Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: " Personal Review " HD 6990
    May 2009
    IND
    RIG
    26k @ 4.5 gh
    4 gb ram
    ud4
    tx-950
    SOFTWARE
    Win7 64
    CAT 10.4
    May 2009
    IND
    STOCK CLOCK 6990
    VANTAGE
    2011
    May 2009
    IND
    AVP
    WARHEAD
    May 2009
    IND
    LOST PLANET 2 ( As highest Possible )
    HEAVEN v2.5
    May 2009
    IND
    6990 @ 900 / 1350
    -Switch 1
    -Power Control Setting 0% ( Def )
    -FAN 50 %
    VANTAGE
    2011
    May 2009
    IND
    AVP
    WARHEAD
    May 2009
    IND
    last reserved
    Jun 2010
    Keep posting please! Wow 35k GPU score @830Mhz mine 5970 not even with 1000Mhz on core 1200 on men get to 35k. Nice mark.
    May 2009
    Switzerland
    What settings have you used on the vantage run and 3dmark11? i still find the vantage gpu score too low, or it's something with the driver or it's just cause i compare with my scores who was made with mipmap low, no AF, no AA.
    CPU: - I7 4930K (EK Supremacy )
    GPU: - 2x AMD HD7970 flashed GHZ bios ( EK Acetal Nickel Waterblock H2o)
    Motherboard: Asus x79 Deluxe
    RAM: G-skill Ares C9 2133mhz 16GB
    Main Storage: Samsung 840EVO 500GB / 2x Crucial RealSSD C300 Raid0
    May 2009
    IND
    Quote Originally Posted by armartins View Post
    thx, soon i'll try oc this card
    Quote Originally Posted by Lanek View Post
    all def setting :
    - 2011 P score
    - vantage P score
    Oct 2006
    You can go higher on stock voltage with the 6990. Don't be afraid. Push it!
    My 6990 and 6970 in Tri-Fire are both running at 975/1400 rock-stable on stock voltage.
    Waiting for a waterblock to have more fun.
    i7 3930k EK-Supreme HF - Asus Rampage IV X79 - QUAD-Fire: 4X Asus 7970 EK waterblocks - 4X4GB=16GB RipjawsZ 2400 CL9 - Crucial C300 128Gb M4 128Gb 2x Intel X25-M 160GB 3X Seagate 2TB - Mountain Mods Extended Ascension + Pedestal 24 - Dual-PSU: Antec HCP-1200 + Corsair AX850 - EyeFinity 3X 30'' LCD - Windows 7 64
    May 2009
    IND
    Quote Originally Posted by Levesque View Post
    975 on def switch bios ?
    May 2009
    IND
    more
    Jun 2010
    Another nice mark. Are CPU-Z voltage readings for Sandy Bridge processors bugged? 1.08v?
    Jan 2010
    damn beast scores
    Internal Watercooling Antec 900 Build Log*
    WC loop: Black ice extreme 240 radiator, XSPC 120 radiator, HK 3.0, D5 pump with Bitspower top, DD fillport, Primochill tubing, distilled + ptnuke
    Pink Floyd is #1
    Xtreme Memory Hoarder
    Mar 2010
    no he probably has a gigabyte board that is a b3 stepping as this seems to be a new problem even with cpuz 1.57
    XIP
    Nov 2004
    NYC
    Nice runs there Gaul
    You need to put more Mhz. on cpu though
  18. #18
    May 2009
    IND
    Quote Originally Posted by Dumo View Post
    ic, soon
  19. #19
    Oct 2004
    Australia
    yeah crank it up had my 6990 up to 985/1565 so far and she rocks. OCP starts to kick in around the 950 mark...
  20. #20
    Jun 2007
    Long Beach, CA
    Is there any voltage unlock yet for this card? I just pulled the trigger on my eK 6970 water block now waiting for the 6990 to come out..
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
  21. #21
    May 2009
    IND
    Quote Originally Posted by Lu(ky View Post
    yup ab 2.2 beta 1
  22. #22
    Oct 2006
    Here's my 6990+6970 Tri-Fire to compare to your results just for fun. I used the same clocks, same processor, same processor speed to be able to see the difference betwween 6990 alone and 6990+6970. Can't wait for my waterblock.
  23. #23
    Apr 2008
    nice scores Gaul, bib you notice that in 3d mark VANTAGE the card is buzzing but not in HEAVEN or the other game bechmarks?? is this normal or should i return my card ?
    iv only tested my 6990 in VANTAGE and HEAVEN .
  24. #24
    May 2009
    IND
    @ levesque = nice 4 share, edit u'r SS plz............
    @ quatto = u can post u'r heaven here with the same setting than we can see normal or not
  25. #25
    Apr 2008
    here you go :
    my VANTAGE GPU score is a little lower !!
