Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 103
Thread: AMD Next Generation Motherboards @ Computex 2011
    Live Long And Overclock
    Sep 2004
    ASUS
    Asus Sabretooth 990FX (AM3+)
    Asus M5A99X EVO AM3+
    Entire range of new Asus AMD motherboards: http://i.imgur.com/c3wmy.jpg
    ASROCK
    ASRock 990FX Extreme4 (AM3+)
    ASRock A75 Extreme6 (FM1)
    ECS
    ECS A990FXM-A (AM3+)
    ECS A75-A (FM1)
    GIGABYTE
    Gigabyte GA-990FXA-UD7
    Gigabyte GA-990FX-UD5 (AM3+)
    (No Picture Yet)
    Jetway
    Jetway Magic Pro 990X
    MSI
    MSI 990FXA-GD80 (AM3+)
    More will be posted as information is available...
    Credit to OverclockZone for some of the exclusive information regarding these boards.
    Jul 2009
    England
    Nice, that ecs looks great! I like the tall 8 pin connector, debug LED position, cmos reset on the rear i/o, looks like it's got it all.
    In fact they all look good apart from the msi which looks like a smurf digested a CHIV
    My pot is bigger than your pot
    WHAU!!!!
    May 2004
    Aland Islands, Finland
    Love the extended 8-pin socket on the ECS A990FXM-A
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Jan 2011
    145.21.4.???
    WTF? Hard to believe the mid-range Llano will accompany with such an awesome board, QuadXFire!
    Jul 2009
    England
    Quote Originally Posted by undone View Post
    Yeah, with 2 cards dual gpu cards. There are 770 asrock boards that could do that
    WHAU!!!!
    Jan 2009
    UK
    All of those boards are minging except for the MSI one!
    I'll be sticking to my Crosshair 4 Extreme I think.
    Feb 2006
    Vienna, Austria
    according to asrock A75 Chipset has native USB3.0 x4 ?!?!
    BTW: FM1 and AM3+ seem to use the same retention brackets
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    May 2010
    Sweden
    Well the MSI one will be 990FXA-GD80
    http://www.xtremesystems.org/forums/...d.php?t=271161
    JETWAY seems to be working on one too...
    http://www.xtremesystems.org/forums/...&postcount=443
    My stuff
    PhII x6 1055T @ 4.2GHz | Corsair H50 + Scythe SL12SH PnP | Asus Crosshair IV F | 4GB Dominator 1600 CL8 | Corsair HX520W | CM HAF932 | Dell 2405FPW | Creative 5.1 THX |
    Apr 2006
    Quote Originally Posted by El Gappo View Post
    +1
    They also seem to have a PATA connector as well.
    I wonder why the retention bracket is split on some boards ? Guess they figure all the good coolers require you to remove it anyway ?
    Jul 2009
    England
    Quote Originally Posted by Kobaltrock View Post
    +1
    I kinda like that too, come across stock coolers with way to much bubblegum type paste on before now and it's near impossible to take the cooler off without pulling the cpu out, with it now split like that you could slide it off no probs
    Here's to hoping the bios is good and it isn't priced to high like the p67 one. If its around $100 with a half decent bios ( with more than 4 ram timings ) I'd hit it up for a daily rig.
    WHAU!!!!
    I am Xtreme
    Dec 2007
    wow, is this the first ever ECS board for amd? i really cant remember the last time they made one.
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
    Aug 2004
    Sweden
    Quote Originally Posted by generics_user View Post
    Yes, USB 3 is integrated.
    It's the newer version:
    Quote Originally Posted by Manicdan View Post
    They seem to have made several models, but I haven't seen them being used much:
    http://tinyurl.com/644hw6y
    Those gray colored boards looks great!
    Oct 2005
    Melbourne, Australia
    Couldn't someone just cut off the side plastic pieces of a current bracket if they wanted that style bracket?
    Jan 2008
    The ECS board loooks really good, and still using a PATA DVD RW, looks like the one I think I would go for if it gets UK distribution
    Apr 2011
    Asrock 990FX Extreme4 seems to use PATA as well.
    Sep 2009
    Aubrey, Texas
    I think I just busted a nut over both ASUS boards! WoW! I have been waiting for them to spit out an AMD Sabretooth for a while.
    i5 2500K@ 4.5ghz turbo
    TT Spin-Q
    ASUS P8P67 EVOs
    4GB (2 x 2) Ocz Platinums @ 1600mhz
    Diamond 6970 2gb Catalyst 11.1
    2 X 1.5tb WD Drives
    LG DVD burner
    Win7 64 bit Home Premium
    Corsair HX 850w
    In a slightly modified Antec 1200
    Xtreme Cruncher
    Apr 2008
    Ohio
    second this on both parts. best looking ECS board i've seen too. Love the smurf comment
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
  18. #18
    I am Xtreme
    Dec 2008
    France
    ECS board looks the best, which is quite a shocking thing to say...
    Donate to XS forums
  19. #19
    Oct 2005
    Looks like ECS is stepping up their game.
  20. #20
    Aug 2004
    Sweden
    Come on, it looks great but it isn't much different from the older models...
    A890GXM-A2:
    A990FXM-A:
  21. #21
    Xtreme Addict Chrono Detector's Avatar
    May 2009
    Most of them look nice, I just wish Gigabyte would reveal theirs already.
    AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
  22. #22
    May 2007
    Colorado Springs
    On the ECS... to the left of the ram... it looks like a little beeper thingamabob. So you'll get the beep during POST.
    I have one on my hardware raid card... I couldn't LIVE anymore without beep on booting. But I'll probably retire this RAID card soon since it is only PCIe x1... so if a motherboard company has that little doohicky... I'm all for it.
    FX-8350, Powercolor ATI R9 290X LCS, OCZ Vertex 4, Crosshair V Forumula-Z, AMD Radeon DDR3-2133 2x8Gb, Corsair HX1000W, Thermaltake Xaser VI, Xonar D2X, Water Cooling 140.3
  23. #23
    Jul 2009
    England
    Quote Originally Posted by keithlm View Post
    You can plug a speaker into pretty much any motherboard. Can't remember a board that didn't have a speaker plug.
    WHAU!!!!
  24. #24
    XIP
    Nov 2004
    NYC
    Hope the bios will be as pretty as the board
    Time to prepare for the new platform
  25. #25
    Apr 2006
    Quote Originally Posted by Chrono Detector View Post
    I think the only ones that we have no idea about is Biostar & Gigabyte.
    Will Biostar continue with their 'bug zapper' LEDs design, will they have a blood red board, or will they chicken out, and go with the brown design?
    I somehow doubt Gigabyte will do anything special either.
    Mats, ahh, so that is why they did that. I guess that means, that if you want to mod your old AM3 board, just get out the saw, and you to can be the proud owner of a AM3+ style retention bracket, with a bonus 'cooling factor' thrown in!
    Quote Originally Posted by Dumo View Post
    Yeah, they will go old school, and have a bunch of jumpers on the board!
