Hello
Some weeks ago I have made my first DI run . That wasn't even only my first run, but there has been second official (I mean posted on forums) Dry-Ice benching in Poland .![]()
I had 1700+ JIUHB, ABIT NF7, 2x256 MB BH-6 and Codegen 400W PFC PSU.
I made my container of 50 cm lenght, 54 mm (2') cooper tube and cooper plate - 60x80x10 mm .
I have drilled some holes in baseplate with 8mm diameter bit.
Brazing . I used bronze sticks and Acetylene-oxy torch .
Container after cleaning.
Isulation was done, with neoprene - 9mm thick .
My rig. I was benching in a big hall
I picked a ice cube out from the box, which I prepared in home...normal box with styrofoam .
Breaking the block .
Pouring the ice and then acetone "pimp: .
I have thermomether for only -50*C...so the scale ended fast, and then never went onto mensuration scope
OK...let's do some overclocking ..![]()
Ohh yeahI like my old 1700+ ...1466Mhz@ 3006 Mhz so 105 % o/c
Some SPI and Sandra 2003 screens @3006-3018 Mhz/2.20V.
Also new record SPI 16M in Poland on Socket A ...
Max suicide screen - 3214 mhz so 119% o/c ... not bad![]()
My mobo was geting crazy with that vcore..I think it was too cold...real vcore was still 2.20 V
The lowest temperature I could seen on the measure soft..
OK it's time to end this crazy play...![]()
Some frost on mounting bolts.
End of the party ..![]()
Baking the NF7 ...ohh it was delicious.
THE END
For next few weeks I plan next Socket A/Dry-Ice action ... this time on my friend's Barton 2500 +
Best Regards
Peter
