I just started working tearing my computer apart today. All I have done so far is mount the harddrives to make enough room for the 240 radiator in the front of the case. When it is finished both radiators will be internal.
Build plans include:
both radiators internal (I will not be using a shroud on the 120 rad)
interior of case painted black
gpu is being take out of the loop
white tubing
Gentle typhoon 1850 rpm fans
sleeving
new gpu coming soon
Completed:
[/URL]
Before:
Newly mounted drives:
Thread will be updated daily with pictures
comments and opinions are appreciated
Fillport:
Front 240:
Rear 120:
Everthing:
A couple coats of primer on top of the self etching primer.
Gentle Typhoons x 3 I loved these fans since the moment I took them out of the box they just feel quality and man are they quiet.
[/URL]
