Well for all of those who are interested in using an Iwaki WMD30RZT I have some bad news. this thing dumps heat like there is no tommorow. My calculations show the heat dump to be a staggering 46.446watts. the test was run over a 1 hour period. well 1 hour and 2 minutes to be exact. the water temp went from 68.4F to 84.6F.
another tidbit of info here. after an hour or so the pumps case temp reads an astounding 82.78C!
to compare the WMD20RLT i have dumps 14.45watts based on the same test here.
through all of this there is SOME good knews. based on the pressure testing which showed with the RBX and maze4 (aluminum topped one) my flowrate was roughly 4gpm at 18.567ft of head!
here are some complimentary pictures. Brandon i was gonna get a video with some sound of this wierd sound the pump was making at first but it stopped before i could get the video going. its been running for over an hour since then without issue.
EDIT: I let it run for another hour for fun to see what would happen and the water temp is at 100F and the calculatiosn show around 40 watts of heat dump. im guessing its lower now due to the high heat differnetial. based on newtons law of heating, the higher the dT the faster heat will move. so the warmer the water gets the more heat it will loose through the insulation and the worse the reading.
anyway its time to stop running the pump as i dont want to boil water here.
