XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 03-23-2009, 08:34 AM   #1
corross
HOW TO REMOVE i7 IHS
Hi guys. Today, my 4th i7 920 arrived. So here’s the guide how to get the pants off this baby.
First this is what you need besides the CPU:
1.razorblades
2.adhesive tape
3.permanent marker
4.Lighter / gas soldering iron or anything like this
5.something to clean the HS after burning (acetone + hankies)
If you have everythig collected, the show can begin.
Step 1 – prepare 6 razorblades for use
-->use some of the tape to protect your fingers
-->mark one of the prepared blades with the waterproof pen as shown in the picture. The cutting depth is max. 4mm for the i7! If you cut deeper, you may damage some of the small ceramic caps.
Step 2 – Cutting
-->Take your marked razorblade and cut from the corners to the middle (each side two cuts from the right corner to the middle, then from the left corner to the middle = 8 cuts around the CPU)
-->now cut the rest like this (each side one cut = 4 cuts, all in all 12 cuts)
Step 3 – get ready to burn
-->We’ll make a little fire under the IHS, but nobody wants to roast the PCB. So do the following:
-->the melting pot (if you heat up the IHS, the solder melts and gravity will do the rest)
Step 4 – Melting the solder
I’ve done this with a simple gas lighter. Sometimes you need to shake a little bit as you can see in the video.
Videos say more than thousand pictures:
http://www.youtube.com/watch?v=YWTgS2ZuiJQ
After this, clean the Heatspreader using acetone
So heres the result, tested & works:
This is a photo of another i7, wich is currently running in my rig:
Carefully remove the tin with your razorblade.
Have fun with your naked i7 !
How the story continues: The custom-waterblock.
Copper 40x15x1000 vs. HS
What was your i7 Batch?
The copper met a milling machine, result: 29x38x12 + two holes
threaded (G1/4 inch thread)
I think you can imagine the leftover.
Performance:
- The water runs directly across the core now. CPUTemps are max. 30°C @ 4GHz full load, wich allows a nice 24/7 OC @ 4,4GHz; 1,39VCore (selected CPU, limited by the max. stable BCLK of my DFI LP UT mobo with HT&TurboMode on)
Regards from Germany,
Frank
corross is offline   Reply With Quote
Old 03-23-2009, 09:02 AM   #2
ghost_recon88
ghost_recon88's Avatar
30°C under full load with water? and that's with HT on? That's insane
__________________
pauld5999 - "0-60 in my civic feels like an AMD pi run"
Intel E5200 @ 3.4GHz | GA-G41M-ES2L | 2GB DDR2-667
Heatware
ghost_recon88 is offline   Reply With Quote
Old 03-23-2009, 09:06 AM   #3
corross
Thats XS
I'll post some screenys of the rig when ready. Next stop: testing 8SSDs@Areca 1261ML on it.
Old 03-23-2009, 09:09 AM   #4
Trigger5521
Trigger5521's Avatar
Clearly not for the faint of heart!!.
__________________
ASUS Striker II Extreme 790i Bios 1202 PICS
Q9650@4.10 (FSB 455hz X4) Linked & synced.
Patriot Viper PC2000Mhz DDR3 4x2GB 8-8-8-22-1822
BFG 8800GT OC2 X2 SLI
OS RAID 10 250GB X4 ES 7200 32MB Enterprise
Games RAID 0 500GB X2 ES 7200 32MB Enterprise
Silverstone TJ10 ESA
Swiftech MCR220 & MCR120 rads
D-TEK Fusion v2
Black Freezer NB/SB
EK's Acetal on Mosfets
1/2 R3603 Tygon Tubing
OCZ 850Watt GameXtreme
SoundBlaster X-FI TITANIUM - PCIE
Klipsch ProMedia Ultra 5.1
Dell 3008WFP 30' @ 2560x1600
Vista X64 Ultimate
Trigger5521 is offline   Reply With Quote
Old 03-23-2009, 09:10 AM   #5
Conquistador SW
Conquistador SW's Avatar
Really nice . How did you manage to seal the waterblock watertight to the core?
__________________
Crunching for WCG
Q9450 3.6Ghz 1.28v / Rampage Formula / 4Gb OCZ DDR2-900 / XFX GTX260 XXX / Antec NeoHE 550 / 2x 250Gb Raid 0 / Intel G2 160Gb
Cooled by PA120.3, Apogee GTZ, DDC3.1 XSPC res/top
E6600 3.0Ghz 1.35v / P5B Deluxe / 2Gb DDR2-800 / 8400GS
Conquistador SW is offline   Reply With Quote
Old 03-23-2009, 09:13 AM   #6
ghost_recon88
What are your idle temps? And that's with chilled water I'm assuming.
__________________
Heatware
Old 03-23-2009, 09:22 AM   #7
corross
I soldered the IHS onto my waterblock. After this glued it on the CPU (two-component epoxy resin)
Yep, I'm using a "chiller". It cools the water down to 20°C. Idle Temp is 21°C.
Old 03-23-2009, 09:34 AM   #8
Conquistador SW
Ok, thanks. I like how on the top of this forum there is a big warning not to pop the IHS and what do I see some threads lower……
__________________
Crunching for WCG
Old 03-23-2009, 09:50 AM   #9
[XC] Hicks121
Xtreme Cruncher
[XC] Hicks121's Avatar
Send a message via MSN to [XC] Hicks121
Let's see some more pics of the whole set-up.
__________________
X3330 @ 3.78 on UD3P, X3210 @ 3.6 on Maximus Formula, E8400 @ 4.2 on P5B-D, E6300 @ 3.64 on P5B-D
Originally Posted by mike047 View Post
CRUNCH HARD, it may not help me and you, but it might help the Kids.
[XC] Hicks121 is offline   Reply With Quote
Old 03-23-2009, 10:22 AM   #10
corross
http://www.xtremesystems.org/forums/...d.php?t=209279
Yes, this is a great sample of craftsmenship. Looks like boble used a wrecking bar...
No problem, but I have to complete the rig first, like I mentioned before. The SSDs are on the way. Moreover, I'm building water blocks for the DFI, because the Mosfets get quite hot.
Old 03-23-2009, 10:31 AM   #11
ewitte
Made me lol too
Sticky: Intel Core i7 - DO NOT REMOVE IHS! ( 1 2 3 4 5)
ewitte is offline   Reply With Quote
Old 03-23-2009, 11:56 AM   #12
ownage
Damn, direct-die watercooling. You have balls lol!
__________________
>Q6600 3.7ghz 1.56v (max 58c full load)
>MSI P35 Neo2-FR
>HD4890
>Cosmos 1000
>CM Silent Pro M700
>SSD, Intel X25M G2
>H2O---MCP655 - XSPC360 - Apogee GT - HWlabs 240 stealth - Fuzion GFX - MCRES.
ownage is offline   Reply With Quote
Old 03-23-2009, 12:42 PM   #13
Clint
Go ahead punk...
Clint's Avatar
The core aint that fragile that people tend to believe. I even lapped the core of my C2D E6600, and not a little either.
__________________
MSI X58M @222BCLK
920 3942A @4.22GHz (1.32v)
Sapphire HD 5850 @1GHz/1.3GHz (1.2v)
Mushkin Blackline 12GB PC3-12800 @1.33GHz 6-6-6-16 (1.64v)
Clint is offline   Reply With Quote
Old 03-23-2009, 12:54 PM   #14
Bobsama
Xtreme Cruncher
Bobsama's Avatar
Wow--did you happen to have pre-removal tests for comparison? Because 30C... that's SWEET!!!
__________________
Pray for BLUE!!!
Up:
E6300 Wolfdale @ 4000mhz == 6GB DDR2 800 == HD3850 256MB == Windows 7 Pro 64
P4 531 == 2.5GB DDR2 400 == X300 128MB PCIe == Vista HB 32
Down:
A64 3500+ == 2GB DDR2 800 == HD3200 IGP == XP Pro 32
Bobsama is offline   Reply With Quote
Old 03-23-2009, 02:59 PM   #15
corross
Before this mod, the CPU temp was around 45°C with the chiller @ 20°C. So it dropped 15°C.
Old 03-23-2009, 03:03 PM   #16
HuffPCair
Xtreme Cruncher
HuffPCair's Avatar
Send a message via Yahoo to HuffPCair Send a message via Skype™ to HuffPCair
FINALLLY i have been wanting to see someone do this with an i7.
Awesome job!!!!
__________________
Cooler Master ATCS 840 (black)
Q66 w/ Corsair H50 on a eVGA 680i SLI
Ballistix DDR2 800
9800GTX+
Corsair 850HX
HDD= 500GB(OS) 1TB(Storage)
Razer Tarantula & Deathadder
Acer 19" & 23" LCD
HuffPCair is offline   Reply With Quote
Old 03-23-2009, 03:06 PM   #17
Fafeifa
Fafeifa's Avatar
I'm going to try this over the weekend
__________________
Fafeifa is offline   Reply With Quote
Old 03-23-2009, 03:30 PM   #18
QuadDamage
QuadDamage's Avatar
That's awesome dude. Popping a soldered IHS is quite a feat in itself but that direct-die water cooling is even better. Can't wait to see them pics of the whole setup!
Awesome.
QuadDamage is offline   Reply With Quote
Old 03-23-2009, 03:36 PM   #19
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
Very nice
__________________
loc.o is offline   Reply With Quote
Old 03-23-2009, 07:12 PM   #20
Mescalamba
Thats not eXtreme.. thats totaly insane. And that video .. wouldnt like to see what could happen if flame met CPU directly.. btw. how can CPU survive that much heat? (Yes I know, since it was soldered, it must been done with some heat too..).
Im tempted to try it too.. but its kinda expensive fun.
Mescalamba is offline   Reply With Quote
Old 03-23-2009, 08:20 PM   #21
liftedcj7on44s
liftedcj7on44s's Avatar
you have to remember intel puts these chips in an oven to start with. Cant remember the temp but its pretty hot. In that vid right as the IHS popped off it looked like the CPU exploded!
Awesome work. Might have to give this a shot. got any hi res shots of the Die BTW?
__________________
CPU- Intel Core i7 920
Motherboard-MSI X58 Eclipse SLI
RAM-6GB Crucial Ballistix DDR3-1600 7-7-7-24(6x1gb)
Video card-Quad SLI GTX295's
Hard drive-500gb hitachi;OCZ Core SSD 64gb
CPU cooler- Thermalright Ultra 120 Extreme
Power Supply-Silverstone DA1000
O.S.-Vista 64 bit/Windows 7 64 bit.
liftedcj7on44s is offline   Reply With Quote
Old 03-23-2009, 08:39 PM   #22
ChaosMinionX
Xtreme New Yorker
ChaosMinionX's Avatar
Send a message via ICQ to ChaosMinionX Send a message via AIM to ChaosMinionX Send a message via MSN to ChaosMinionX
Thats awesome
Can't wait to see the cooling setup
__________________
===Under Construction===
[HeatWare]
ChaosMinionX is offline   Reply With Quote
Old 03-23-2009, 09:13 PM   #23
Fafeifa
Fafeifa's Avatar
Can you run the core naked under a regular Heatsink on air or you need some shims?
__________________
Old 03-23-2009, 10:06 PM   #24
dejanh
I am Xtreme
dejanh's Avatar
Should be able to...
By the way, how did you clean the core from the solder?
dejanh is online now   Reply With Quote
Old 03-23-2009, 10:21 PM   #25
Fafeifa
Fafeifa's Avatar
I haven't done it yet, now evaluating the risks before getting my hands dirty.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
