Wouldn't it be great to have a fully watercooled system in the beautiful Silverstone FT-02 with such a huge radiator as the Black Ice SR-1 560?
In this post, I will be describing what I am going through to get to that dream watercooling combination.
Photos & videos:
http://imgur.com/a/01aMs
Videos of the build fully assembled:
- Fully Watercooled FT-02 (SR-1 560, 100% EK, MCP35X, CH3F, 1090T, 5970)
- Fully Watercooled FT-02 - Noise Test
Personal story:
A few months ago I chose to get a Black Ice SR-1 560 to go with my Silverstone FT-02. I had no choice but to "mount" it externally, just sitting on top with screwed-on rubber feet and quick disconnects so as to be able to move the case and the radiator independently. That meant having the hoses go through a PCI slot via a G1/4" L-bracket and routed through the wide hole in the upper back. I found out the hard way that it just wasn't a viable solution as this PCI bracket leaked every time the hoses moved (unscrewing the fittings). I was so disgusted by this complete failure that I went back to 100% air-cooling. Only, the 5970 couldn't take it: an AC Accelero Xtreme wasn't able to cool it properly under load even with the 3 fans at 100%. I re-seated it twice, and every thermal pad was making proper contact, so I took it this Accelero wasn't optimized for the 90°-rotated design of the FT-02. I had to go back to liquid cooling, but after the bad experience I had, I definitely wasn't ready to go the external route again and settled with an internal GPU-only loop with a single 140mm radiator, very efficient (42°C on both GPUs under FurMark). That brought my confidence in LC back up and now that I sold my 980X, I'm moving to a cheap CH3F + 1090T system with enough money to go back to full LC (CPU, GPUs, MB) and most importantly, use my poor, abandoned 560 that cost me so much and is begging to dissipate heat. Of course, that meant modding the case, but I'm determined to succeed even though I couldn't find a story of somebody mounting a 560 in a FT-02, just the idea briefly mentioned back when this case was released.
Mounting problems:
From what I gathered up until now:
1. The SR-1 560 must be mounted at the bottom of the case, in place of the 3 180mm fans and their mounting brackets. Obiously, there's nowhere else to place it.
2. Once the fans removed, there is still no way to insert the radiator because of the ~1 cm-thick metal "bands" on each vertical edge, that support the side panel. It's not possible insert it diagonally either, since the hard-drive cage is in the way.
3. This radiator is *exactly* as long as the inside length (front to back metal panes) of the FT-02, so it is a super tight fit.
Modding:
There are 3 things to do in order to be able to insert the 560, one for each of the points above:
1. Remove the 3 bottom fans and their mounting brackets :
The fans are easy to remove. Their brackets, on the other hand, gave me a hard time: for each bracket, there are 4 clips in total, 2 on each side. One side is easy to unclip, while the other one seems to have its clips stuck to the external side of the bottom of the case. They have to be punched to be unstuck, and then unclipped, letting the bracket off the case.
2. Remove the hard drive cage:
There are 11 or 12 rivets to pop, including 4 in the front, which require to remove the skeleton of the case from its U-shaped shell. To do that, there are several screws attaching it to the skeleton, inside the case, they're easy to spot. Then, pop the rivets with a drill. 2 of them will have to be done diagonally as the drill is too close to the edge of the case but they do come out, eventually.
3. Remove the foam in the lower back of the case:
The radiator can now be inserted once rotated. One of the sides must then be pushed down so that the radiator is level with the floor of the case. This can't be done because the foam attached to the back of the case is too thick.
Removing it is the hardest job in the whole process. The glue Silverstone used is extremely strong. Attempting to remove it with fingers only, the foam comes off partially, but there's some foam left and most importantly, glue stuck to the wall.
I tried both warm water and nail polish remover with no luck. Eventually, I soaked the remains in warm water and dish soap so as to soften it, making it easier to peel it off with a spatula. There's a remaining layer of glue, very thin and not that sticky, but I simply couldn't get rid of it and the fact that it's even over the whole surface tells me that it was (and still is) there for good. There are now scratches and various marks but this trade-off is well worth it.
Status:
Extracted from one of the YouTube videos:
I just finished putting together my fully watercooled PC housed in a Silverstone FT-02B modded to accomodate a Black Ice SR-1 560 radiator, though with only 3 fans since the 5970 is 1.5cm too long.
Specifications:
- Motherboard: ASUS Crosshair III Formula
- CPU: AMD Phenom II 1090T (CCCBE CB 1022BPMW)
- RAM: Corsair Dominator GT 2000 MHz C8-8-8-24
- GPU: ATi Radeon HD5970
- Sound card: ASUS Xonar DX
- SSD (OS): Corsair F120
- HDD (storage): Hitachi 5K500.B 500 GB
- Media R/W: LG CH8LS10
- PSU: Be Quiet! Dark Power Pro P8 1000W
Watercooling equipment:
- Pump: Swiftech MCP35X (PWM controlled)
- Radiator: Black Ice SR-1 560
- Reservoir: XSPC Single Bay
- CPU waterblock: EK Supreme HF v2 - Acetal + nickel
- GPU waterblock: EK FC5970 - Acetal + copper (not nickel plated as bought before the other ones)
- Motherboard waterblock: EK FB ASUS CHIII - Acetal + nickel
- Radiator fans: NoiseBlocker BlackSilent Pro PK-3
- Exhaust fan: Scythe Gentle Typhoon AP-15
- Fan controller: Sunbeam Rheobus Extreme
- Fittings and adapters: TFC and BitsPower
Modding of the FT-02 detailed on XtremeSystems.org: http://www.xtremesystems.org/forums/....php?p=4743338
I am thrilled with the silence and excellent temperatures so far. With everything at stock under full stress load:
- CPU socket (Prime95 small FFT) : ~35°C (cores allegedly ~25°C)
- GPU cores (FurMark): ~35°C
- Northbridge (Prime95 small FFT): 30°C
- Southbridge (Prime95 small FFT): 31°C
Definitely worth all the money and time that went into this build!
