Hi,
I just got my a8n-sli mtb last week and started to test it out abour 4 days ago.
Specs as followed:
fx-53
pc power and cooling turbo cool 510 deluxe (20 pin) (a 24 pin psu is comming my way next month)
2xraptor 74gig raid 0
ati 4 mb vga pci card (still waiting for pcie cards)
1x Audigy 2 zs
1x xp-90
2x512mb ocz pc 3200 rev 2 platinum TCCD chips
Now for now I am running at 12*208 wich give me 2500mhz with 2-2-2-10 timmings and auto for the voltage in the bios with 4x htt.
System is fully stable with prime 95 over 20hrs straight with no errors.
Now I want to add more bandwith so I try 10*240 with ram at 2.5-3-3-10, 3x or 4 x htt, cpu voltage (tried auto all the way up to 1.65 in bios) my ram voltage is at 2.85v and then when it arrives to boot on my hard disk array the system freezes (so I never get into a working OS and then usuallay after that I go back to stock settings and my OS is corrupted etc... so I have to reinstalled. I tried that on the nvidia on chip controller as well as on the onboard silicon image controller using sata 1&2 and also 3&4. Cause I remember that on my msi neo 2 board the locks were not on the sata port 1&2.
So I think there is a major problem with SATA lock on this board(maybe its only my board, luck of the draw etc..)
What do you think, I saw people doing 280htt. Were they using Pata drives??
BTW I also checked ntune when I am at 12*208 and the pci is at 33.33 mhz. And also the silicon image controller is suppose to be able to run at 33-66mhz so if there were no pci lock, that controller should still work if the pci bus is overclocked. So maybe this is due to my vga pci card or sound card??
LMK
Any suggestions anyone??
Mcklain
I should really trade this one down with someone's cheaper CPU+$$$ so I can test things with less suspense
