Results 1 to 25 of 79
Thread: 10 heatpipe xp120
Threaded View
    Mar 2005
    Ontario, Canada
    10 heatpipe xp120
    I was able to solder two xp120s into 1. First I tried to just glue them together with arctic alumina thermal glue but the temps were no better than one xp120.Then i got an acetalyne plumbers torch (not oxy-acet) and was able to separate everything.Two propane plumbers torches could not give enough heat.The new xp has the original 5 heat pipes on the bottom, the 2 outside upper pipes soldered beside the first 5 to the base and the last 3 uppers soldered on topof the first 5.That gives me 7 pipes soldered on the base and 3 just above without the the second base.I will pull it out later and get some pics of the finished product but iI have to clean it up a bit, the torch left it very ugly.
    This case has a 120mm exhaust fan that almost lined up pefectly for the upright half ,I will bend it a little more whenit comes out.
    After the AS5 settled my temps are 51-56C at 265(4.24Ghz) and 1.6v.I tried 270(4.32Ghz) and 1.65V but it started to throttle after a half hour of dual prime95,then one prime failed.Temps with one prime95 never get to 50C.
    Running ut2004 for an hour temps never got above 44C.
    The last picture is a thermaltake silent tower with a silverstone nitrogen soldered to it.I made this before you could mount an xp120 to the 775s.The temps were the same as an xp120 but its realy heavy.
ID:	27200   Click image for larger version.
ID:	27201   Click image for larger version.
ID:	27202   Click image for larger version.
ID:	27203   Click image for larger version.
    Rampage III Gene I7 950@4.48G--1.485V HR-02 12G G.Skill 1600-1.5V, GTX470-SLI@725core 1750mem, Antec P180 MINI
