So I missed the boat on the TJ07 gold rush and am coming to the case after everyone and their dog has done a TJ07 project.
So you may all be sick of them by now but by god its a lovely case. I've had all sorts of cases in the past and do tend to spoil myself every now and then and go high, from old Coolermasters to big ass Lian-Li I've often bought the good stuff and then kept it for quite a while.
Which brings me to this build. Its a rebuild of my trusty old home computer, you know the one that you keep on upgrading, giving it new leases of life without changing the facade too much.
Over the years this one has been a XP1800+, an FX60 workstation, Q6600, Q9650, and i7 920. All with requisite motherboards, go faster stripes and more recently watercooling.
You may have seen pics of it, you may be an afficionado of the brand and feel I have committed sacreligeous acts on it in recent times but if not I'd like to introduce Mars, aka Bigjobbie.
Current Specs:
- Case: Coolermaster ATCS 201 (Circa £200/$250 in 2001)
- Mods: 120.2 Rad hole cut in the roof
- Mobo: DFI X58-T3EH6
- CPU: i7 920 D0
- Memory: 6GB Crucial Ballistix 1600
- Gfx: GTX460
- HDD: 160GB SSD, 250GB SATA, 80GB SATA
- Zalman ZM-MFC1 fan controller
- Radiator: Swiftech MCR220QP
- Fans: 2 x 120mm Redwings, 3 x 80mm Redwings
- CPU block: HK 3.0 LT
- GPU block: EK FC460 Nickel
- Reservoir/Pump: XSPC X2O 750 Bay Res Pump
- 8/11mm clear tubing
- Corsair 650W PSU
Plan is to move to a bigger case, this one is very cramped and I'm not getting the performance I know i can from the chip. So improve water setup, better temps, higher overclocks, mad leccy bills
This is what I picked up second hand to replace the CM201
The guy had kept her in pristine condition, only the smallest of blemishes that you wouldn't notice if you weren't poring over the finish lookin for them. (not that I would!)
Note the Disk bays? Obviously he had been a bit of a storage nut, he told me he was selling the case to get one with more space for disks! But apart from that a great guy and a great buy. (I do like silver cases)
So whats going to go in there you ask?
Well from the old rig I'll be recycling: i7-920/GTX460/DDR3/HDD's/MCR220QP/Zalman ZM-MFC1/CPU Block and GPU block!![]()
And adding this lot!
Thats:
- MCR320QP Radiator
- Laing DDC-1+ Ultra Pump
- XSPC DDC res top/Raditator stands(360+240)
- Silver kill coil
- 7/16" ID - 5/8" OD (11-16mm) Blue tubing/Nickel fittings
- Various power extenders.
Lets take a closer look:
Fittings "numnum" & Rad detail
To be continued
