Results 1 to 21 of 21
Thread: Project HELIOS - Invocation Begins 10.01.10
    Dec 2004
    HELIOS, the Titan god of the sun. Tireless is he who is like the deathless gods.
    As he rides his chariot, he shines upon men, and piercingly he gazes with his eyes from his golden helmet.
    Bright rays beam dazzlingly from him, and his bright locks streaming from the temples of his head gracefully enclose his far-seen face.
    A rich, fine-spun garment glows upon his body and flutters in the wind: and stallions carry him.
    Then, when he has stayed his golden-yoked chariot and horses, he rests there upon the highest point of heaven, until he marvellously drives them down again through heaven down to the lasting earth.
    Design Features:
    - Crafted from the worlds highest grades of composite materials and carbon fiber.
    - Showcasing some of the finest watercooling components and computer hardware.
    - Designed to hide every fastener, nut and bolt.
    - A lack of case windows leave the motherboard bare and exposed.
    - High-tech and specially engineered ceramic foam filters and stainless steel mesh keep out dust.
    - Made from virtually indestructible panels over 8MM thick.
    - Taking advantage of air pressure zones to keep hardware dust-free.
    - Fully removable motherboard tray without disconnect or power-down.
    - Highly modular design makes part-swapping as simple as possible.
    - Sleek minimalist design is a call back to swiss modernism and bauhaus principals.
    - Design and fabrication methods tailored to an extreme rapid fabrication cycle.
    - HELIOS is to be a scratch build mod, truly, like no other.
    Hardware List:
    Computing:
    Processor - 1x unknown
    Graphics - 3x nVidia GeForce GTX 480
    Motherboard - 1x unknown
    Memory - 12GB unknown
    Power - Corsair AX1200
    Storage - 8x 120GB SSD
    Display - 3x Asus VW266H 25.5"
    Cooling:
    Processor - 1x AquaComputer Cuplex Kryos XT
    Graphics - 3x unknown
    Radiators - 2x HW Labs GTX480 (3x140mm)
    Tubing - 20' Tygon AS600038
    Fans - 13x NB-BlackSilentPro PK-3
    Pumps - 4x Laing DDC-1plus
    Pump Tops - EK-DDC Dual Top V2
    Memory - Mips RAM Kόhler6
    Fittings 1 - 10x 3/8" Straight Rotary Fitting
    Fittings 2 - 20x 3/8" 45 Degree Rotary Fitting
    Fittings 3 - 20x 3/8" Angle Rotary Fitting
    Fittings 4 - 10x Low-Profile Stop Fitting
    Fittings 5 - 16x Fitting Spacer
    Fittings 6 - 16x Mini Fitting Spacer
    Fittings 7 - 8x No-Spill Quick Disconnect Female
    Fittings 8 - 8x No-Spill Quick Disconnect Male
    Fittings 9 - 4x 2-Slot Crystal Sli-Link Tube
    Fittings 10 - 3x Mini Sli-Adapter
    Fasteners and Hardware:
    Polyethylene Spacer - 40x 3/16”OD x .115”ID x 3/8” (McMaster - 92825A009)
    SS Dowel Pin - 50x 3mm x 6mm (McMaster - 91585A051)
    SS Press-Fit Threaded Insert - 5x 1/4-20 x 1/2” (McMaster - 92394A116)
    SS Press-Fit Bushing - 4x .257”ID x 1/2”OD x 1/4” (McMaster - 8492A155)
    SS Knurled Thumb Screw - 4x 1/4-20 x 3/4” x 1” (McMaster - 91830A577)
    Wool/Rayon Adhesive Back Felt - 1x 24” x 32” x 3/64” (McMaster - 8770K3)
    SS Low Head Socket Cap Screw - 75x M4 x 30mm (McMaster - 92855A425)
    SS Knurled Thumb Screw - 24x 6-32 x 1/2” x 1/4” (McMaster - 91746A536)
    SS Low Head Socket Cap Screw - 25x 6-32 x 3/4” (McMaster - 93615A210)
    SS Self-Lock Flat Head Cap Screw 25x 10-32 x 1” (McMaster - 92805A268)
    SS Male-Female Standoff - 18x 6-32 x 3/16”OD x 3/16” (McMaster - 91075A461)
    Hinge / Lid Support - 2x 1.744” x 5.313” (McMaster - 14785A51)
    Materials:
    - 8MM thick CNC cut carbon composite panels crafted to the strictest military specifications
    - 2MM thick thermoset carbon composite panels made for aerospace applications
    - Stainless Steel hardware throughout
    - Stainless Steel micro-weave mesh
    - Felt dampening
    - Polyethylene to reduce friction in modular areas.
    - Custom engineered ceramic foam air filters
    Specifications:
    Size - 206mm Wide - 610mm Tall - 610mm Deep
    Weight - unknown
    Performance Statistics - unknown
    Design, Prototypes, Mockups and Fabrication log to follow.
    Dec 2004
    Dec 2004
    *reserved for final/current image*
    Dec 2004
    INITIAL CONCEPT ILLUSTRATION:
    Using Adobe's Illustrator I created a couple rough perspective drawings, so that I could get a better idea of the concept in my head:
    -At this point the plan was to construct the case in Aluminum.
    REVISION 1.0:
    REVISION 2.0:
    After talking with the community and doing some more planning myself, I made some changes to the plan.
    -Altered some of the chassis dimensions.
    -Trashed the idea of stacked radiators.
    -Relocated the pumps and reservoirs.
    -Added a downward facing PSU fan, which would later be scrapped.
    -Finalized the tubing layouts.
    -Changed from 360MM radiators to 420mm
    -Changed the fabrication material to Grade 38 Titanium
    REVISION 3.0:
    I again posted my designs for the community to critique and made some very minor alterations yet again.
    REVISION 4.0:
    At this point I was getting some really good feedback online and started putting it into practice.
    -I redrew the entire design with new dimensions.
    -Plotted the wiring paths.
    -Refined the tubing layouts.
    -Finalized the pump and reservoir positions
    PAPER PROTOTYPE:
    It was now that I decided to take my design and bring it into the physical plane. The medium I decided upon was cardboard and tape - the board I used is the same stuff one would use to matte pictures when framing.
    REVISION 5.0, current and FINAL revision:
    Happy with the prototype and the general concept, I decided it was time to finalize the plan and fix the little issues. This revision I've kept to myself until this now. I've made many very small changes to the plan.
    -I again completely redrew the design, this time with 8MM thick paneling.
    -I added small routered grooves where the panels fit together to better hide the seams.
    -Altered the relationships of components and their positions.
    -Finalized the design for the PSU cavity.
    -Beveled all the edges of the cuts - to compensate for the diameter of the 1/8" cutting tool on the CNC router.
    -I also swapped out the Titanium for a Carbon Fiber construction instead (I'm going to save the Titanium I acquired for another project down the road).
    Dec 2004
    I've been working with an engineer, and friend of mine named John Dalton, who has graciously offered up some time to throw together a 3D mock-up.
    He sent me off the first revision of his model today.
    There are couple of minor errors, due to my vague explanations:
    -In this model the motherboard backplate is flipped 180deg
    -The SSD mounts are affixed to the side panels instead of the rads
    -the motherboard tray is just floating in space.
    They are such minor issues that I have no problem at all sharing some previews with you.
    And John already agreed to rectify the issues for me on Monday.
    Here's an ISO view with perspective.
    Side view with perspective:
    View of the back and side of the chassis.
    A couple of detail shots of the bottom.
    Note here how I managed to save some space by routering out some spots in the chassis and side-panel. These will allow for a couple extra millimeters for the pumps and PSU fan.
    You can CLICK HERE for a live model preview which you can rotate around and navigate in 3D space.
    Unfortunately this HTML export from SolidWorks is only supported by IE, and on PC.
    Xtreme Design
    Aug 2009
    Central Texas
    Reserved for praise and awe. =)
    Not From Concentrate
    All Projects
    Previous Projects:
    S3 Mini ITX Chassis
    The ArK
    Uriel
    Israfel
    Veritas
    Eldritch
    Dec 2004
    Lol, thanks a lot mate.
    That's all I have to share for today.
    I'll have the revised model as well as some renderings to show you all next week.
    As well, next week, I'll share some pictures of the manufacturing process behind the composite panels. Perhaps even some shots of them being CNC cut to spec.
    *j
    Aug 2010
    San Jose, California
    Great job Langer.
    I know I've said it before but I love your work.
    Judging from all the time, effort, and attention to details you have put into this project thus far I'm sure the end result will be absolutely astounding.
    This is going to be one of those threads I'll keep hitting the "F5" key on.
    Mar 2007
    Sydney, Australia
    Wow, the final product is going to be amazing. A lot of effort put in so far, keep it up
    May 2009
    Greece
    It looks amazing..
    Waiting for more...
    24/7 Rig: AMD Athlon II 450 - MSI 760GM E51- 8GB 1600MHz Gskill RipjawsX- Nvidia GTX260 - OCZ Vertex2 60GB - Seagate 640GB - Antec Quattro 1200W - Samsung T220
    Bench Rig: Intel Core i7 3770K - Asus Maximus IV Extreme - 4GB 2000MHz Corsair Dominator GT - 2x Nvidia GTX260 - Intel Postville 40GB - WD VelociRaptor 36GB - Antec Quattro 1200W
    Dec 2004
    @Huww - Thank you very much sir. I'll try hard not to disappoint.
    @.Logic - I have indeed pulled some hair getting it just right, thanks for the comments.
    @geobot24 - Thanks a lot mate.
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    Dude, are you an architect of some sort?!
    Team XS: xs4s.org
    Dec 2004
    lol, nope. Just obsessive.
    [edit]You're sort-of correct actually. I do a bit of 'information architecture' in my experience design work. hehe[/edit]
    Dec 2004
    I've been diligently plugging away.
    I decided to trade in the project log for a big bang at the end.
    Many issues arose when fabricating the 8mm thick panels - there was a great numbers of unsuccessful trials before arriving at the solution seen in the images below. A total of 64 layers were required to achieve the thickness and rigidity of my specifications.
    As planned:
    There are three small 1/8" pins sticking out 2.5mm from each mated edge. These more than hold it together, there are no visible fasteners. (I've not yet inserted the pins holding the side panels in place - this will be the last step.
    All that remains now is to give the panels a final surface finish.
    A final clean of the edges.
    Dilling of a few remaining holes for mounting things like the motherboard.
    Then a light hammering to seat all the pins into their final positions.
    That's all I have to say for now, I'll let the images do the rest.
    Presenting HELIOS:
    Side-View w/ Side Panel
    Side-View
    Opened Top
    Front
    Reverse Side and back of Motherboard
    Detail Shot
    Tune in soon for final pics, the fabrication story, technical specifics, hardware selection and some pretty badass motion graphics.
    *j
    Sep 2008
    Italy
    Interested I follow you
    Mar 2010
    What u make the case out of ? like some sort of wood (mdf)?..
    I like the color of it looks clean...
    Keep us posted with this very cool build .
    Jun 2010
    wait so is this open source info? or will these be built and sold?
  18. #18
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    sexayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy yyyyyyyyyyyyyyyy!!
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  19. #19
    Dec 2004
    @Tom1 - and I thank you for doing so.
    @Dark -I give you my thanks, and refer you to the thread sir.
    1. Crafted from the worlds highest grades of composite materials and carbon fiber...
    2. Made from virtually indestructible panels over 8MM thick...
    3. 8MM thick CNC cut carbon composite panels crafted to the strictest military specifications
    4. I also swapped out the Titanium for a Carbon Fiber construction instead
    5. 2MM thick thermoset carbon composite panels made for aerospace applications
    6. ...the manufacturing process behind the composite panels...
    @Sean - Thanks for the comment, the design holds a creative commons license you are free to derive and copy all you'd like as long as it's not for profit. I will be constructing 3 of these cases made from different materials, wood, metal and plastic - the one you see above is obviously the plastic one... and I can assure you that the costs of 8mm carbon panels far out weight the potential market share, so manufacturing is not an option. That said, I do have plans and a design in mind which will be seeing manufacturing at some point.
    @Johnny - Hahaha, thanks mate.
  20. #20
    Xtreme Guru
    Jun 2010
    If you dont mind me asking whats the total cost so far to get this build to where its at??
  21. #21
    Mar 2010
    Ops my bad.. I been following this a bit late into the project & skipped all that.
    ill have to read it from start..Thanks for reply. Much appreciated ..
