Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Slightly tweaked 704-2 DFI bios
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Oskar asked me to unhide a few extra ram options in the upclock section. Some may work and some may not so try at your own risk. I am testing so i know the bios loads ok.
    Also I removed all the CAS settings that don't work, 1.5, 2 , 2.5 and 3 are still there but the others are gone.
    Thats about it, no table tweaks etc and its only available on the -2 at this time.one last thing is i had Oskar remove the added 0.1vdimm thats applied when you set TRCD to 2, so now the Vdimm you set in bios is real close to the vdimm the board actually sets.
    Grab it here
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Oct 2004
    Germany
    I tried it , in Ram Option gives A , B , C , E , D what does that mean ?
    I also have a Winnie
    Mar 2004
    awesome i will test and add to ISO.
    Testing-
    DFI LP DK 790FXB-M2RSH - 1/16 Beta
    Phenom II X4 940 (CACVC AC 0850BPDW), 3.82GHZ (19x201) @ 1.46v (+150mv), NB: 2.61GHZ (x13) @ 1.3375v (11), HT: 2.61GHZ, PCI-E: 101MHZ, CPU: P-1 state
    OCZ Reaper, 2x2GB @ 2.015v, MaxMemClk-1066-5-5-5-15-20-195x4, DDR2-536, Tony's 1066 Phenom SPD
    Corsair HX620, Swiftech 2xMCR120-QP + MCRES-Micro, MCP-655, Vortex XP (D-tek Fuzion v1), 1/2"
    Xtreme Mentor
    Jun 2002
    Any chance to get the -3 version?
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    the jedi master
    Jun 2002
    It seems AMD have mentioned support for ddr533 with FX57, Oskar has added the register options into bios but had to hide them, i unhid them for him
    Now he thinks these added option may do nothing, I renamed them from X to A B....E to we can talk about them.
    Post what you find, remember pressing the insert key will get you booted if the board stalls.
    Tony AKA BigToe
    the jedi master
    Jun 2002
    Quote Originally Posted by xs64
    if you have a winchester none of the upclock options will work, but we just don't know without testing...post what you discover
    Tony AKA BigToe
    Jun 2005
    Greece
    Nice..i will try it with my tccd and my ch-5....
    As xgman said...id there any chance for "clear" tccd version?
    Oct 2004
    SC, USA
    Is this BIOS optimized for TCCD or only UTT/BH5 or all of them?
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    Jun 2005
    Greece
    Here is my first results with tccd
    Dividers "A , B , C , D , E" no boot
    Divider 250 is now shown at a64tweeker as 133 and not as 133++ as with previous bioses but if was 133 my ram should boot at 2-2-2-5 but no go
    Running everest(right now while posting) with my cpu 220*12(stock cooling) and 250 divider and 2.5-3-3-5 i get
    7057 read
    2933 write
    39ns latency
    Now i willt try with one stick of ch-5
    Jan 2004
    The 704 BIOS needs more dividers in the middle range. It goes from 140 to 166 and thats just too big of a jump. It needs at least the 150 divider back. And the 140 divider gave me some weird reports. Memtest was reporting the RAM running at like 285Mhz when it shouldn't of been anywhere near that high and CPU-Z didn't even report the RAM speed.
    Jun 2005
    Greece
    Third party programmes can't read properly the dividers...maybe cpu-z at next version can read them
    the jedi master
    Jun 2002
    You can't add what is not supported, i have a feeling with E die some of the other middle ratio's were done away with and the upper ones added.
    its a case of you can't have everything but you can have 90% of what you want.
    What we need is someone with an FX57 to have a play with the bios...see what they find.
    Im waiting for Oskar to remove the hidden 0.1+Vdimm TRCD tweak from the files then i will load up modbin and mod the other 2. for the record though i hit just as high overclocks with -2 as -3 and -1 with TCCD, i find the -2 stable and universal.
    Tony AKA BigToe
    Jan 2004
    I had a 150 divider on the previous BIOS versions, why wouldn't i be able to have a 150 divider now?
    the jedi master
    Jun 2002
    Ask Oskar
    Tony AKA BigToe
    Xtreme Mentor
    Jul 2004
    Ontario
    yea I noticed the 150 divider gone too. Strange but it could be as Tony suggested, it was taken out for whatever reason to accomodate the newer ones. Wondering however, why does the vdimm get a 0.1v boost if TRCD at 2 is selected? Does it help the board and memory stay stable because of the setting being at 2?
    I too am wondering about the 533 option as supposedly the FX-57 supports that. I hope someone can test it but more imporantly verify that the registers that were put in actually work. If so that would be cool. I plan on getting an FX-57 as my next cpu.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Mar 2004
    Is this bios modded by you bigtoe? Just want to know so I can write it at my website
    Intel FTW!
    Beanna
    Jan 2005
    KAPVT MVNDI Rome, Italy
    with all those new bios..i'm coming from an old one i don't even remember..can't even boot with HT 4x HTT 300
  18. #18
    Dec 2004
    The Holy Land
    that is looks interesting.
    great work tony, i will try it now
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
  19. #19
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    So anyone tried it succesfully? I mean running mem with a >DDR400 divider to get mem speed above HTT speed???
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
  20. #20
    Jan 2005
    Bay Area, CA
    Quote Originally Posted by burningrave101
    Just use A64 tweaker if you need the 150 divider...
  21. #21
    Jan 2005
    so does this bios have that bug that was originally discovered about the vcore?
  22. #22
    Nov 2004
    Yes but the 123% and higher options have been removed so it's pretty safe to use.
    Case: Corsair D800
    Cooling: CPU=EK Supremacy, GPU=Koolance VID-NX690, Pump=MCP655, Radiator= Alphacool NexXxoS UT60 Full Copper 360mm
    PSU: Corsair 1200i
    Mobo/bios: Asrock Z77 Xtreme4
    CPU: 3770 @ 4200
    Mem: Corsair Vengeance LP 16GB 1866MHz CL9
    Disks: Lots of ssd's
    GPU: EVGA GTX690 Quad SLI
    Sound: X-fi Titanium
    Monitor: Crossover Q27
  23. #23
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    About the 150 divider. It's there when I set multiplier to 9x and it's gone when it's at 10x. WTF? I actually need the 150 divider as it maxes out my mem with this 280x10 Venice
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
  24. #24
    Xtreme X.I.P.
    Aug 2004
    Chile
    this has the vcore bug??
  25. #25
    -100c Club Member
    Apr 2003
    Riverside, California
    Well this bios won't let me use PS2 keyboard. (didn't find it out till I hit PC ICE's place where he only had PS2 keyboards -_-)
    JFYI
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
