Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: SandyBridge breaks 5.6 GHZ and does benches a bit below...
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    Hey,
    we have had rumors, reviews, availability announcements and everything about SandyBridge here, but not yet the current standings of clockspeeds. So here we go now 1 day after official release we see near 5.6 GHZ on that chip benching
    And there we have 5600 MHZ by Clunk cpuz valid - great job dude!!!
    I am a bit behind with currently 5595 MHZ but 2 cores
    2600K @ 5595 MHZ validation link
    I simply like SandyBridge for everything it can do - close to 13s pifast is insane as well as the 1m times you get out of it easy. I am pretty sure there is some more potential that can be unlocked. as we all know "internal pll overvoltage" was the only thing holding us back at the very beginning. I am pretty wondering that not a single mfc has checked what voltages are actually applied and if higher ones can get us even further - we need more infos about that function and how to use it properly, I am sure I have some more room on my chip to go for sub 13s pifast
    regards
    SoF
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Feb 2006
    Manchester, UK
    Good stuff, what will it do with 4/8?
    I am Xtreme
    Aug 2008
    way to go Sof
    what temps? did you adjust cpu inside windows? or all from bios?
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    nice! Im waiitng at chip and of course, love validation (my speciality with air :-) ) I can try it with air :-), Hope, it will be fun.
    ROG Power PCs - Intel and AMD
    Jan 2005
    East Blue
    Quote Originally Posted by Clunk View Post
    thanks! 4/8 on air ~5150 with ss ~5500
    Quote Originally Posted by Hondacity View Post
    way to go Sof
    thanks! idle ~-30 (maybe - no temp under zero readable ) booting out of the bios, no rog-connect, no evo-software
    Quote Originally Posted by FlanK3r View Post
    If you are lucky and brave 5.550 MHZ CPUz on air should be possible
    HWiNFO Author
    Apr 2006
    /dev/null
    Try this to monitor the system: www.hwinfo.com/beta/hw32_366_1087.zip
    Jan 2005
    East Blue
    shows -0°C when using singlestage also
    Xtreme Mentor
    Jun 2008
    France - Bx
    Kidz, don't try this @home !
    HWiNFO Author
    Apr 2006
    /dev/null
    What, where?
    Quote Originally Posted by SoF View Post
    Jan 2005
    East Blue
    Quote Originally Posted by Olivon View Post
    Quote Originally Posted by Mumak View Post
    What, where?
    monitoring --> sensor status we need reliable temp readings from the CPU below zero somehow
    HWiNFO Author
    Apr 2006
    /dev/null
    Plz post a screenshot
    Also try the HWiNFO32 link I sent and Sensors and post a screenshot.
    I am Xtreme
    Aug 2008
    i think intel never really invested with temp monitoring after celerons....
    remember celerons could read temps past-80c....
    since clarkdales the temp sensors didn't scale past -10c...
    Jan 2005
    East Blue
    it is with the version you posted to me screenshot a bit later - just shut down my rig.
    yeah temp reading is a disregarded point below zero.
    HWiNFO Author
    Apr 2006
    /dev/null
    Hah, even that would be a dream with Intel DTS.
    Most pre-Nehalem CPU DTS sensors are unusable below 50c. Here's a nice table about DTS precision and some other facts: http://www.hwinfo.com/forum/viewtopic.php?f=7&t=97
    That board should have other sensors as well, so HWiNFO32 might display them + some additional interesting values
    Jan 2005
    East Blue
    Hey Mumak here's your screen I just grabbed from my disk
    HWiNFO Author
    Apr 2006
    /dev/null
    Thx Indeed, all CPU thermal sensors are out of range..
    Hm, 43 W of CPU Package power is pretty low...
    A HWiNFO32 Summary page would be nicer than CPU-Z
    Jan 2005
    East Blue
    you seem to be closely related to hwinfo dev or sth? sum page I'll do that for you tomorrow
  18. #18
    Feb 2006
    Manchester, UK
    Managed a validation at 5600MHz, but it was screaming and very unstable, and only 1 core.
    http://valid.canardpc.com/show_oc.php?id=1587182
  19. #19
    Xtreme Mentor
    Jun 2008
    France - Bx
    Managed a validation at 5600MHz, but it was screaming and very unstable, and only 1 core. :rofl2:
    Nice clunk
  20. #20
    Jan 2005
    East Blue
    WOOOOHOOOOOOOOOOOOOOO VERY NICE
  21. #21
    Feb 2009
    He wrote it.
  22. #22
    Jan 2005
    East Blue
    Hehe I had that feeling - ok gonna help him even more then to get it running
  23. #23
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Sof 1/1 seems to push the chips a bit extra MHZ but are the benches better with 1/1 ? i wouldnt think so though?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  24. #24
    HWiNFO Author
    Apr 2006
    /dev/null
    Very close, it's my baby
    I'm going to release a new Beta in few hours with enahnced monitoring support of some SNB boards (ASUS, ASRock, GBT)..
  25. #25
    May 2005
    you know an intel forum exists to post stuff like this ????
    Quote Originally Posted by Movieman View Post
    Fanboyitis..
    Comes in two variations and both deadly.
    There's the green strain and the blue strain on CPU.. There's the red strain and the green strain on GPU..
