Hello,
I found damage on my original EK Supreme HF nickel block, and took it to the store for a replacement.
Unfortunately, it wasn't until after the 90 minute train ride home that I decided to check the new block, and found that the bag containing the block (with the EK seal on it) was torn open. That, and I found the block base has stains on it when I opened the block to inspect it:
You can see the two horizantal lines (lining up with the jet plate) in the middle, and the stains towards the bottom end of the picture, on the channels.
The pink/green are just reflections in the block.
Should I use this block, or return it (again?)
Thanks,
Odai.
