The DDR600 512LA Package.
Testing Environment
K8 939 3000+ (0.09)
G-Skill TCCD LA 256MBX2 2.85V
K8N Neo4 Platinum
GeForce 6200
TEAC 512EB
Delta 300W
DDR682 CL3 4-4-8 Testing Report
Booting Screencut
Memtest 1.40, can not judge the NForce4 chipset.Maybe 1.40 edition Later
CPU 342X9=2728Mhz,DDR682 CL3 4-4-8 1T,PASS 4 Cycle
The memory brandwishis is used 2T Command Environment.
CPU 342X9=2728Mhz,DDR682 CL3 4-4-8 2T
If someone has any question,Please do the test by yourself.And we can compare the difference between 1T and 2T.Some Motherboard is more strong ,others are not.
In Windows XP environment. It is in the â1Tâ Command.
When we check this situation,we can find that it has difference 300MB/S of brandwish.
In the Windows2003 environment, it can run DDR720.Because my CPU is not veryspowerful. I slow down the CPU MULTIPULER. It is the reason of low brandwish.
In the Force3,MSI K8N NEO2 testing report
Overclocking is not the AMD.Motherboard ,promise cpec.
CPU&Motherboard can access 200MHZ,RAM access 300MHZ
Like Msi_NEO2, 2/3 can pass 300MHZ.
1/3 can not pass 300 MHZ If we make the RAM of pass DDR600,it will be error situation in this Motherboard.
In this high MHZ, It must depend the CPU,MOTHERBOARD,RAM.
All of three equipment are powerful, It can pass the related testing tools.
As I know,DDR600 is the limited item in the market.
NOTE:Next test Nvidia GeForce 6600GT AGP,coming soon
I was just scrolling through here one last time before I pass out for the night and I had to double take at this thread. Those are some amazing clocks you have on that ram. Keep up the good work
but soon im getting adsl!
A64 has a low latency memory controller, you really need to be running 2.5-3-3 or tighter to get the best from it...and the best way to check is Everest Write or sandra unbuffered.
