Some time ago I started building a small cascade with two NL11F compressors. In the first stage I use 200cm of 0.026 captube and a 4,5m long HX with 2x 3/16 in 1/2" tubing. In the second stage I use 230cm of 0.026 captube and a second HX to desuperheat the gas before it enters the main HX.
Dimensions of the cascade: 60x30x40cm
Finished
First run
20mm thick insulation is frozen after 1 hour of running
First stage holds about -60° HX in and out when 2nd stage is running. I don't know why but this cascade is working better than all my previous cascades, where I used valves. I will put her under load today, lets see what it can do
