Here's a product that might interest some of you: http://www.koolance.com/water-coolin...roduct_id=1086
It's a dual 5.25" bay reservoir that allows one or two Laing D-5 pumps (two sets of inlet/outlets in back). Pumps are not included, of course. Here's some of the product description:
Machined from a solid piece of acetal for maximum reliability, the RP-450X2 has a thick acrylic window and front aluminum bezel. Two sets of G 1/4 BSP threaded inlet and outlets appear on the back, designated "P1" and "P2" for each pump. If one pump is used, an acetal blocker is included to occupy the second pump location.
There are four pre-drilled holes for optional 3mm LEDs around the acrylic window. CD bay mounting screws are included. Capacity = approx. 10 fl oz (300ml). Weight without pumps = 2.5 lbs (1.1kg). Total dimensions = 5.8" (14.8cm) W x 5.4" (13.6cm) L x 3.3" (8.5cm) H.
Tim
