 2004
    Sweden
  25. #25
    Xtreme News & Reviews
    Apr 2005
    Atlanta, GA
    SO SO CHEATING!!!!!
    Here in ga i get maybe 4C air outside
    Desktop
    AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
    Gigabyte GA-MA790X-UD4P (F9 Bios)
    8GB (4x2GB) @ DDR2-800
    ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
    Corsair Force GT 120GB
    LSI MegaRAID 8408E (3x750 R5)
    Windows 7 x64 SP1
    Cisco E2000 with DD-WRT kernel 2.6
