Page 1 of 4 1234 LastLast
Results 1 to 25 of 84
Thread: DFI Ultra-D...SUDDEN DEATH (Part Two)
    Xtreme Mentor
    Oct 2004
    First, I experienced a great deal of sadness. Fine. I can accept the fact that, sometimes, these things happen unexpectedly and without valid cause. This is the reason why manufacturers and retailers extend RMAs to their customers.
    I woke up fairly late today. Staying up until 5:00am watching television has that effect on me. But guess what I woke up to? The sound of Mr. Federal Express knocking on my door.
    I greet Mr. Federal Express with a mouthful of funky morning breath. He tells me where to sign. I take my packages, close the door, and run over to the living room with box in hand and a morning hard-on to go with it. Box is ripped open and my replacement DFI Ultra-D is lookin' sexy.
    Everything gets plugged in. This time, I chose to play around with some OCZ TCCD instead of the VX. Everything boots up at default settings on the shipping BIOS (01/25) and I'm off to test out the VMOD I had performed on my 6600 Non-GT.
    After one hour of trying to find a sweet spot for my card, I decide to give it a rest. Everything is still at default BIOS settings. Here's the plan: shut down the computer, smoke a cigarette in the patio, come back inside, format the HDD, and reclaim my throne on the 6600 Non-GT ORB.
    Guess what? I've got fans spinning, some pretty LEDs, and no signal to the monitor. Deja vu? Call it what you want but after 3 hours of messing around with the board, I'm callin' it quits. And just to top it all off, Newegg will not be giving me a refund for this board. I'm going to have to ship it back to them and wait another week for them to send me the same exact board...just so I can experience the same exact problem again. Sweet deal. I'm not even going to open the box for the replacement, so if you're in the market for a DFI Ultra-D, hit me up. I'm picking up an MSI K8N Neo4 Platinum.
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    man that sucks hard.. whats the diff between the DR and the D. I would look it up but im much to darn lazy.
    Fused
    Dec 2003
    Malaysia
    sorry to hear that
    May 2004
    Nazareth, Israel.
    what a crap!
    tell bud, are you using any USB mouse/keyboard? maybe the info in of the threads here will help you, though i'm not that sure since you've have it running, but who knows...
    more to add, how about investigating your other hardware? maybe you have a kamikaze one over there, that misses the MoBo, eh?
    again, sorry to hear about that.
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Unbelievable - send OPB a PM that he can report to OSKAR. 1 time O.K. - but 2 times the same issue should not happen. So I'm looking forward anxious what will happen to my RMA'd bord when comming back to me..........
    Sure - there is the MSI NEO4, but I need 1,8 Vcore for my FX and I read about the NEO4 is not able to deliver that voltage even with the 20% + trick.
    We will see....., good luck to You.
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Dec 2003
    Dont want to sound like a jerk, but, I dont think it's the motherboards creating this problem.
    Being that this has happened twice, and in the exact same manor, one has to start thinking there is an outside influence.
    Could it be your power supply? I also wonder if the voltage mod on your video card isn't killing these motherboards?
    I mean, it's not beyond possible in any way, but to go through two boards and get the same end result is more then just poor QC.
    Good luck with it bro, hopefully the third times the charm on this one.
    GigaByte EP45-DS3R
    Intel Q9650 @ ???ghz 9 x ??? 1.35v ~ 1x120mm W/C
    2 x 2gb Patriot EP PC2-6400EL @ 1:1 2t 5/5/5/12 2v
    Evga 9800Gx2
    2 x 74GB Raptor Raid 0
    PPC&C 750W SSI
    Dell 2005FPW
    Cooler Master 590
    Xtreme Mentor
    Oct 2004
    The difference between the D and DR is four SATA ports supported by the Silicon Image Sil3114 chip.
    I can guarantee that the other threads regarding USB voltage jumpers, bent capacitors, and what have you will have no effect on my board. The problem is much deeper than that. Again, the mods on DFI-Street are not sharing something that the rest of the community should be aware of. Why? I do not know.
    The hardware I used is the same hardware others are using with success. A Newcastle processor, TCCD memory, PowerStream 520W PSU, and a Raptor hard drive. I tested with VX on my first Ultra-D, so I decided to give my TCCD a shot this time around.
    I don't mind the lack of options on the Neo4. I'm sure I'll find a few VMODS that can easily be implemented to give me close to what I'll need. I just need a board that will last longer than a few hours and the DFI is just not a lucky board for me right now.
    Xtreme Mentor
    Oct 2004
    Quote Originally Posted by GRAFiZ
    I doubt it. A lot of people are running the same exact PSU on the same board without grief. I have also tested my Zippy PSU with the same result.
    Absolutely not. I did not have a VMODed card for my first board. I only performed the VMOD on my card last night, and that was over 12 hours prior to the arrival of my replacement board.
    I know. And this is why I believe that there is something more to it than just the basics. With this board, I didn't even get to flash the BIOS or modify any setting in BIOS. It was completely stock and untouched. Not even the date in BIOS was changed.
    Thanks, bro. But when the 3rd board comes in, I'm selling it to avoid the same hassles.
    Apr 2004
    Auckland, New Zealand
    Really sorry to hear this Conrad, I know how much you have prepared for this rig.
    Jus for shts and giggles have you tried unplugging the PSU from the board completely and leaving it, then plugging it in again and powering up?
    The Zippy has a known issue with the DFI, but I mean putting the OCZ back in again...
    Sounds like after a restart something real dodgy is happening... something not initialising properly or jus plain corrupting itself.
    Good luck with the Neo4, let us know how that goes bro.... and good luck in dominating the 6600 class!
    VX/UTT Voltage Scaling, please contribute...
    10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
    Mobile 3400+ CG 0437XDPW
    DFI LanParty UT
    XP120 w/ 120mm Thermaltake Thunderblade
    2x512MB OCZ VX
    BBATI 9800np w/Infineon
    PC Power & Cooling 510w Deluxe
    Jan 2003
    Macomb Twp MI
    What is the known prob with the zippy P/S with the DFI boards? I have the same setup with the 700 WATT zip..
    Xtreme Mentor
    Oct 2004
    Alex - I've tried everything, bro. The first board was even allowed to sit inside of its box overnight. I never got anything more than a bunch of fans whirling and a few LEDs. I can accept bad luck when it comes to hardware not overclocking to my satisfaction. But bad luck with hardware just randomly having a stroke is completely unacceptable to me.
    eclypse - There are several of us here that are not able to boot our systems with the 4.0VDIMM jumper enabled while using the 700W Zippy. It works fine, though, with the jumper in the default position.
    Oct 2002
    London
    Have you tried removing the battery from the board, with no power connected m8?
    Real bad luck, with two boards
    Xtreme Mentor
    Oct 2004
    Yes. I've removed the battery, set the jumper to clear CMOS, set the jumper to safe boot, unplugged everything. Nothing works.
    Sep 2004
    Man that's fusked up. :| I may have to stop recommend this board. She's built but I've been hearing to much BS.http://forums.anandtech.com/messagev...&enterthread=y
    Xtreme Mentor
    Oct 2004
    Don't get me wrong. I've had 2 DFI 754 boards. They were excellent. The new DFI 939 boards are just as good (for other people). They're just not good for me and it's starting to hurt me feelings.
    Sep 2004
    250GB is good or god. But I dunno about this one. I was doing some searching and found about 14 threads at AT and serveral here with same GD issue. Just won't boot. I'm not going to start rumor but poor QC at minimum.
    Evil Kitty
    Jun 2002
    Detroit, MI
    Boy that sucks! Sorry to hear of the troubles.
    That said, given the thousands of DFI NF4 boards that sold in the span of a few days, and the fact that there is only a handful of dead mobo reports around the net (even a report of 20 dead boards is nothing when compared to what sold), its hard to say there is any "issue". In fact, given the huge number of boards that sold in such a short period, I would have expected to see more reports. If there was a real issue, you'd see DFI Street full of dead mobo reports....not just a handful like we are seeing.
    I dunno what others might think, but two boards going down the exact same way seems to indicate something you are doing, or something in your hardware config, that is the common denominator. There just isn't a large enough percentage of bad boards out there to support the theory that you happen to receive two bad boards as a practical explanation.
    Not ragging, just suggesting you double check your whole system. Good Luck!
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
  18. #18
    Xtreme Member soundx98's Avatar
    Dec 2002
    Cantundastan, Wisconsin
    Excuse me, I had to go change my underwear after reading your 1st post.
    My replacement board arrives today.
    I bought another rather than wait on an RMA.
    Let's hope this one is without issues and the RMA board is repaired/replaced.
    My 1st setup went without a hitch and was smooth sailing until it went down. Still not sure it was the board or me that caused it.
    Whatever has caused the problem is made completely frustrating by the fact you CANNOT enter the bios. You're screwed, blued, and tatooed. Would a bios savior solve the issue? I didn't use one. Most of us still have it in our NF2! But even with a newly flashed bios chip I was unable to enter bios.
    I don't think DFI-street mods or anyone else know positively what is happening. Otherwise there would definately be a fix out. DFI has been through this before. I have to believe it is some type of Bios corruption.
    conrad, I want you to know, I really feel bad for ya. Hoping the re-built rig is problem free. For both of us. good luck brutha.
  19. #19
    Nov 2004
    His motherboard isnt grounding properly.
    Change out all the motherboad screws and use smaller ones.
    this has happened to me alot. the board is fine
    Tba
  20. #20
    Xtreme Mentor
    Jul 2004
    Ontario
    I don't believe this. Conrad, you of all people are the one I was anxiously waiting for a response from on your new board. Now you tell me its dead again in a couple hours? This is getting really hectic. It seems more and more that this is happening. Poor QC is right. I heard of other people getting their boards only to have the onboard power and reset buttons broken off floating around the box.
    The more I hear this the more I am staying away from the DFI as I have heard many others are doing. I really don't feel like these hassles. Let me know how the MSI goes as I may go that route too. I have most of the stuff for my new setup except the board as I was leary to get the DFI after these stories. I am going cpu hunting today and then getting myself a new gpu and im done.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  21. #21
    Jul 2003
    Mason, MI... USA
    I glanced through your previous thread also and have to ask if you've tried a PCI video card in there?
    I certainly would try everything possible to get this figured out, normally something reoccuring like this is not a coincidence.
    Try:
    no mouse/only a ps2 keyboard/no hdd/cdrom/floppy with only one vidcard pci or pci-e.
    When using USB mouse/kb try all USB ports as on most boards no all of them initialize properly on boot. If you are using the sound module thingy try disconnecting that too.
    GL with whatever you do but i would really like to see your problem fixed or found.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
  22. #22
    Jun 2002
    Denver, CO
    Bummer man. I setup my board last night and it went the smoothest an upgrade has gone in quite a while for me. No problems what so ever and I was expecting quite a few.. Are you using the 5v rail for ram on both of these boards? Just curious. It does sound kinda fishy two boards dead same symptoms .That's whats so aggravating about DFI is it the board or the user.
    Maximus Formula||E8400 9x445 1.42v||2x2GB GSkill PC8000||150GB Raptor||ATI 3870 840/1200||Vista64
    DFI NF4 Ultra-D modded to SLI-D||Opteron 165||4x512MB Patriot XBL 2.7v||X850XT 575/594||37GB Raptor||Seagate 120gb||Audigy 2 ZS||XP Pro
  23. #23
    Feb 2004
    Houston, TX
    Sorry to hear about your board conrad. It does seem like DFI is having some CQ issue just as they did back in the nf2 days. Some people would get really great overclocking boards and others would get board that would not even post.
    I was one of those people that got a bad nf2 board back in the day but decided to give DFI another try after I heard the nf3 were alot better. Now it seems as though they are having the same issue as they did back then so for now I would stay away from DFI. I think I've seen over 20 threads on various forums about DFI sudden death.
    Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
    Gigabyte DS3 C1 F8i
    2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
    Asus EN6200 8 pipes enabled
    250GB Hitachi T7K250
    Fortron Blue Storm 500W
    Antec P180
  24. #24
    Jan 2005
    AMD factory
    Hm, think it's time for the ultimate solution:
    What's good for ASUS should also work on DFI..............
    Previous system:
  25. #25
    Nov 2004
    london
    "The difference between the D and DR is four SATA ports supported by the Silicon Image Sil3114 chip."
    but what does this mean or do
