Results 1 to 14 of 14
Thread: Xtreme Broken!!!! i7 IHS Removal, Have You Done It?
    May 2007
    Hampshire, UK
    Decided to pop the IHS on my 950 & fubared it....
    I have popped the IHS on loads of chips & never broke a chip yet but once I cleaned up the core I noticed a hairline crack across the core. I popped it in the board without a heat sink & gave it some power monitoring the temp with a laser temp probe & as she hit 50oC it smoked so I never got to run it.
    My question is how many people have cracked i7 cores removing the IHS & if you were successful has your chip lasted after removing it?
    Attached Images Attached Images
    Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
    Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
    Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    May 2007
    Hampshire, UK
    Seen & read that thread before doing it, I think there's one i7 in there that's IHS has been removed & is alive.
    I've removed heaps of soldered IHS's & never had a problem with a broken/cracked core so I just want to know if it was just bad luck or common for the i7 hence the question.
    BTW If i can find enough people to chip into this thread & my dead chip is put down to bad luck I'll try again on another chip.
    Feb 2008
    Canaduh
    http://www.xtremesystems.org/forums/...ht=naked+w3520
    it runned for a few times, but i think i scrap the die when mounting it last time i tried running it it didn't work, i still have it somewhere
    ihs have not ben removed but sanded down, cpu was popping bsod left and right before i did it anyway
    Intel i7 980x / 3001B331
    HK3.0+LaingDDCPRO+XSPCRX360+1xMCR220
    EVGA Classified X58+EK FB
    6GB Corsair Dominator GT 1866 7-8-7-20(TR3X6G1866C7GT)
    ASUS GTX580
    Enermax Revolution+85 950w
    Corsair Obsidian
    Sep 2007
    CA Bay Area
    Anyone have any info on Lynnfields in this respect?
    May 2007
    Hampshire, UK
    @ mk-ultra
    Thanks for the input, its interesting one guy "Aerou" believes the IHS thinned down is more efficient than totally removed for running on air.
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    The bad part about the whole thing, apart from losing warranty, is that you can't use the cpu hold-down retention anymore. If you have the need to do it, I would suggest to lap an IHS to make it more even and have a better contact, but only to the point where you can still use the original retention.
    And yes, a 1.5mm thick IHS gave me 1-2 degrees better temps than being IHS-less.
    Having done the whole thing (btw that cpu died recently, probably because of a bad mount - this wouldn't happen to a unmodded CPU !!! ), I advise against it. Save your cpu, money, warranty, time and pain.
    The TIM between the die and IHS is very good, it allows the heat to buffer into the IHS. Apart from that, it treats the problem of hot-spots in a cpu and allows the cooler to have a larger area of contact for heat transfer ( better utilization of heat-pipes).
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Dec 2006
    germany
    well mine is removed and it's still running very nice since months with my SS
    2600k @ Asus M4E - Little Devil Case
    Intel I7 965xe @ Evga E762 - Little Devil SS Case
    2x Intel I7 E5620 @ Evga SR-2 - MountainMods ext Ascension watercooled
    Intel I7 930 @ Evga E759 - LianLi V2000 air cooled
    May 2007
    Hampshire, UK
    Quote Originally Posted by Aerou View Post
    The TIM between the die and IHS is very good, it allows the heat to buffer into the IHS. Apart from that, it treats the problem of hot-spots in a cpu and allows the cooler to have a larger area of contact for heat transfer (better utilization of heat-pipes).
    Good point thanks for your input.
    Quote Originally Posted by sargatanas View Post
    http://alexiel.stor.li/intel.jpg
    Great, this was my plan for the 950 first I was going to compare air temps to see what removing the IHS got me then it was going cold...
    Did you make any temp comparisons with & without IHS?
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by C-N View Post
    The temps will be worse unless you use direct die water cooling.
    Donate to XS forums
    Dec 2006
    germany
    didn't compare it because I bought it like this.
    compared to other w3520 it's worser with watercooling but better with phase.
    Feb 2008
    Canaduh
    Quote Originally Posted by zalbard View Post
    that made me think
    the aftermarket waterblocks are designed for the big heatsink, not this "little" die, IMO you'd need a custom block to focus the cooling on the die only to have effective cooling
    ASUS GTX580
    Corsair Obsidian
    May 2007
    Hampshire, UK
    Quote Originally Posted by mk-ultra View Post
    Like this guy
    http://www.xtremesystems.org/forums/...d.php?t=222040
    Oct 2010
    香港 , Hong Kong
    Carzy
