Results 1 to 24 of 24
Thread: Kingston SSDNow S100 16Gb $55 230MB/s
    Oct 2006
    Kirghudu, Cowjackingstan
    Question Kingston SSDNow S100 16Gb $55 230MB/s
    Anyone knows what controller it is based on? Any 4K IOps? I think this is potentially a contender for a top $/performance spot for 8-port RAID controller owners
    http://www.newegg.com/Product/Produc...82E16820139428
    Sony KDL40 // ASRock P67 Extreme4 1.40 // Core i5 2500K //
    G.Skill Ripjaws 1600 4x2Gb // HD6950 2GB // Intel Gigabit CT PCIe //
    M-Audio Delta 2496 // Crucial-M4 128Gb // Hitachi 2TB // TRUE-120 //
    Antec Quattro 850W // Antec 1200 // Win7 64 bit
    Xtreme Mentor
    Feb 2009
    I think it uses the JMF616. These drives are targted for non-PC applications.
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    i would like to see that device tested. that would make a awesome low cost array for onboards
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
    Oct 2006
    Quote Originally Posted by Computurd View Post
    I think it's the best $/MBPS deal. I don't care that it's only 16g. Potentially we are talking about 1840MB/s for only $440 Throw on 9240-8i and wow...
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    yeah the 4k random would tell the tale, but also the GC on that drive, how good it is would be key as well. outside of arrays it would be useless so it would have to have killer gc, like the idilinx. i still dont believe there is a better GC than the idilinx i dont care what device you speak of. hell the SF drives have horrible GC.
    Oct 2006
    All true... JMF controllers didn't shine in the past, but some review sites seem to be fond of 616 (e.g. Adata S596).
    Xtreme Mentor
    Feb 2009
    According to Anandtech the Kingston SSDNowV+100 (Toshiba T6UG1XBG) has really agressive GC, so it should therfore be really good for a raid array if you need sustained throughput. (Albiet at a price premium).
    I've looked everywhere for the 4k performance of the SSDNow S100 but can't find it. Kingston's web site calims "they’re ideal for non-PC applications from gaming and casinos to digital signage". They also use "commercial" grade NAND.
    I'd be a bit wary of them without knowing 4k or sustained throughtput performance.
    Oct 2006
    Quote Originally Posted by Ao1 View Post
    Aaaaand a sample drive is on its way Going to take one for the team, lol. Will report back on what it can do. If it's worthy - it's going to be in my ghetto raid. Highly suspicious on how many channels it has, and what kind of 4K RR it can do.
    Cheers.
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    excellent! this will be interesting
    how goes the 9240 btw? i am eagerly awaiting word on that, i need another controller, and for once someone other than me is gonna test
    Oct 2006
    Hey CT, 9240 will arrive probably late this/early next week. I won't have enough drives to see its limits, SF1222 drives were returned. With single S100 on its way and 2 X18-Ms I could potentially push 660MB/s. Anyway will be interesting how it stacks up vs 9260 w/o FP and SB850.
    Dec 2002
    How is it better than their 64GB version? Slightly higher read, nearly 2x writes, 4x capacity for just 2x the price. http://www.newegg.com/Product/Produc...82E16820139415 Missed a deal where they had them for $85. http://dealzon.com/deals/kingston-ssdnow-cheap
    Here's several more in the same price range. http://diskcompare.com/item/5489/
    Review of some of these low end ssds: http://www.techspot.com/review/313-budget-ssd-roundup/
    Oct 2006
    Quote Originally Posted by keiths View Post
    Side by side V100 is a better drive if taking capacity into consideration. For benchmarking, the one might argue that 2 of S100 are better than 1 V100. Theoretical 460MB/s sequential read vs 250. Now, consider the case when you want to build 8R0 array on a proper RAID controller and you will care about how much $ you will pay for throughput not necessarily $/Gb.
    Dec 2002
    Ah, OK. On that basis, I would think the OCZ Vertex Series OCZSSD2-1VTX30G is a better deal; performs quite a bit better & ~2x capacity at just +$12 more per drive, for two to four drive RAID setups. I'd imagine more disks would be hitting interface limitation, negating single drive performance?
    http://diskcompare.com/filter/?mis=&t=ssd&s=&p=100
    Oct 2006
    Vertex 2 is a better performer, yes. Not the original Barefoot one. I will know soon what kind of IOPs and sustained throughput S100 is capable of.
    SB850 can do over 1Gb/s. So 5-6 SATA2 SSD drives is fine. LSI 9260 with FP key and Areca 1880 can do over 2Gb/s.
    Dec 2002
    Ahem! Found a video: http://www.youtube.com/watch?v=S2qQVtdTHsw
    and the link in the clip is to a review with crystaldiskmark results: http://www.qk123.com/forum/thread-8198-1-1.html
    http://translate.google.com/translat...n&hl=&ie=UTF-8
    r/w
    seq: 201.3/78
    512k: 145.6/29.5
    4k: 11.49/6.6
    4k qd32: 27.85/7.329
    Oct 2006
    r/w
    seq: 201.3/78
    512k: 145.6/29.5
    4k: 11.49/6.6
    Great, thanks. The drive has very weak 4K numbers. The only use I could think of is to put Temp folder, browser cache and may be use it for ready boost Vertex 1 is a better drive.
    Dec 2002
    Quote Originally Posted by F@32 View Post
    I haven't been paying attention to hardware in awhile, I take it 4k is key for Windows 7 performance?
    Here's a review of the 30g vertex1 with crystaldiskmarks for single and 2x raid0:
  18. #18
    Oct 2006
    The reason 4K is a great OS drive performance indicator is that over 60% of file IO happen for files less than 64K in size. Big portion of those are around 4K in size. Thus rundom performance with that file size is very important. Right now Intel X-25M, RealSSD C300 and SF-1200 drivers offer the best 4K MB/s and IO/s. Sequential numbers are good for people who do image editing and audio/video recording/transcoding. Other than that they are not very important in a desktop environment.
    Note that if you read through this thread http://www.xtremesystems.org/forums/...d.php?t=260956 it is evident that even Win7 and most apps are lagging at utilizing amazing disk performance that current crop of SSDs have to offer.
    Thanks for the link, I had Vertex 1 in the past and compared S100 scores to my CDM and I saw that Vertex 1 is a better drive.
    If you're willing to pay about $110-120 for SSD, RealSSD C300 64Gb is the best performer right now along with 40-50Gb SF-1200 based drives (F40, Vertex2, S599)
  19. #19
    Dec 2002
    Last I heard, there was next gen mainstream SSDs coming supposed to do ~500MB/s, obviously late/not here yet. Six months to two years away for all I know.
  20. #20
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    gaming loads/access is roughly 70 percent sequential.
  21. #21
    Oct 2009
    How important 4k random read and write performance is in linux? 16GB would be more than sufficient for linux media PC and to think of it, even thought 4k read/write is only ~10MB/s, it's still around 10x the speed of conventional HDD.
  22. #22
    Feb 2010
    stuffme, great question, this seems like the perfect fit for an xbmc-appliance type box. (with some nas in a different room)
    slowpoke:
    mm ascension
    gigabyte x58a-ud7
    980x@4.4ghz (29x152) 1.392 vcore 24/7
    corsair dominator gt 6gb 1824mhz 7-7-7-19
    2xEVGA GTX TITAN
    os: Crucial C300 256GB 3R0 on Intel ICH10R
    storage: samsung 2tb f3
    cooling:
    loop1: mcp350>pa120.4>ek supreme hf
    loop2: mcp355>2xpa120.3>>ek nb/sb
    22x scythe s-flex "F"
  23. #23
    Oct 2009
    I have this drive now for testing and I will post the results soon. Could someone instructs me how to test the drive properly with iometer, so I don't post useless results?
    This I can say already, the drive is very slow on writes, but reads it's quite fast for its price.
  24. #24
    NREMT-I
    Jul 2005
    near Atlanta Georgia (and hate it)
    I have this drive....... STUTTERS like CRAZY. It was a XP64 boot drive, but couldn't stand the lag it had, so now Im using it as a game drive only for FarCry2.... Sucks for that too....
    Nothing anymore
Tags for this Thread
