Results 1 to 22 of 22
Thread: Single stage in Lian-li v2000.
Threaded View
    -100c Club Member
    Apr 2003
    Riverside, California
    Few more tweaks need to be done as well as changing compressor (too noisy for my taste). Need to fabricate front PSU intake vent drive bay and rear exhaust 120mm fan hole for lower half. Too tired to do any more cutting today :P
    No PSU doesn't go straight in there... I had to pop out the rivet, move it off a little, drill hole than re-rivet the drive bay cage. Think I can't tolerate anything louder than Mach compressor really so thats what will go in instead of this 1/3 HP compressor.
    Edit: Mucho updates... Only thing left is redoing the back plate to make it nicer and better aligned (just cosmetic) and cleaning up the wire again... (cosmetic again:P) Possibly rewiring H2O loop to make it easier to work inside case.
    Fabricated Lian-li perforated style drive bay cover Used up 3 spots for better airflow when only really needed 2 slot size. Why not :P
    Version 2 with PC ICE's rework on compressor and better placement of condensor to get most air from intake fan. used different platform and different compressor (mach compressor) but basically same thing.
    Back PSU bracket rev.2 is work in progress. Basically same thing but better alignment and cuts than what it is now
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
