Bought a 512MB HIS X1800XT PCI-E from Auspcmarket.com.au and it arrived yesterday![]()
256MB BFG 7800GTX next to 512MB HIS X1800XT
Full pictures here http://fileshosts.com/videocards/HIS/X1800XT/html/
System
Opteron 146 CAB2E 0540FPMW Corsair Hydrocool 200 Water cooled
DFI NF4 Ultra-D R.AD0 704-2BTA bios
512MB HIS X1800XT with Cat 5.11 drivers
1x 74GB WD Raptor 10K SATA OS drive
1x 160GB Seagate Barracuda 7200.7 SATA NCQ
Liteon 48x24x48x CD Burner
Floppy drive
510W PC Powercooling SLI psu
WinXP Pro SP2 - very old install left over from DFI NF4 SLI-D i had (haven't bothered to do a fresh reinstall yet)
NF4 6.53WHQL chipset drivers
Ram = 2x 512MB Gskill PC4400LE TCCD 431
Some CCC screenies:
Default fan speed in windows is 27%
GPU @27% fan speed = 54C idle
Using ATI Tool set fan speed at 100% and GPU temp drops 8C at idle!
GPU @100% fan speed = 46C idle
- weird CCC shows 20C if ATI Tool is running together heh
- according to ATI Tool at idle GPU current draw = 8.2A and stock speed load GPU current draw = 21.8A - 24.5A
Overclocking Tools
Now there seems to be 3 way to currently oc the card but it seems it ain't as straight forward as first thought - see Update below as to how to properly set 3D clocks:
1. ATI CCC control panel - seems to limit max GPU clocks but loosens memory timings ALOT so that you clock mem higher using this tool.
2. X1800 Overclocking tool - available from Driverheaven.net's download section
- this seems to also loosen memory timings ALOT so you can clock mem higher, but you can clock GPU higher than that of with ATI CCC control panel. Read http://forums.techpowerup.com/showpo...1&postcount=88
- Also voltage reporting is out of whack and not accurate.
2D
3D
3. ATI Tool 0.25 Beta 9 - http://forums.techpowerup.com/showthread.php?t=6615
- artifacting scanning doesn't work properly as it reports artifacts at stock (known bug)
- now this tool tightens the memory timings so much tighter than the other 2 tools above, so you can't clock mem as high.
- BUT! According to http://www.xtremesystems.org/forums/...ad.php?t=80637, 600ish mhz on mem in ATI Tool 0.25 Beta 9, is already 200-300pts higher in 3dmark05 than 700-800+mhz mem in X1800 Overclocking tool apparently.
- Also voltage reporting is pretty spot on with ATI Tool.
Unfortunately, this version of ATI Tool is far from perfect for X1800XT users see
- I get this problem too when oc'ing a tad in ATI Tool screen goes blank when i hit run in 3dmark05 and other benchmarks http://forums.techpowerup.com/showpo...4&postcount=58
- http://forums.techpowerup.com/showpo...&postcount=154
- http://forums.techpowerup.com/showpo...9&postcount=69
- minor change in clock with ATI Tool on GPU to 600mhz and 3dmark05 completed and my ATI Tool reported GPU at 378mhz and dropped 3dmark05 score from 8,400ish to 6,900ish similar to this guy's issue at http://www.rage3d.com/board/showpost...3&postcount=47
ATI Tool seems to only report the 2D speed when run first go. Here's voltages and temp panel:
I think all X1800 owners should start bagging the cards oc'bility to force ATI to release their WinCLK overclocking utility that Macci used for his preview/pre-release benchmarks for his X1800XT and save us X1800XT owners the headaches we paid AUD$960-1,000+ for :nod:
Update on how to properly set 3D clocks:
- Some interesting info posted at http://www.xtremesystems.org/forums/...29#post1160329
Yay, can confirm it works:Originally Posted by SIOUX
- In service manage in windows disable ATI Smart and ATI Hotkey services and reboot pc. You loose temp reading in CCC but can use ATI Tool to view temps.
- Use X1800 Oc'ing tool and set 3D desired clocks using the 2D panel
- Use ATI Tool to only verify and view the 3D clocks are set correctly. So should be same as what you set in X1800 Oc'ing tool.
- Whenever you set the mem clock, remember to set the GPU core clock again, or it will fall back to lower clocks and when you set the GPU core clocks again, remember to set the mem clock again, or the same will happen.
- Setting voltages, OC'ing tool reports wrong voltages so DO NOT use OC'ing tool to set voltages, use ATI Tool to set voltages. Example, GPU voltage reported in ATI Tool is 1.275v will show in OC'ing tool as 1.3v. Set ATI Tool GPU volts to 1.3v will show OC'ing tool at 1.325v but the real voltage measured by DMM is closer to 1.3v as set in ATI Tool.
As you can see it works!
3dmark05 @default 621/747 clocks set in 2D panel of X1800 Oc'ing tool app.
I then tried setting 2D clock in X1800 Oc'ing tool higher in same windows session and got:
650mhz = 648mhz real GPU 3D clock
660mhz = 654mhz real GPU 3D clock
670mhz = 668mhz real GPU 3D clock
680mhz = 675mhz real GPU 3D clock
685mhz = 681mhz real GPU 3D clock
690mhz = 688mhz real GPU 3D clock <-- had to increase and fix fan speed from 31% to 100%
700mhz = 695mhz real GPU 3D clock (upped GPU volt from 1.275v stock to 1.325v in ATI Tool - shows at 1.35v in OC'ing tool)
702mhz = 702mhz real GPU 3D clock (1.35v ATI Tool)
703-708mhz = 702mhz real GPU 3D clock
710mhz = 708mhz real GPU 3D clock (1.375v ATI Tool)
711-715 = 708mhz real GPU 3D clock
716mhz = 715mhz real GPU 3D clock (1.4v ATI Tool)
717-723mhz = 715mhz real GPU 3D clock
724mhz = 722mhz real GPU 3D clock (1.425v ATI Tool)
730mhz = 729mhz real GPU 3D clock (1.425v ATI Tool)
740mhz = 735mhz real GPU 3D clock (1.425v ATI Tool)
745mhz = 742mhz real GPU 3D clock (1.425v ATI Tool)
750mhz = 749mhz real GPU 3D clock (1.425v ATI Tool)
Note:
- interesting ATI Tool reports default GPU volt = 1.275v
- but ATI CCC according to folks measuring via DMM GPU volt default to 1.33-1.35v ????
same goes for mem clocks in X1800 Oc'ing tool
780mhz = 774mhz real mem 3D clock
800mhz = 792mhz real mem 3D clock
810mhz = 810mhz real mem 3D clock
820mhz = 819mhz real mem 3D clock
830mhz = 828mhz real mem 3D clock
840mhz = 837mhz real mem 3D clock - (artifacts when GPU voltage is stock but at 1.375v GPU volts no artifacts even though mem volts are still untouched at stock! )
850mhz = 846mhz real mem 3D clock (1.375v GPU ATI Tool)
860mhz = 855mhz real mem 3D clock (1.375v GPU ATI Tool)
870mhz = 864mhz real mem 3D clock (1.375v GPU ATI Tool)
880mhz = 873mhz real mem 3D clock (1.375v GPU ATI Tool)
890mhz = 882mhz real mem 3D clock (1.375v GPU ATI Tool)
900mhz = 900mhz real mem 3D clock (1.375v GPU ATI Tool) - artifacts
3Dmark Benchmarks
Stock cpu 10x200HTT = 2000mhz + @X1800XT clocks
stock 2D = 594/693
stock 3D = 621/747
With SIOUX's work around for X1800 Overclocking tool set
3Dmark05
with cpu stock managed
@680(675)/800(792) = 8,986
@690(688)/800(792) = 9,044
@702(702)/800(792) = 9,060
@710(708)/800(792) = 9,084
@710(708)/802(801) = 9,106
3Dmark2003
with cpu stock
@621/747 = 16,368
@708/801 = 17,698
How sweet is this for 512MB HIS X1800XT on stock heatsink air
Opteron 146 CAB2E 0540FPMW @10x280HTT = 2800mhz at stock vcore
2x 512MB Gskill PC4400LE @280mhz 2.5-3-3-6 7-14-2222
3dmark05
@621/747 = 9,235
@708/801 = 10,163
@742/891 = 10,795
http://service.futuremark.com/compare?3dm05=1504826
3dmark2003
@621/747 = 17,707
@708/801 = 19,169
Opteron 146 CAB2E 0540FPMW @10x300HTT = 3000mhz at 1.408V
2x 512MB Gskill PC4400LE @272mhz 2.5-3-3-6 7-14-2222
3dmark05
@621/747 = 9,287
@708/801 = 10,221
@715/882 = 10,601
http://service.futuremark.com/compare?3dm05=1501277
@750(749)/890(882) = 10,869
http://service.futuremark.com/compare?3dm05=1501440
3dmark2003
@621/747 = 17,945
@708/801 = 19,449
@735/882 = 20,328
Aquamark3
@621/747 = 98,100
@708/801 = 101,262
Dam local thunderstorms in the area so shutting down unecessary pc activity so this is where I am for tonight
Opteron 146 CAB2E 0540FPMW @10x310HTT = 3100mhz at 1.536v
2x 512MB Gskill PC4400LE @282mhz 2.5-3-3-6 7-14-2222
3Dmark05
@621/747 = 9,321
@750(749)/890(882) = 10,915
Thanks goes to SIOUX for the tips to get me clocking quickly
Update:
Well 23pts to go
And for a treat an original non-resized screenie
Opteron 146 @3120mhz
HIS X1800XT @749/891
3Dmark05 = 10,977
Update:
I have my 11k #4 rank on ORB now
3Dmark05
@749/900 = 11,007
GPU: 1.45v
VDD: 2.171v
VDDQ: 2.165v
Had to squeeze out 900mhz on mem for that bit extra, plus tightened mem timings a tad
pretty nice for single card but definitely lower than what 512MB 7800GTX can do for 3d2k3 especially with dual core cpus and dual core optimised drivers. Although WarCat 5.11b drivers seem to give 1,000+ pts more than Cat 5.11
3Dmark2003 = 20,784
But 3Dmark2001 has always loved ATI cards
3Dmark2001 = 40,094
Updated: Dec 8, 2005
changed to the drivers on the HIS CD-ROM which are cat 5.11 6.14.10.6575 WHQL FM Approved versus cat 5.11 on ATI.com web site which are 6.14.10.6583 WHQL not FM approved and clocked a tad higher
512MB HIS X1800XT stock heatsink air
@756/900 = 11,049
http://service.futuremark.com/compare?3dm05=1530346
(currently equal 7th ranked on ORB for X1800 series OR #2 ranked for WHQL - FM approved drivers)
edit:
meanwhile managed to get #2 ranking on ORB for FM approved drivers in both 3dmark05 and 3dmark2003 for X1800 series categories
Opteron 146 @3130mhz
HIS X1800XT stock heatsink air @756/900
3dmark05 = 11,049
3dmark2003 = 20,860
