Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 102
Thread: atitool 25 beta 9
    Nov 2005
    atitool 25 beta 9
    Where can i get this tool,i need it .I wanna burn my x1800xt
    Mar 2005
    Imladris
    W1zzard over at techpowerup.com hasn't released it yet for public consumption. You'll either have to get it directly from him or from someone else he's given it to.
    The little air system that could.
    Xtreme Cruncher
    May 2005
    Lincolnshire, UK
    ATI Tool Beta 9 is now up for download on the techpowerup forums!
    Asus P9X79 Pro | i7 3820 @ 4.875GHz | 4x4GB Corsair DDR3-1600| 3x 6970 Lightnings watercooled| Corsair 1200W PSU | Mountain Mods Ascension case |
    Xtreme 3DTeam Member
    Jan 2004
    Cascadia
    Problems with changing clock speeds on X1300pro....
    Xtreme Mentor
    Jul 2004
    Ontario
    Anyone tried this yet? On Artifact scanning I get a border around the image of pure yellow the second I click on start for artifact scanning. Very wierd pattern to say the least. If I choose old (more compatible?) scanning method I get zero artifacts even after 35 mins. No clue why the two modes are so varied. I hope someone else gets the yellow border around the box if they DON'T choose old compatibility method so I don't feel so alone here. What exactly is the difference between the two modes that varies so much in the way it scans?
    On a sad note as well voltage changes are not applied to the profile on startup so we still have to manually set this each time however clocks sticked.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Nov 2005
    Where the Cheese Heads Reside
    It only supports X1800's so far ant the artifact tool doesn't work yet.
    Core voltage works but memory voltage doesn't yet, it resets to 1.8V BE WARNED. Profiles work only for clocks so far, next version will have voltages applied per profile.
    -=The Gamer=-
    MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
    8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
    Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
    BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
    -=The Server=-
    Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
    3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
    Heat
    Xtreme Mentor
    Jul 2004
    Ontario
    I thought artifact scanning DID work just perhaps not 100% as of now??
    Deathman20 if you use Artifact scanner WITHOUT selecting old (more compabile?) method do you get yellow boxes surrounding the 3D image? Just want to make sure I'm on the same page as everyone else so i don't further worry about this card. I know I'm a pain in the ass but I do appreciate it dude. Thanks.
    Asus P8P67
    Gigabyte GTX 460 1G
    Nov 2005
    I just got artifacts in the screen on mine currently even though it doesn't say theres errors it beeps as it is having errors. Havn't played around with it alot but going to check it out here in a few seconds again.
    -=The Gamer=-
    -=The Server=-
    Heat
    Nov 2005
    Oh BTW it doesn't matter if its normal or the old more compatible mode is selected. Its still artifacts either way. W1zzard mentioned it might not work yet.
    And I don't get no yellow boarder around the window either.
    -=The Gamer=-
    -=The Server=-
    Heat
    Muslim Overclocker
    May 2005
    Canada
    Quote Originally Posted by deathman20
    Set my voltages and frequencies exactly to what I wanted them to on boot up
    Great job w1zzard. Now I don't have to use that crappy ATi internal tool
    Aug 2004
    Manchester@UK
    Quote Originally Posted by cantankerous
    got that too :| havent tried anything else yet as Ive just downloaded it :p
    will report later
    E3110@3.6Ghz || Gigabyte P45-DS3 || 2GB Cellshock 6400 || Asus HD4850||
    Muslim Overclocker
    May 2005
    Canada
    Quote Originally Posted by ahmad
    Nevermind. My computer locks up at boot up with ATITool, so I am guessing that its not setting the correct voltage.
    Although I do remember it working after restarting... meh. I need more rest.
    Nov 2005
    Ok, when playing with ATITool, can you reach the same clocks that you reached with OC at the same voltages (mind you OC reads ~.025V over what actual voltage is).
    -=The Gamer=-
    -=The Server=-
    Heat
    Nov 2005
    Did a test quick...
    OC
    627.5/747
    1.25V/1.95/1.95
    Works fine in games and has past 3DMark 03 and 05 tests serveral times
    ATITool reads voltages as 1.225/1.938/1.938.
    DMM Voltages 1.213/1.938/1.938
    Doing a restart now to eliminate test varables
    ATITool
    625/650 is the higest I can go with out it crashing at least on the memory. 655 crashes the computer.
    Now this is the same voltages OC got but can't achieve, let alone its the exact same voltages. Hmmmm
    Edit: running 05 to confirm what the hecks really going on.
    -=The Gamer=-
    -=The Server=-
    Heat
    Nov 2005
    Ummm discovery... big one
    OC tool
    625/750 3D Mark 05 8710
    ATItool
    625/650 3D Mark 05 9083!!!!
    -=The Gamer=-
    -=The Server=-
    Heat
    Jan 2005
    Same here
    OC Tool
    630/740 = 8230
    ATI Tool
    620/675 = 8427
  18. #18
    Xtreme Mentor
    Jul 2004
    Ontario
    Yea I noticed much better scores with ATItool as well. I thought it was jut me but I guess not! Not bad!
    Asus P8P67
    Gigabyte GTX 460 1G
  19. #19
    Xtreme Mentor
    Jul 2004
    Ontario
    Yea for me it was the same. I got artifacts the second I started the checker and the artifacts came up as solid yellow blocks surrounding the entire fuzzy brown thing. That was what I meant about yellow border, it is what would be known as HUGE clusters of artifacts. The bottom however said no errors found and my system didn't beep either. If I change the mode to old (more compatible?) mode the clusters of yellow artifacts boxes totally disappears and again it says no errors found as well as no beep is audible. I can't wait till X1800 artifact testing gets fully completed as I am dying to see if ATItool will pick up what I see in FEAR with my card with those quick flashing black squares here and there. If ATItool shows my card is fine then I will stop freaking out about this. Setting volts and clocks at startup would be dope too. Good job W1zzard, thanks.
    BTW, you mentioned there is no difference on the mode selected in general? Meaning if you truly do have a bad card/overclock you should and will see errors on both methods? Why have both then? Anyone know the difference between the modes on how they test?
    Asus P8P67
    Gigabyte GTX 460 1G
  20. #20
    Xtreme Mentor
    Jul 2004
    Ontario
    Quote Originally Posted by ken
    will report later
    You too have the huge clusters of artifacts surrounding the fuzzy brown image? What card you running? Thanks.
    Asus P8P67
    Gigabyte GTX 460 1G
  21. #21
    Nov 2005
    Iget yelow in artifact scan 2,but have another problem,voltage of memory show me 2.097v but on OC tool show me 1.8v.
  22. #22
    Aug 2004
    Manchester@UK
    I got an X1800XT and my voltage is at 1.275/2.097/2.097 according to ATITools
    update: set 600/700 in ATITools, run 3D05 and I got weird black screen, wth, I benched at 700/820 by OC no problems !!!
  23. #23
    Muslim Overclocker
    May 2005
    Canada
    I think you guys are not using the OC tool correctly, hence the discrepencies.
    If you have CLI running in the background, it WILL change your clocks to whatever you had them in CCC. Also, after some playing, my 2d/3d option became grayed out and now I can use it without shutting down CLI (still maintains my OC). Only use 2d OC.
    But yeah, results have been pretty much the same...
  24. #24
    Muslim Overclocker
    May 2005
    Canada
    This is what I mean.
  25. #25
    Nov 2005
    The OC tool loosens your ram timings up considerably allowing for higher OC's on the ram but at a cost.
    There is much to be learned with the real deal. And it will take some time to get our OC's figured out again at least on the memory side. OC is going into the recycling bin very soon on my computer since it has of no value to me anymore.
    -=The Gamer=-
    -=The Server=-
    Heat
