mobo: MSK k8n neo2 1.3b6 beta bios
CPU : 3500+ 90nm s939
Cooling : vapo LS
OCZ DDR booster 3.7v
Cooling : vapo LS
Nice. It seems the problems with burning out A64 mem controller from high VDIMM are long gone.
DFI LP LT X38-T2R
Intel Core 2 Quad Q9450
Thermalright Ultra-120 eXtreme
2x2GB OCZ Reaper DDR2 PC8500
eVGA 9800 GX2
WD Raptor X 150GB
PCP&P 750W Silencer
CM Stacker 830 SE
now that's what i call speed!! it's the almighty 2-2-2-x
which voltage!?
/// edit ///
WTF??! 3.7v !!! :banana4:
OCing with Arabian Style
i seem to remember macci running at 4.0v pushing for 310mhz+ with some bh-5.
All along the watchtower the watchmen watch the eternal return.
Real nice!!
Can you post some bh-5 vs gskill results?
then each at its max freq.
Im about to have 3x BH-5 kits (2x512mb and 1x1g kits) and was wondering if I should get some gskill..
thanks in advance
Ísland best :banana: heimi!
Originally Posted by Arnar
I think that is totally different story, You can't just do it for 3.7v every day
but you can have samsung TCCD chip play 2.6v ddr550 every day.
Hehe.. but cant you use 3.5v on BH-5 for every day?
It would though be nice to see 250 BH-5 (2225) vs gskill at 300
And have multiplier set so the cpu is at the sem freq
Arnar, I can be very sure that
DDR500 2-2-2-5 is much much worse than TCCD running at ddr600 2.5-3-3-x(in terms of normal badwidth efficiency)
And the voltage for BH-5 running ddr500 is around 3.1~3.25v while TCCD only needs about 2.65v~2.75v to run DDR600(256mb x2 dual channel please)
Ok, I was just looking for something to make up my mind wether to get Gskill ram.. since I recently bought a whole lot of BH-5 (3kits)
Voltages on the RAM doesnt matter ( I also have OCZ DDR Booster ).. just that they could live 24/7 on them ( or just couple of hours a day ) so I would be very thankfull if you could do that
ya I did that earlier already, please check out here:
http://www.xtremesystems.org/forums/...ad.php?t=43710
you can see those results from TCCD doing over ddr600(at least).
compare with this bh5 done for ddr560 2-2-2-5, especially TCCD on ddr611(fsb 305)
has got better result 8543mb/s than bh5 though.
ok thanks.. and would the results be the same for 3dmark01 also?
Very nice Kev
I love seeing those 8xxxMB/s Sandra screens.
Less is more.
Very nice........What about unbuffered Sandra with TCCD and BH-5 at their maxed frequency?......
INTEL PWA FOR EVER
Dr. Who my arss...
"TCCD only needs about 2.65v~2.75v to run DDR600(256mb x2 dual channel please)"
but at 3-4-4-8 timings which would cancel out. dont ever use worse than 2.5-3-3-7 timings, the super high latency will kill performance, esp with a64s
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
as pointed out buffered sandra is not a huge deal, it tells us something but unbuffered and the ddr500 2,2,2,5 vs ddr600 2.5,3,3,7 won't be that far apart i wouldn't think. Also wanna see 3dmark results to show general performance.
another thing is, jsut cos the tccd will run high on lower voltage, doesn't make that everyday use and bh-5 not. simply put there are a shedload of people that have run up to 3.5v for long periods of time and not had a stick die. its about running voltage that those memory chips can handle, tccd likes less voltage, that doesn't make runnning at 2.75v inherantly better. tbh i'd ru n3.7v without question all day long without caring. just not got a chip/board combo that wants to run high enough fsb to warrant that at the moment,
also, ath 64 deaths, other than that basically initial thread what, almost a year ago where only a few people actually had deaths and almost entirely all of them were on chaintech(early boards) or modded vdimm shuttle boards where almost all of them died from fluctuations, basically unsafe mod. Since then i ain't heard anything about dying ath 64's. Sure a few die here or there, no product in any history doesn't have some faulty components. My first 3200+ back last, sept? august? i ran at 3.3v for like 7 months straight before it was sold, to my m8, with the board, and its been at the same since then.
Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
Lets see a 3DMark2001 Lobby Hi test then?DDR500 2-2-2-5 is much much worse than TCCD running at ddr600 2.5-3-3-x
12x250 1:1 2-2-2-5 vs. 10x300 1:1 2.5-3-3-x ?
edit: lets add 272x11 1:1 2-2-2-5 there too since you obviously got RAM capable of it
Can you do one? Thx
That is a very nice score. Cant wait for those benches
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
Sorry Macci, I am talking about normal bandwidth. I certainly understand what your point is.Originally Posted by macci
ya Iwill definitely do that when I got time.Originally Posted by µnrealneo²
need a spare HD to install win2k
why win2k ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
because for performance, generally:Originally Posted by TEDY
amd + win2k
intel + winxp
Gigabyte GA-X58A-UD3R rev 2.0
Intel Core i7 950
2x MSI N460GTX Cyclone 768D5/OC in SLI
Corsair 6GB (3x2gb) DDR3 1600mhz C7
Silverstone ST75F-P 750w psu
Samsung F3 1TB
MY HEATWARE
As the advice from Macci,(run 3d mark 2001se, game 3 high details only);please see here
Mobo: MSI k8n neo2 Bios: 1.3b6
RAM: 1.Mushkin PC 3500 Level II BH-5, 2x 256mb DC kit
2.GSkill TCCD DDR550 2.5-3-3-7, 2x256mb DC kit
OS: Windows 2000 SP4
CPU AMD s939 3500+ 90nm
Power: OCZ power stream 520W
HD: Maxtor 6E040L0 IDE
Let's see those two set of RAM:
1. BH-5 273x11 2-2-2-5:
2.TCCD 300x10; 2.5-3-3-6:
It shows that results are really close to each other.
Therefore, I think there is no need to do BH-5 at 12x250, 2-2-2-5 right?
Thank you everyone.
sell me these mushkin
what volts on the BH5?
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
