Results 1 to 11 of 11
Thread: New Llano Die Photo (Not very clear, but clear enough)
    Sep 2009
    Sep 2007
    Jakarta, Indonesia
    Okay folks, get your gear ready & count those stream processor amount !
    Mar 2005
    Rotterdam
    nice work - looks like nearly half the die size gone for gpu. please someone qualified compare the size to the rumored 480 shaders and dont forget to factor in 32nm =)
    here is a 40nm redwood 5670 die shot to get one started:
    now the architecture for redwood:
    Gigabyte Z77X-UD5H
    G-Skill Ripjaws X 16Gb - 2133Mhz
    Thermalright Ultra-120 eXtreme
    i7 2600k @ 4.4Ghz
    Sapphire 7970 OC 1.2Ghz
    Mushkin Chronos Deluxe 128Gb
    Banned Movieman...
    May 2009
    illinois
    i think i counted 24 boxes of the same size in the GPU area.
    anyone want to confirm?
    Jun 2007
    above USA...below USSR
    Quote Originally Posted by stangracin3 View Post
    yea, looks like 24.
    Case-Coolermaster Cosmos S
    MoBo- ASUS Crosshair IV
    Graphics Card-XFX R9 280X [out for RMA] using HD5870
    Hard Drive-Kingston 240Gig V300 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
    CPU-AMD FX-8320 5Ghz
    RAM 8Gig Corshair c8
    Logitech 5.1 Z5500 BOOST22
    300Gb of MUSICA!!
    Steam ID: alphamonkeywoman
    http://www.techpowerup.com/gpuz/933ab/
    Oct 2007
    Hong Kong
    K10 core: 9.69mm^2
    Whole chip will be >220mm^2?
    Feb 2009
    Lima, Peru
    For the ay they are arranged there's the possibility of a dual ultra-threaded dispatch processor like barts.
    Athlon II X4 620 2.6Ghz @1.1125v | Foxconn A7DA-S (790GX) | 2x2GB OCZ Platinum DDR2 1066
    | Gigabyte HD4770 | Seagate 7200.12 3x1TB | Samsung F4 HD204UI 2x2TB | LG H10N | OCZ StealthXStream 500w| Coolermaster Hyper 212+ | Compaq MV740 17"
    Stock HSF: 18°C idle / 37°C load (15°C ambient)
    Hyper 212+: 16°C idle / 29°C load (15°C ambient)
    Why AMD Radeon rumors/leaks "are not always accurate"
    Reality check
    Dec 2007
    Hungary (EU)
    ...an earlier slide:
    Attached Images Attached Images
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    for some days we will have here AMD Financial day 2010, think, we will smarter
    ROG Power PCs - Intel and AMD
    Xtreme Mentor
    Jul 2008
    Shimla , India
    Two things that are very important to remember is the enhancements mae and its nemeses "Sandy Bridge". As i have said several times before sandy bridge is much stronger in the cpu department but not as strong as the llano in the GPU department. Now there is a thing i left out the ratios, i mean ya the llano's GPU is stronger but by how much or the CPU part of SNB is faster but by how much?
    This was a part of discussion "Because we have no job's assigned thank you Intel" and the outcome was that a Intel GPU can reach the top not with huge number of shaders but with improved efficiency and speed. Intel does not want people to waste die space on stupid GPU's there were number of meetings held to decide if the current standard of GPU products were good enough to drive basic operations till Windows XP everything was a-ok but then Vista changed a lot of things it was concluded that for a entry level computer to run OS like Vista with bling they needed more GPU power at first they wanted to include a chip on the mobo itself but it worked out to suck a lot of juice and so it was decided to go on chip "Went down easy with most people" and then on die "Veery hard to digest people did not like that die space was being used for a dam GPU but had to be done"
    Coming Soon
    I am Xtreme
    Dec 2007
    Quote Originally Posted by ajaidev View Post
    i think were coming to a point where cpu speed is fast enough, and its a transition to the gpu for anything that "really needed" a faster cpu. no point in waiting for scaling of the cpu, when if you code for scaling the gpu is more than ready (pending the code can be run on a gpu)
    so if we compare a slew of benchmarks between the 2 chips (of a same tdp and price if possible, like what 35W and 250$ gets you) then i think the perf difference will sway ALOT depending on the benchmark, and its really a matter of which ones the user needs it for.
    then im curious if in 3 years or so when its time to upgrade that same laptop, which one feels slower then, the one with a stronger cpu, or stronger gpu? i think that part is really most important considering people are keeping their computers longer than ever, which one will have the longer life.
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
