Results 1 to 25 of 2964
Thread: ***Official***Z68X/P67A-UD7 Club/Discussion/Info**
Threaded View
    I am Xtreme
    Dec 2004
    France
    Official P67A/Z68X-UD7 Owner's Club + Discussion
    From The MOST in Depth Preview/Review P67A-UD7
    Some highlights include the VRM/PMW design (power delivery), and I go very in depth about the advantages and disadvantages of Analogue VS Digital VRM design. BIOS section including brand new BIOS settings including wattage and amperage to the implementation of EFI BIOS in the future. The USB 3.0 sub-system on this board is phenomenal tree type system along with SATA6G connectivity this board can power all of your devices to their fullest extent, and when you have all the SATA and USB ports filled you can enable USB 3.0 Turbo Mode to add speed and bandwidth. I take apart of the cooling on this board and put it to the test to find out how well it transfers and dissipates heat in the motherboard cooling section. I then take a look at both PCI-E busses in the NF200 and PCH P67 section, and analyze the benefits.
    Motherboard With Cooling:
    Motherboard Without Cooling:
    BIOS(BETAs are three letters/numbers, final versions are in FX format):
    Beta BIOS F5g
    Beta BIOS f5h
    BIOS F3 Originial BIOS
    BIOS F4
    BIOS F5M
    BIOS F5N
    BIOS F5
    BIOS F6A
    BIOS F6X CPU PLL OVERVOLTAGE
    BIOS F6C
    BIOS F6E
    BIOS F6
    BIOS F7A CPU PLL OVERVOLTAGE
    BIOS F7B
    BIOS F7
    Features:
    24 phase power for over 1300 watts output
    32MBit BIOS for future EFI BIOS
    NF200 directly to CPU PCI-E lanes for SLI
    Separate PCI-E bus for peripherals so no bottleneck SLI
    Sleek Black NO Brown through Matte PCB
    Extensive USB3.0 system with USB 3.0 Turbo(bypass DMI by CPU PCI-E lanes)
