Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 152
Thread: DFI Ultra-D...SUDDEN DEATH
    Xtreme Mentor
    Oct 2004
    For the past 30 hours, my board has been working fine. As a matter of fact, I did not encounter a single problem when installing the board and configuring it. It has been 100% hassle free up until about one and a half hours ago.
    Just before it conked out on me, I plugged in a good ol' IDE hard drive so that I can install Windows 2000 Professional. I pulled the plug on my Raptor so that BIOS would only see the IDE drive. I reset BIOS so that everything was set to AUTO - no overclocking whatsoever. WIN2K installed fine. I then rebooted the computer so that I can defrag the drive. Fans are blowing full blast, LED lights on the board are on, but I wasn't getting a signal to my screen. The diagnostic LEDs only have three lights on. I tried reseating the graphics card, reseating the CPU, reseating the RAM, and swapping the RAM with other modules. Nothing. I've reset the CMOS, pulled the CMOS battery, consumed a few Heinekens. Nothing.
    I was wondering if anyone else has encountered the same problem - or if anyone has a clue as to what has caused this to happen.
    Components used were:
    - AMD Athlon64 3500+ Newcastle
    - DFI LanParty UT Ultra-D
    - OCZ PC-3200 Gold VX (2x512MB)
    - XFX GeFORCE 6600 256MB
    - OCZ Powerstream 520W
    Banned
    Jan 2004
    Land of Buckeye
    I will refer this to Oskar.
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    Can you try out another PSU? I had a computer that appeared like it was on and tried everything...turned out the PSU was bad
    jjcom
    Dec 2003
    city of industry, CA
    yes, please try another psu, i've seen the ocz 520w do that before.
    new benching rig
    mobo: dfi ultra-d rev. AD0
    cpu: x2 3800+ @ 3.30 ghz
    cooling: VapoLi SS by jinu117
    stepping: LDBHE 0601 TPMW
    mem: khx pc3200 1gig bh5's
    psu: zippy emac 700watts
    gfx: evga 7800gt @ 650/1355
    hd: 36gb raptor + seagate 120gb
    single 7800gt 3dmark05 WR!
    3dmark05 - 10814
    Jan 2005
    "Fans are blowing full blast, LED lights on the board are on,"
    This means the board is getting power from the PSU. It could still be the issue, but I don't think it's very likely.
    Banned
    Jan 2004
    Land of Buckeye
    I fried a ocz 520w when I first day got SLI-DR, but not like this.
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    Quote Originally Posted by thebluesgnr
    I had something like this happen on an old 90mhz P1. Everything turned on, but the PSU wasn't giving enough for the MB to work
    jjcom
    Dec 2003
    i've seen where the OCZ 520w was working on psu testers and also with the paperclip trick, which only starts up the powersupply, but failed to work on any motherboard that it was tried on.
    new benching rig
    3dmark05 - 10814
    Xtreme Mentor
    Oct 2004
    The Zippy that I had purchased specifically for this board was a no go on my first day with the DFI. I read of others here having the same problem. The OCZ unit worked flawlessly up until the point when the board died. I tried a Thermaltake PSU as well and it just doesn't want to boot up.
    I'm sure 520W from the OCZ unit is more than adequate. I was only running one hard drive, one DVD writer, and a low-end GPU. Actually, 520W is overkill for the components I listed in the first post.
    I guess I'm just a little bit upset because it died when voltages and frequencies were set to stock. I wasn't even overclocked or doing anything out of the ordinary.
    c[_]
    Nov 2002
    Alberta, Canada
    you didnt disconnect that drive while it was running did you?
    Try another cpu, and maybe a hotflash of the bios.
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Mentor
    Oct 2004
    Quote Originally Posted by STEvil
    I would never do such a thing.
    It's not the CPU. I'm using it on my Neo2 as I'm typing this so I know that can't be it. I also hot-flashed another chip with the shipping BIOS, popped it in the DFI, and nothing happens.
    I'll just refer to this as S.M.D.S. - Sudden Motherboard Death Syndrome.
    May 2004
    Perth, Western Australia
    you should take that out of your sig its probably jinxing you
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    Do Motherboard manf Actually test the mobos after there made?
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
    Sandoval
    Jun 2004
    ehn why cee
    did you try holding down insert as you press the reset button on the motherboard? i had the same problem, getting stuck at 3 lights on the motherboard.
    p.s. dang i wish the zippy worked with this board, i'm soooo itching to run vx up to 3.8
    i7 980x | corsair dominator 6x4 Gb | TJ07
    SLI GTX 580x2 | GT430 | rampage 3 | corsair AX1200
    LSI 9265 | OCZ vertex 128x4 raid0 | corsair c300 | hitachi 3tbx3 |
    blocks: cpu hk 3.0 | gpu aquacomputer 580x2 | mb ek re3 fc | ram bitspower galaxy
    pump: laing d5 x2 | res: koolance 452x2
    rad: TC 120.3 120.2 | scythe GTx5
    NASs: qnap 879 8x3tb | thecus N5200 2tbx5
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Quote Originally Posted by conrad.maranan
    Did You already find a solution ???
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Oct 2002
    London
    I wonder if this is what happened to the 2 x DFI reps over at the DFI forum??
    Their boards are dead too......but they cannot talk about it.
    Nov 2004
    On a crazy college campus! (Nash, TN)
    All I can say is - that's a bummer . . .
    We're sorry for your loss, sir. (insert cheezy hearse graphic)
    Want your news on the front page? Click here!
  18. #18
    Jan 2005
    The only thing I can think of is someone reported problems when the HDD was set to cable select vs. Master............or visa versa, cant remember, too early, but try both.
    Antec SX 1045Bll
    OCZ 520 Adj. Powerstream PSU
    A64 4000+ San Diego @ 2.8Ghz
    XP-90 w/92mm Vantec Tornado
    DFI LanParty nF4 SLi-DR
    4x512 GSkill PC4400LE
    HTT255x11 3xHT DDR510 2.5-3-3-11 1:1
    NEC3500 16X DVD +/- RW
    BFG 7800GTX OC
    3DMark01
    My RIGS
  19. #19
    Xtreme Mentor
    Jul 2004
    Ontario
    Quote Originally Posted by bito
    What is this about not being able to talk about it? And why not? If something is up with these boards we all have a right to know regardless of if the info is good or not.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  20. #20
    Jan 2005
    AMD factory
    Please report here the offical statement from DFI............
    Previous system:
  21. #21
    Xtreme Mentor
    Oct 2004
    Holding INSERT down while rebooting was one of the first things I did in order to boot into BIOS Safe Mode. It didn't work. I read the post from AG on DFI-Street several days ago and how his board also experienced S.M.D.S. but can not speak of it. I did find it somewhat strange that DFI would refrain him from disclosing information regarding his problem.
  22. #22
    Jan 2005
    AMD factory
    So what about the situation? Do we have here a secret problem hidden by DFI which explodes sometimes like a time bomb and kills some boards ???
    Previous system:
  23. #23
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    What bios was you using.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
  24. #24
    Jan 2005
    Quote Originally Posted by bigtoe
    Sorry to butt in, but which one is the best? I'm using 1/25 and having problems overclocking.
    Antec SX 1045Bll
    BFG 7800GTX OC
    3DMark01
    My RIGS
  25. #25
    Jan 2005
    AMD factory
    Quote Originally Posted by Lidocaine
    Latest is 209 and before was 201 - both should fix a lot of problems, try it.
    Previous system:
