Results 1 to 12 of 12
Thread: Finally Lain-Li V2000 prototype is complete (well kind of)
Threaded View
    -100c Club Member
    Apr 2003
    Riverside, California
    Finally Lian-Li V2000 prototype is complete (well kind of)
    If you remember what I went through before, this is upgraded version of previous prototype. I am still waiting for my condenser and compressor for finilizing the design so using old mach II condenser and compressor with newer revision of chilly1 evap is utilized. Froster-X is there but it isn't installed yet as I am waiting for AC adapter for it. BTW, Thanks for the sidewindow NJKid32 (I just borrowed it lol getting one myself next time I drop by my supplier)
    Froster-X LCD... will replace picture when I get froster running.
    PSU was meant to be sitting at bottom but I couldn't get extra length for few cables on this full sized case. Will have to look into extenders. Pointers are welcome. (especially PCI-e extender)
    Bottom is NJKid32's case that has proper orientation to allow best airflow.
    I love this stock window that is made by lian-li. Very clean.
    Innard of system.
    Before putting into case and load testing tuning.
    As usual, X2 running 1.7-1.71v 3.1ghz 2xballistix, etc. Like Idle temp?
    Again, same setting running dual prime
    Unfortunately, these wonderful temp is not same inside case. #1. evaporator lost bit of efficiency leaning sideway, #2. Case airflow is still bit less than ideal. I would need to use something stronger than Panaflo M1A to really get back the temperature. However, I chose not to as being silent and cool is what I am aiming for. Total temperature lost is about 3-4c whic is more than acceptable as even with the temperature increase, it is well over 10c colder than stock vapochill LS
    Once new compressor, condenser, misc parts I asked lian-li to make arrives, I will get next revision of prototype up
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
