Ok guys, we need some help here:
Please post up you timings, maximum speeds and voltages, along with the memory your are running AND your CPU type (Winchester, Northwood, Clawhammer (FX series, 4000+))
Too many people are struggling with these boards and having a database they can go to for timings would be awsome. I am sure many RMA's can be avoided on both the board and memory. This is one of the toughest boards I have seen over the last 7 years I have been overclocking. I also can kick more a** than any I have seen, when properly tweaked and dialed in.
All the other DFI threads are too long and have too much BS in them to actually go through for help with timings. Please keep this short and to the point. For discussion please use one of the other DFI threads.
Lets get at it! It will make all of our lives easier.
Shot 1:
DFI NF4, Clawhammer (FX55, FX53, 4000+) 130nm and OCZ VX memory
Refresh Rate (Tref) = 4078 in BIOS
Drive Strength Level = 6
Data Strength Level = 4
In Genie BIOS Setting:
CPU StartUP Value = 1.500v
CPU VID Control = 1.55-1.6v
CPU VID Special Control = AUTO
LDT = 1.3v
Chipset Voltage = 1.70v
Dram Voltage = 3.40v (always use less if possible)
Any settings not shown just leave at default or AUTO
Shot 2:
DFI NF4, Winchester 90nm and OCZ VX memory
CAS 2 may work best
Refresh Rate (Tref) = 3072 in BIOS (4708/166 1.95us will cause thousands of errors)
CPU VID Control = 1.50-1.55v
LDT = 1.3v
Shot 3:
DFI NF4, Newcastle 130nm and OCZ VX memory
LDT = 1.3v
