"The cooler makes use of aggressive-looking shroud design that is inspired from shark-fins. Underneath it is a dense aluminum fin array that sits right on top of the GPU. The GPU base has four 8 mm thick heat pipes that make direct contact with the GPU. Two of these heat pipes convey the heat to the main aluminum fin array, and two to a smaller aluminum fin array that is positioned right on top of the VRM area. A backplate decks up the reverse side of the PCB. Colorful will release this card to the Asian market in September."
Yeah, and that cooler is awful also...have a look
Has good power regulation though:
The cooler:
More:http://www.techpowerup.com/129947/Co...hics_Card.html
Traduction from original site(more pictures and concept also):http://translate.google.it/translate...n&hl=&ie=UTF-8
