Just got this today... thought might as well post here too and share with you guys as well. :0
ASRock > Products > Z68 Extreme4
Box
Contents
Mobo
Box
Contents
Mobo
Finally a Z68 board with Displayport and max res. 2560 x 1600
Intel FDI is limited to 1920 x 1200 (1080P) if your board only have HDMI or DVI ports, Z68 boards don't support dual-link DVI
Live to Mod.. Mod to Live!
Just got back from work and already whacked everything onboard liao, now time for the more impt things in life... yes, time for supper 1st.
Left out these few shots.
LGA 775/1155 mounting holes
Full house CPU socket - no skimping on components like some brands
Everything's new again - though they say Z68 is same old same old
Speaking of UEFI, must post this screenshot to make all other mobo owners envious cos Asrock implements F12 screen captures even on their Extreme4 series.
No need to spend loads of money on the high end model to enjoy sharing screenshots.
I'm yet to be convinced of Z68.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
Two more chokes than P67 Extreme4
Foxconn BloodRAGE GTI|i7 920(200x21)|6GB Kingston HyperX 1866 CL9(1600 6-7-6)|GTX 470 SLI|WD300HLFS|CM Silent Pro M850
AsRock X58 Extreme3|i7 920(212x19)|6GB Kingston HyperX 1866 CL9(1700 7-7-7)|GTX 460 768 MB|WD300HLFS|Audigy|Chieftec CFT-650-14C
AsRock P67 Extreme4|i7-2500K(45x100)|2x2 HyperX Genesis 1600(1866 9-10-9)|2xGTX 460 768 MB|RAID1 2x1TB Т7K1000.C + WD6401AALS|CM Silent Pro 600
I noticed that the new Giga Z-68 boards (ud7/5/4) didn't have video outputs? I like the idea of being able to use built in video for back up or if you don't want/need a dedicated video card. I like my current P67 ASRock so I'm looking foward to availability of this model here in the states as well as other Z-68 offerings.
Ryzen 9 on the test bench... Sometimes older generation/tech as well.
is there suppose to be a connection?
It looks amazingly nice tho
Ivy Bridge is what you want, Z68 is such a small upgrade it's not worth the price if you already have a high end X58 system.
PCI-e 3.0 will be the next big thing.
This is a nice board though, but nothing to be "jealous" over like you state.
Clear CMOS button with bright red LED at the I/O plate, anyone finds this useful?
Lucid Virtu - very early days as can be seen from the apps supported
"Prowler"
Cooling:
Studying the effects of Lucid Virtu on 3D11 P scores
Unlocked 6950@stock clocks on Asrock Z68 E4, latest available Lucid Virtu 1.1.101.16618 installed
Virtu not installed
Virtu installed but not enabled
Virtu installed and enabled
Interesting findings indeed, looks like the Lucid team has done very well with the latest version with regards to 3D11 P scores.
Intel i5 2500k @ 4.2 Ghz
TRUE 120 Extreme @ Scythe S-FLEX 1600rpm
8GB (2x4GB) G.Skill RipjawsX PC12800 CL8 1.5V
AsRock Z68 Extreme4
2x 6950@70 2GB CrossfireX
Dell U2711
OCZ Vertex 2E 60GB SSD
Samsung F3 500gb HDD
Silverstone FT-02B-W
AsRock Z68 Extreme4
Dell U2711
>MacClipper
Do you use linux or could boot Z68 system from one of the linux live-cd editions?
I'm having one small request, it takes no more than half a minute.
...and what's better LAN controller: BCM57781 by Broadcom or TRL8111E by Realtek?
Introducing Lucid Virtu "d-Mode" for Z68 motherboards with or without video outputs...
http://download.asrock.com/manual/Vi...e4/English.pdf3.2 d-Mode
d-Mode is provided for demanding 3D gamers to achieve uncompromised 3D performance of discrete GPU
installed in the system. In this mode, Virtu allows user to utilize Intel special features such as trascoding, while
display is connected to discrete GPU.
Note: We recommend you use d-Mode for better 3D performance unless you use Intel Insider feature or the
power saving i-Mode.
To use Lucid VIRTU solution in d-Mode, display must be connected to discrete GPU installed in the system.
Nice for everyone with discrete graphics or/and big displays with resolutions greater than 1080p
Function should work on every Z68 board with Lucid Virtu license -AOC
Nice ! Thanks MacClipper
The heatpipe looks VERY close to the EPS connector, what's the clearance like? And what's with the V8 branding? It's not on the box or part of the model number...
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
Just bought this exact mobo to go alongside the following:
i5 2500k Retail
8GB (2x4GB) G.Skill RipjawsX PC12800 CL8 1.5v
Silverstone FT-02
Another AMD (Asus) HD6950 2GB reference for crossfire
I am going to reuse the other bits from my current system...
It should be with me today too!
AsRock Z68 Extreme4
Dell U2711
