Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Thread: DFI LP nF4 7/2 NEW BIOS
    Nov 2004
    this is the alpha stage bios for E version cpu , ddr speed higher than htt bus ... it's not completely tested . so use it very carefully . if you fail to boot after bios flash , try to clear cmos or press/hold the insert key and press reset button to reset the system ... The system bios will automatically hide the non-functionable ddr divider/multilier depend on the cpu clock multiplier selected
    702-1
    702-2
    702-3
    thanks OSAKR
    Jun 2004
    kool, im not trying it yet
    May 2005
    Alphas wouldnt mess wit em at least wait until beta
    CPU: AMD FX-57 0516
    Ram: G.Skill 1gb PC 4400 LE / 2x512 Mushkin Redline
    Video Cards: BFG 7800 GTX Viperjohn modded
    HD: 2X WD Raptors 74gb
    Sound: Sound Blaster Audigy 2 ZS
    Case/Cooling: Lian-Li PC65 - Vapochill LS
    Mobo: DFI NF4 Sli-DR
    PSU: PCP&C 510W SLI
    Dec 2004
    as long as it's not "pre alphas" Anyway...who wants to try ?
    Q6600 g0 L741 1.4V@35xx-> 8x44x FSB - 5:6 333/800- 2x2gb OCZ XTC Plats@53x mhz - dfi lp X38 TR2, Ultra Xtreme 120 - W7 64Bit - NV GTX275 - Corsair 520 (blew up) -> Toughpower 750W
    100% Load 24/7
    Mar 2005
    Seattle
    Ya, I have been trying all of these new bios lately. None of them have been any better than the 5/10 ones for me. I'll wait too
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
    Mar 2004
    New York
    Im usually pretty brave with my bios savior ... but im kinda scared..lol
    I wana hear at least 2-3 people flash and then ill try it..
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    I have been out of the cpu revisions for a while, which CPUs do the memory multis work on?
    For those of you about to post:
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Venices and X2's I believe would be version E's.
    Mar 2005
    looks like no one is jumping in...........I gues I wont either
    Apr 2005
    I will try if it can cure my cold boot.
    Xtreme X.I.P.
    Dec 2003
    DONE 702-1 on San Diego 3700+
    Two major additions...
    Just flashed it so no testing yet
ID:	33495   Click image for larger version.
    Mar 2004
    New York
    bachus_anonym.. the brave one..hehe..
    Ill flash it tomorrow.. Too busy testing my ram I just got back from rma..
    XIP
    Nov 2004
    NYC
    Will try it, hopefully it will cure the E & tccd probs...Thanks WWM
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Quote Originally Posted by windwithme
    702-1
    702-2
    702-3
    thanks OSAKR
    Umm... Any ideas as to why the 702-1 & 702-3 are listed under the same name when trying to d/load them??
    Will give these a shot a bit later...
    Just waiting til my 48hour of Prime95 + 1hr loops of 3DMark 01SE/03/05 & all SuperPI tests prove to be stable... Using 623-2 bios ATM...
    Hopefully these new bios will help my PC3200 GOLD out as the last few haven't been stable @ 240MHz like the 510-2/510-3 bios was...
    BTW, stable to me means 48hrs+ of Memtest86+ standard test stable with 50 loops of Test 3, 5, 6 thrown in the mix as well...
    I'll be back to report my findings with the 702 bios...
    Cheers,
    Minh
    Cheers,
    Minh
    Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
    Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
    Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
    Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
    Xtreme Mentor
    May 2004
    Here's the real -3 bios.
    XIP
    Nov 2004
    NYC
    Heres with 702-2 @ 233=RAM/FSB:07/06 and Dram Response Time at fast......cpuz mem. can't read...
    Xtreme X.I.P.
    Dec 2003
    @Dumo
    Hmm... On my SD 3700+ CPU-Z won't recognize mem dividers 233 and 250 at all... Those two fileds in Memory Tab are blank... and yeah, in A64 Tweaker div233 is 117 and I think 255 is 133++ Everest and Clockgen won't recognize mem frequency correctly, either... Looks like we need updates now
    Also, WWM forgot to add that Oscar injected the latest Memtest 1.60 in that BIOS, just for "memtest junkies"
  18. #18
    Mar 2005
    flashing
    hmm so is ur ram really running @ 5/4 or it's running @ what cpuz is showing?
    A64 FX-57 CABCE 0516 WPMW First DI Run
  19. #19
    May 2005
    does this bios fix divider issues with venice
    3200 Venice
    DFI Ultra-D
    OCZ 3200 Gold - BH5
    OCZ Modstream 520
    Antec Superlanboy
    Sapphire X850XT PE
  20. #20
    Mar 2004
    flash is safe. flashed both 702-1 and 702-2. thx wwm and oskar
    Testing-
    DFI LP DK 790FXB-M2RSH - 1/16 Beta
    Phenom II X4 940 (CACVC AC 0850BPDW), 3.82GHZ (19x201) @ 1.46v (+150mv), NB: 2.61GHZ (x13) @ 1.3375v (11), HT: 2.61GHZ, PCI-E: 101MHZ, CPU: P-1 state
    OCZ Reaper, 2x2GB @ 2.015v, MaxMemClk-1066-5-5-5-15-20-195x4, DDR2-536, Tony's 1066 Phenom SPD
    Corsair HX620, Swiftech 2xMCR120-QP + MCRES-Micro, MCP-655, Vortex XP (D-tek Fuzion v1), 1/2"
  21. #21
    Mar 2005
    lol, I don't believe the memtest website even has 1.6v out yet
    EDIT:NM, it does
  22. #22
    Dec 2004
    forrest of imagination
    the point of using DDR>HTT... , maybe gonna see higher RAM clks on windows than before?
  23. #23
    Xtreme Mentor
    May 2004
    If you have a memory controller than can't handle running at high frequencies.
    I don't really see the point though, you could just drop the multi on the CPU and keep the memory 1:1.
    I would like to see half multis more than this.
  24. #24
    Xtreme X.I.P.
    Dec 2003
    That's very true... div233 and div250 are just for those that want/can only OC their mems... Like 200x10=2000Mhz DDR466 or DDR500. I don't think I will be using it but maybe some will
  25. #25
    Dec 2004
    yes .5 multi more helpful than this i guess .. and my venice is 3000+ (multi 9) and i'm running 312x9 (daily) , 350x8 (bench) ... i cannot see any ram (yet) to pull higher than 350 with tight timings..
    anyhow, thx wwm n oskar.
