POST #112 IS WHERE THE 3516.66MHz SCREENSHOT IS LOCATED
A very big thank you to chilly1 for hooking me up with a kick-butt cooling solution for my new daily gamer. And a special thanks to Vandi423 for providing me with the CPU used in this system.
I have experienced more than a fair share of set backs in order to get this system up and running. But it's up now and it sure is running. I broke everything down last night for final re-assembly inside of its case tomorrow. Hopefully, this system can put up some nice 3DMark scores.
chilly1 Custom Phase Change Systems
DFI LANParty UT nF3 250Gb (5/04 4.0VDIMM BIOS)
AMD Athlon 64 3700+ (Newark)
Sapphire Radeon X850XT Platinum Edition
OCZ EL DDR PC-3200 Gold VX (2x512MB)
OCZ PowerStream 600W Power Supply Unit
Western Digital Raptor 74GB SATA HDD
Under load, the CPU evap block holds a steady -35C. I'll be experimenting with DI and LN2 next month, so I'm hoping that there's a little bit more to be had from this chip.
AIR-COOLED (Thermalright XP-90C + Sunon 92mm)
Just a real quick SP2004 run...
Maximum SuperPI 32M...
Maximum SuperPI 1M...
CPU-Z Validated Sucide Screenshot...
And the CPU with two broken chips...
