LP UT 250GB with 512MB TCCD 1T DDR 600 BIOS Setup Example
LP UT NF3 250GB + TCCD 512MB , 1T DDR600 BIOS Setup Example
1 . Genie BIOS Setup Page
CPU tested using K8 754 , 3700+ CPU , running 300 * 8
Besides
CPU Multipliers
FSB Frequency
CPU Voltage set to what you want
DRAM Voltage set to 2.8V
All others option is ok with Auto or Defualt
2 . DRAM Setup Page
DRAM Module tested is OCZ TCCD 512MB
With only one module , it's recommended to installed in DIMM1 , DRAM timing set as below
With two modules , it's recommended to installed in DIMM1/2 , DRAM timing set as below
Due to K8 has intergrated memory controller , and each TCCD module will not perform as the same as the one I got ...
Not all the similiar setup can running at DDR600 using 1T , it's depend on the CPU and DRAM you have ...
If such bios configuration is not stable in your system setup ...
Try
1 . Increase Trp to 4
2 . Raise DRAM to 2.9V or above , and try DRAM Drive Strength 1 first no matter you have 1 or 2 TCCD 512MB , if it's not stable , try 2 , 3/4 will not be stable once DRAM voltage is too high for TCCD
If it's still not stable , in order to keep the best performance , it's recommend to keep the memory timing(or you can even try to decrease Trcd to 3) and decrease the FSB frequency to see what's the highest stable limit of your setup , it will maintain the best peformance
Setup up to 2T for running at DDR600 is not a good idea ...
Above information is FYI ...
Ps : Some TCCD 512MB Module perform better to set Skew Value to 64 using 1 DIMM, set to 128 using using 2 DIM ... You need to try it ...
- You may not post replies
- You may not edit your posts
Forum Rules
