I want to show secoond batch of PC case with integrated Phase Change cooling and Water Cooling place called LD PC-V10.
Case is made of Aluminium. Dimensions are W x H x D 650 x 690 x 220
On the top of the case is space for 4 X 120mm (480mm) radiator.
There are 4 slots for 5.25 use and 5 HDD's.
Front design is little different. Perforation is made for 2 x 140mm fans.
PSU cooling is improved.
4 x 120mm radiators on the top.
Kind Regards
