Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 167
Thread: TCCD and high voltage mystery explained
    Nov 2002
    california or chicago
    Alright after a few in the lab we figured out the awe inspiring mystery of TCCDs that do well with higher voltages
    It appears that samsung made some minor die revisions and that newer production chips do perform better with high voltages
    I pulled about 20 current production OCZ-PC -3200 plat rev 2 and put the booster to them , from 2.8 to 3.1 volts showed no peformance improvement
    from 3.1-3.6 we were able to run between 466 and 480 at 2-2-2 memtest stable and 510 and 550 2-3-3 memtest stable , with a fan running over the modules
    These are current production parts and it seems that we have been shipping these chips to retailers for about 2 weeks
    keep in mind we only saw a diference at 3.1 volts and above ,
    I would guess most TCCD products produced in the past 3-4 weeks should respond the same .. but thats a guess based on initial testing
    oh yeah , heres a quickie screenshot at 3.3 volts
    OCZ employee and proud of it.
    If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
    I am overclocked!
    "Posted on Mar 30, 2005 at 1:35 AM by StormGod
    In soviet Russia memory overvolts you! "
    Worst overclocker evar!!
    Oct 2003
    Harrisburg, PA
    sounds good,
    do these sticks clock any higher at 2.5-3-3 with 3.4v? could we possibly see 320 1:1 2.5-3-3 with high voltage?
    I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
    Nov 2002
    I have not had time to play that in depth , but I would bet that with higher voltages they do better at all timings.
    I am overclocked!
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    You scared me there for a second, I thought that was 1mb super pi
    You guys at OCZ are too much, keep it up
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
    May 2004
    Montreal
    Thank you for solving the TCCD mistery Ryan
    Are the late production OCZ TCCD the ones with the new OCZ badge on the HS ?
    The HS on mine are just the regular OCZ stamped units.
    Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
    Evga GTX285, Raptor 150GB, Corsair HX620
    Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
    Win Vista Premium X64
    Nov 2002
    Just trying to post up a quicky .... no time for real benchmarking in my busy day
    I am overclocked!
    Nov 2002
    Its hard to tell when exactly samsung changed the die , I do know the chips were using to build now are the same batch we have been using for 3 weeks at least.
    I am overclocked!
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    Anyways to get a 1gb set of this memory with the newer dies?
    id gladly pump 3.4v~ to get 280(560ddr) cas 2.5
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by ryanpgroovy
    What is the ram that Tony mentioned that does 2-2-2 at 260mhz? was that just a new tccd that got lucky? Or is there some serious brewing in the ocz LAb?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    wow thx a lot for soending so much time on solcing this riddle!
    id recommend you to find out what chips respond well to high vdimm and put a new sticker on that ram
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    so better wait a week or two so all new ram is new samsung die
    what ram mostly likely then ?
    mushkin/ocz/gskill ?
    i really want high voltage tccd cause i have 3.3vdimm available on my DFI NFII
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    Nov 2002
    The betas tony have are not TCCD ....
    hopefully people will buy lots of ddr boosters with all this new voltage lovin .....
    I am overclocked!
    Xtreme Guru
    Jul 2004
    [QUOTE=ryanpgroovy]The betas tony have are not TCCD ....
    A new mystery ic that isn't TCCD that does 260mhz+ at 2-2-2. Everyone get your checkbooks ready!
    c[_]
    Nov 2002
    Alberta, Canada
    heh.. wonder if they have another "shift point" higher up?
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    damn i smell a big xmas surprise from OCZ
    DDR 600 2-2-2-5/11 3.3Vdimm TCCD OWNAGE
    and wake up with PC2100 nanya ram LOL
    XS Local
    Dec 2001
    Have you tryed better cooling on these?
    IMHO i would like to see some Heatsinks, water cooling possibly?
    my EB burns me when i use 3.0v and testing when memtest last night the heater in the house came on cuz its cold in calif at night this week, and seconds after i started getting errors (it was on the 34th run of test5) so it was heat related im 99% sure.
    i would like to pull the spreaders off and add some sinks or something else, but i wouldnt wanna kill the warranty if i havent allready by excideing the voltages..
    3dmark01 3dmark05
    Heatware
    c[_]
    Nov 2002
    Alberta, Canada
    use a fan.
  18. #18
    Oct 2003
    USA /okla
    if I could get some 1:1 DDR 600 stable ram at 2-2-2-5-T1 I would spend 400.00 on a pair without blinking. I wonder what my OCZ 3700EB would be worth if this happens??
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
  19. #19
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by Dissolved
    Maybe OCZ should make a new heatspreader for this new High voltage ram. Maybe something with fins that dissipates heat better? or maybe a windtunnel design that surrounds the dimms with a fan at the top?
  20. #20
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    damn, so can we say yet this stuff is officially better that bh-5? i think so.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
  21. #21
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by WeStSiDePLaYa
    As soon as my mushkin comes, I'm putting the BH5 on Ebay before this info gets leaked onto every forum.
  22. #22
    XS Local
    Dec 2001
    Quote Originally Posted by STEvil
    use a fan.
    common sense yes, But even at stock speeds at 2.8v they get pretty warm in a cold room in the open air.
    What im Saying is, From what ive seen, memory is getting more power hungry and Might benifit from better Cooling Support.
    Problem is tho, memory Dimms are so close together heatsinks make this impossible.
    Im on my DFI, i use dimms 1 & 3 so i have a 1/2" area between the memory dimms to allow me to do something. Fan is OK, but fans wont truly disspate all the heat from the memory..
    3dmark01 3dmark05
    Heatware
  23. #23
    Jun 2004
    well i know i have good airflow and i get a 80mm fan right over my dimms and my ram stays pretty chilly.
    but wow, i really want to get some of this BH-5 killers in my rig.
    Specs
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    Audio Setup
  24. #24
    XS News
    Aug 2004
    Sweden
    I have been trying mine up to 3.8 Volt, after that computer crash.
    From what i notice is that Cas2 will gain most of the boost from higher volt.
    ~3.5Volt seems to give most boost at Cas2.
    Cas 2.5 runs best at 3.1volt.
    Cas 3 dont like above over 3.0 volt.
    I think it is this way, have only noticed after messing with a booster.
    Everything extra is bad!
  25. #25
    Oct 2004
    What a wonderful time to be building a new comp
