It's this year we start to see some DRAM module made by winbond UTT chip ... Apparently there are some problem now ...
Although the module maker claim and made it to become a high voltage + high speed in official spec ... My personal though is that
this is something , err , ridiculous ... UTT memory chip is even untested from winbond at 2.5V to make sure every single chip is a good one
within it's chip spec , forget about 3.5V plus life time warranty ...
I will not be surprise to see if module made by UTT chip can not work after some weeks or months even at default voltage ...
I will not buy anything that is untested by it's "original" manufacturer ...
Think about it ...
If nvidia made a lot of UTT NF4 chipset , and sold them to motherboard manufacturer ... Someone start to sell these board made by
UTT NF4 chipset , they even claim and gurantee that this board is capable of running at 400mhz fsb and 2.0V chipset voltage just because
they have test it before they ship it to you ...
Will you buy any board made by UTT NF4 chipset like this no matter you want to use 400mhz fsb and 2.0v chipset voltage or not ?
I have a classmate who work for IC packaging and testing company ...
According to what he told me , IC testing is quite complicated and is a very professional process which made it to become one
separate business from IC chip fab ... It's not something like put the chip into final product , running real or testing application , and it's
working good , ok , done ...
As far as I know , IC testing goes through different process compare to real application testing like what we do ... And the IC
testing will require the complete and very detail testing data which is specially designed for testing propurse only from the original
manufacturer which might be a business secret to original manufacturer ...
Since the UTT chip is sold because of it's not tested by professional testing company to save the extra testing cost , I don't think
that the one who buy it will send it back to the IC testing company to do it again ... So they should skip the IC testing level and test it
in application level which might contain uncertainty in it ... Application testing level may not 100% solid no matter how the application is programmed ...
Until now , I did not see First tier module company like kingston or corsair to produce any UTT based module --- within or over the chip spec ...
There must be some reason they did not choose UTT memory ...
For me , I will not buy anything made by UTT chip no matter overclocking or not ...
