This is a mostly picture journey on a cooling upgrade that has been desired for some time. My wife finally gave me the green light... So foolish of her.
Something you should know
I do things a little differently. I tend to prefer function over aesthetics. My worklogs are usually only one or two days long (because I am too excited to use the new system). I test products and setups even when they are not optimal, it's my curiosity that kills me! For instance, I'm the kind of guy that would put a water block on a water block, or build a TEC sandwich, or build a chiller out of a mini fridge. I'm questionable at times! but enough about me...
Quick facts about the current build:
- the guts of this rig are sigged below \/
- i am upgrading the RAM, adding a GPU, the rest is all cooling
- currently there are two loops. CPU, GPU
- Existing build has dual 240 magicool extremes, and one Danger Den 240GTS. (a total of THREE 240mm rads, spread across a video and CPU loop)
- Using and combining existing Dual pumps, one XSPC pump bay res. One panworld/blueline PX40 (~480GPH @ ~45watts ) AC/120 pump. More info on that pump can be found here.
- existing EK copper water block, adding a second block & a second 5870.
- it uses high speed 4000rpm deltas. if you think that those would be loud, you would be thinking correctly.
Desired outcome / goals:
-> a bump in graphics for my flight sims and eyefinity
-> much better cooling with reasonably quiet operation (I fold 24x7)
-> a clean looking cooling loop (bling not required but acceptable)
The New stuff:
- Adding a metric ton of enzotech, BP, feser, and thermochill fittings
- replacing all of the cloudy tygon tubing with clear Primochill LRT
- two thermochill PA 120.1's (on sale at sidewinders BTW)
- adding another 5870
- adding another EK fullcover copper block with black backplate(all rev 1 stuff - hard to find these days)
- adding five low speed yate loon fans
- upgrading to 16GB of RAM (mainly for my virtual machines)
- adding an HP blueray drive (shhhh the wife doesn't know about that one)
and now it's time for pr0n
