well, first of all, I would like to appreciate MikeGuava sent me 3 great fx57
to me for doing this benching comparison.
They are : 0513mpmw(T), 0516wpmw(N),and 0522TPMW(T)
I have 2 fx57, one is 0516wpmw, it also from Mike as well
As well know, 0516wpmw has 2 different wafar numbers ; 1 is 1241482e, another is 1241732e. Both are about the same OC performace, 1241482e is a bit better than 1241732e. Due to these two 0516wpmw benches are everywhere you can read about. So I won't post again here.
So here I would like to show you guys are 0513mpmw, 0522Tpmw also the very rare to see one is the one I just get, 0524 VPMW(T) with Y starting wafar number.(will post the pic later)
Before I got the 0524vpmw, I previously owned the 0522tpmw before, this 0522tpmw is really an awesome fx57 even better than 0516wpmw; however, it is also really rare to get it from retail due to AMD got most of them for RMA purpose. Moreover, 0513mpmw and 0512mpmw are for review sample only. So what about 0524VPMW? well, the XIP of AMD CPU expert S7e9h3n said "It might be a garbage!!" Well, let see if that vpmw is garbage.
All I did is compare their SUper pi Mod 1.4 (1m, 8m, and 32m)and some Pifast.
Testbed:
Mainboard: DFI eXpert SLI-DR; BIOS 1117B
RAM: Team Xtreem BH-5
Power: OCZ 600adjSLI
HD: WD740GD single drive
OS :Windows 2003 server
Cooling: PCICE Single stage
**Note: Every CPU memory controller is totally different, so A64tweaker setting table would be a bit different either.
Let's see super pi 1m:@ DDR520(260x13),1.44v
0513mpmw: 1m
0522tpmw
0524vpmw:
pi 8m:
0513mpmw :
0522tpmw
0524vpmw:
For 32m:
unfortunately, 0513mpmw could not finish 32m at that vcore, vdimm under that setting I used on the 0522tpmw and 0524vpmw
0522tpmw :
0524 vpmw, when I test this cpu, I feel it's really strong and decide to challenge 1.44v on the 3.4g 32m, so here we go, THIS IS BY FAR MY PERSONAL RECORD that the best FX57 use the as low as vcore can do 32m pass lowerest vcore ever.
Continued
