Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: Killed my BIOS chip on DFI NF4 - why??? Made no mistake........
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Question Killed my BIOS chip on DFI NF4 - why??? Made no mistake........
    O.K. - Here's the story:
    After some time with my BH-5 I decided to go for another try with my TCCD.
    Shut down the rig, unplugged the power cord and waited till all onboard lites were off.
    Swiched the jumper to the position for 3,3V rail and replaced my BH-5 with the TCCD.
    Cleared CMOS and started the system - long beeps, a constantly blinking power lite on front panel and 3 red onboard lites at the diode area.
    Hm, rebuilt all like it was before but still no POST. Then tried 3 kits of RAM, long CMOS clear, removed the battery, unplugged all USB connections and all the other tricks but still no go.
    Fortunately I have a second BIOS chip - threw it in and ooooooops, rig is running again !!!
    Hm again - gave the first BIOS chip a second try - but again no go, definately killed. But why?
    Replacing the RAM can not kill BIOS and when I swiched the jumper for the voltage rails there was no power to the system but the battery.
    Never heard that it is recommended to remove the battery before setting the jumper........
    Conclusions:
    1) Any ideas what happened here?
    2) All You people with 3 red LEDs on and spinnin' fans but no boot try a second BIOS chip.
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Nov 2004
    Kenmore, NY
    Thanks for the heads up, unfortunately I doubt that most of us have a second bios chip floating around.
    ~MadMikeSS~
    Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
    P5B Deluxe 1236 BIOS
    HIS HD4850@750/1100 - AX MP-1 cooled
    Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
    FSP 700W PSU
    Lian-Li PC-V2000B
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    You can always hotflash
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Nov 2004
    Il
    yea just hotflash so you have that bios chip incase the problem happens again. i would suggest hotflashing as soon as possible.
    Biostar A780 mATX
    AMD Phenom II x2 (Unlocked to x4) Stock Clock/Heatsink
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    Seagate 320GB 16MB Cache Sata 3.0
    heatware: skip86
    May 2003
    NC
    what is hotflash?
    Mar 2005
    Quote Originally Posted by BLHealthy4life
    what is hotflash?
    I don't know, something life-saving perhaps?
    Nov 2004
    Kenmore, NY
    what is hotflash?
    Something that women have when they go through menopause?
    ~MadMikeSS~
    FSP 700W PSU
    Lian-Li PC-V2000B
    Dec 2003
    Cape Girardeau, MO
    my bios got corrupt when I changed some of the mem timings too low. luckily the bootblock wasn't damaged, but it was all buggered up for a while. At first I just got the beeps, then turned it off. Turned it back on and it came up to the bootblock saying checksum error, please insert floppy... turned it back off and walked away pissed (and to find a floppy drive). Came back and it powered on to the Lanparty splash screen as if it'd just had the cmos cleared. Went into bios and there were all kinds of droppings in the menus and chopped text and whatnot...so I promptly re-flashed and the problem went away.
    Q6600 @ 3.4ghz 1.33v
    Evga 680i
    8800GTS 640
    2gb Adata Extreme
    OCZ Gamextreme 600w
    May 2004
    DFI and bios death, two good old friends
    Bios savior fever ahead
    Xtreme Mentor
    Oct 2004
    There are too many threads open at the moment dealing with DFI problems. We only need one active thread since most of the issues being discussed are already being discussed in another thread.
    Please refrain from starting up threads on the same or similar topic from this point forward. In the future, multiple threads on relatively similar issues will be consolidated into one thread.
    Please refer to the AMD section Guidelines for advice and suggestions on how to initiate and participate in discussions.
    Thanks.
    Nov 2004
    Portsmouth UK
    I totaly respect what your saying conrad, but I believe HCC is bringing in a new concept which would have probably been lost in the 30 odd page DFI thread. I agree compleatly that there is a trend arising to post willy-nilly in the AMD section, but I do think this has worth outside of the huge DFI thread. Do you enjoy trawling through 18 pages of posts looking for little gems like this?
    E2180
    MSI P35 Neo2 FR
    Geil Black Dragon 2x1GB
    EVGA 7900GTX
    Toughpower 750W
    Viewsonic VP191b
    Jan 2005
    AMD factory
    Quote Originally Posted by Theo404
    Subscribed - THX. That was exactly the reason I started a new thread.
    Previous system:
    Apr 2005
    UK
    i feel worried about changing memory now if it can cause problems already fed up of computers atm, took me a week to sort out my dfi ultra-d
    MY RIG
    DFI LanParty UT nF4 Ultra-D
    AMD64 3500+
    Corsair XMS PC3200PT 2048mb
    Sapphire X850 XT
    Enermax CoolerGiant 480watt
    2 Blue Neons & 2 UltraViolet Neons
    UV Cabling Kit
    100 Gig Of Space
    Nov 2004
    Portsmouth UK
    Might be an idea to try and fully discharge the components before messing with them, I read in another thread (the name escapes me) that you should pull your power supply cable, wait a few seconds then press the power button (on the PC). Makes sense to me because I tried it and the leds came on for a second and the fans moved a little, suggesting there was still stored current somewhere.
    E2180
    MSI P35 Neo2 FR
    EVGA 7900GTX
    Toughpower 750W
    Viewsonic VP191b
    Jan 2005
    AMD factory
    Quote Originally Posted by icehot
    Nah - think it was not caused by changing RAMs - has to do somethin' with the Vdimm jumper in my opinion.......
    Previous system:
    Nov 2004
    Portsmouth UK
    Ya, far more likley it was a surge or shock when you switched the vdimm regulating curcuit over to the 5v line.
    E2180
    MSI P35 Neo2 FR
    EVGA 7900GTX
    Toughpower 750W
    Viewsonic VP191b
    Nov 2004
    Il
    it could just be a fluke or something?
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
  18. #18
    Apr 2003
    USA Tampa FLA
    yeah you are right. i always unplug the system flip the psu's switch and wait for all the lights to go off on the mb before even sticking my hand in the case! i would be willing to be that it was some sort of surge that caused the problem not just changing the memory.
    peace perc,
  19. #19
    XIP
    Nov 2004
    NYC
    Quote Originally Posted by Perc
    peace perc,
    Absolutely...the best precaution. I think OPB posted the warning way back....
  20. #20
    I am Xtreme
    Dec 2003
    Lightbulb Things to try / consider.
    1. Oskar said awhile ago that yeah you can do bad things if not COMPLETELY discharged so maybe a factor.
    2. Try hotflashing (boot, pull working chip, and replace w/ one you wanna flash , then flash the 'new' chip) including the boot block (just to be sure) the 'bad chip and see if that brings it back.
    3. Thinking it was prolly 5v jumper since I have swapped memory in this board literally hundreds of time w/o issue (other than occasionaly loosing a cap off the dimm )
  21. #21
    Jan 2005
    AMD factory
    peace perc,
    Hey folks I know that and did it, turned off sys, swiched off the PSU and unplugged the power cord, waited for 2 minutes and all the lites were out of course.......
    Previous system:
  22. #22
    Nov 2004
    Portsmouth UK
    I dont think anybody actualy got what I said.
    Of course you have to power down the system and pull the PSU chord, everyone does that. The point I was trying to make is to push the power button on the system after you've done that! Give it a try. on my system the leds came on for a few seconds....ie. still juice in it.
    E2180
    MSI P35 Neo2 FR
    EVGA 7900GTX
    Toughpower 750W
    Viewsonic VP191b
  23. #23
    Jan 2005
    AMD factory
    Now I see Theo - sorry for misunderstanding. Will do that next time. THX.
    Previous system:
  24. #24
    Jan 2005
    KAPVT MVNDI Rome, Italy
    it happened to my friend to 2 weeks ago..he was benching with his new geil ultra-x(bh5) then since it was sucking bad he changed back the rams with the gskill..and suddenly he couldn't boot 3 leds on(it means can't "find" the ram FYI) told him maybe it was the mem controller died..then i also told him to use single channel using the second orange slot..then worked..then worked also in DC
    dunno where the explanation is on why happened but it's scary
  25. #25
    Jun 2003
    Quote Originally Posted by MadMikeSS
    Sorry about that.
    So far when ever i've made changes i've unpluged everything and discharged and i havent had any problems. "Knocks on wood"
