Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 235
Thread: Project : L3p D3sk
    Apr 2010
    Holland
    Talking Project : L3p D3sk
    Hi there
    I'm quite new to this forum, but since they liked my build at some Dutch hardware sites, i wanted to post it here too.
    My other build came to an end and didn't know what to improve, but my old desk almost fell apart.
    Really want to thank Pascal for his pc-in-a-desk idea. After seeing it I couldn't even sleep that night
    I started sketching it with Google Sketchup
    After 9 hours of non-stop drawing it finally had some shape.
    Hardware to be used:
    (Most of it comes out of my old build)
    Intel Core i7 980X @ 4.5 Ghz
    Corsair Dominator GT 6GB DDR3-2000 CL7 (Elpida) @ 2000 7-7-7-20-1T
    ASUS Rampage III Extreme
    2 x ASUS GTX580
    ASUS Xense
    Sennheiser Xense
    Highpoint RocketRAID 3560 24x SATA-300 2 GB
    Bigfoot Networks™ Killer™ 2100 Gaming Network Card
    1x Intel 510 120GB
    3x Corsair F60 raid0
    6x Hitachi Deskstar 7K2000 2TB raid5
    2x Optiarc AD-7241S-0B
    2 x Coolermaster Silent Pro 700W
    Dell U2711 27″ IPS
    2x Dell 1703 FPt 17″ portrait
    Blocks
    1 x EK Supreme HF Nickel CPU Block
    2 x EK-FC580 GTX – Nickel
    2 x EK-FC580 GTX Backplate – Nickel plated
    1 x EK RAM Dominator Nickel
    1 x EK-FB RE3 – Nickel
    1 x EK-FB RE3 – TOP Acetal – Level 2
    2 x Bitspower HDD Acetal Liquid Cooling Block – Silver
    Pumps
    2 x Laing D5-MCP655
    2 x Bitspower D5/MCP655 Mod Pump Top V2
    2 x Bitspower Black Sparkle D5/MCP655 Mod Kit
    Reservoir
    1 x Aquacomputer Aquatube G1/4 brass
    Radiator
    1 x Aquacomputer evo 1080
    Fans
    6 x Nanoxia DX Series 120MM DX12 - 1200RPM @ 5V
    11 x Scythe Gentle Typhoon 120MM 1450RPM @ 12V
    Fittings etc
    24 x Bitspower Black Sparkle Multi-Link (SLI/CF) Adapter
    16 x Bitspower Black Sparkle G1/4 Rotary 90 Degree IG1/4 Adapter
    12 x Bitspower Black Sparkle G1/4 naar G1/4 (2x OD) Verbindingsstuk
    10 x Bitspower Black Sparkle G1/4 Stop Fitting
    8 x Bitspower Black Sparkle 13MM (1/2) Schroeffitting – G1/4
    6 x Bitspower Black Sparkle G1/4 Rotary 90 Degree ID 1/4 Adapter
    6 x Bitspower Black Sparkle G1/4 IG1/4 Extender
    4 x Bitspower Black Sparkle G1/4 Five Rotary Snake-Style Dual IG1/4 Adapter
    4 x Bitspower Black Sparkle G1/4 Rotary 45 Degree IG1/4 Adapter
    2 x Bitspower Black Sparkle G1/4 Triple Rotary Mini Snake-Style Dual IG1/4 Adapter
    1 x Bitspower Black Sparkle G1/4 Triple Rotary Snake-Style Dual IG1/4 Adapter
    1 x Bitspower Black Sparkle G1/4 Rotary IG1/4 Extender
    5 x Bitspower Crystal Link Tube For 5-Slots (SLI/CF)
    8 x Bitspower Silver Shining 2xG1/4″ Fillport
    2 x Bitspower Silver Shining G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini
    2 x Bitspower Matt Black 2xG1/4″ Fillport
    2 x Bitspower Matt Black 13MM (1/2)Schroeffitting – G1/4
    1 x Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17
    2 x Thermosensor G1/4 2x ID In-Line met Display (blue)
    2 x Colder 13MM (1/2) Snelkoppeling Set
    2 m Tygon R3400 1/2 ID Black
    2 m Tygon R3603 1/2 ID Clear
    3 L Feser One Cooling Fluid – UV Acid Green
    I'm also gonna use my old cooling again since it works superb.
    It's a 1080 radiator under my floor from my house, right in the corner where my pc is.
    My water temperature in wintertime is around 18 degrees, in the summer it's around 23 degrees.
    Here some Youtube movies:
    Underground radiator
    The Final Fill-up
    Silence of the L3p D3sk
    Click here for the post with the high resolution photo's from the almost finished desk.
    Sponsored by:
    Apr 2010
    Holland
    Here's my update from Tuesday.
    Started with an Aluminium plate of 1850x990x3
    Plates for the mainboard tray, hdd tray, pump/res tray and cable plate
    The bearer ring to hold my desk
    Been to an other company to make a logo
    And back to welding
    Plasmacutter to make some cable holes
    End of the first long day
    Sep 2006
    Ohhh nice work m8, briliant idea!
    Can you putt please all sketches and all measures for holes and other, I want to build something similar?
    Thx in advance!
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    oh this is gonna b sweet!, subb'd
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Apr 2010
    Holland
    Here my update of Wednesday
    Creating a logo (was just a try, worked out well)
    Made some holes for the lcd's for the in and outgoing water temperature, and for the logo
    Had to make some changes to let my knees fit
    Fitting the trays with sound isolation under it.
    I love packages !
    Thought the buttons would the same, gonna change for 2 big one's now.
    Sound isolating for under my trays.
    NooB MOD
    Jan 2006
    South Africa
    A PC in a desk? SWEET Sub'd
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Sep 2008
    Belguim
    sweet following
    proud to be from Belguim ^^
    Lightpainting and hardware are my life!
    Dec 2006
    The Netherlands
    Talking
    Hi L3p, If been following your threat on tweakers as well. But since ur here now as well im gonna watch your build here! since i read here everyday.
    I was planning to build a "computer desk" for a couple of months as well.
    Your project looks great, not even talking about the expenses your making
    I'm not sure yet how im gonna build my new desk, but i want to make something with integrated watercooling. Perhaps a RVS framework, with MDF and PlexiGlas. Since i can't weld aluminum myself it will be a very expensive project to do it that way.
    Hope you gonna post some more details and some tips and tricks of things to watch in such build. Keep it up, hope u had a nice holiday!
    Greetz,
    Sintenel
    Project Blackhole: XS Case forum
    Apr 2010
    Holland
    Been so busy this week with the d3sk i didnt have time to update here
    So here's the progress of 3 days
    My best friend "babs" welding
    Holes for the Bitspower fanguards
    Both sides will have 3x 120mm Scythe Gentle Typhoons 1450 rpm op 5V
    Underground will be 9x 120mm Scythe Gentle Typhoons 1450 rpm op 12V @ the 1080 radiator
    Thats me !
    "Rough" work is done
    A Bitspower Black Sparkle Ashtray
    So brought the d3sk back home
    Apr 2010
    Holland
    And the next update
    Gonna use the backplate of an old lianli. (Thanks brother in law !)
    Fitting, measuring and hanging
    The battlefield.
    Just playing around
    Apr 2010
    Holland
    The next day.
    New toy arrived
    Fitting and measuring, pff
    Forgot a hole
    So made it bigger
    Mess outside
    Made 2 extra 120mm fan holes in the cable-space, cause i decided my psu will come there too.
    And made the hole for the lianli backplate.
    Bitspower !
    And building everything back for the hole picture
    Apr 2010
    Holland
    Next day update
    Shopping time
    Measuring the last holes.
    And more measuring
    Muscle pain !
    Rear = ready
    And the front !
    Apr 2010
    Holland
    Friday night, a very long day ..
    Hiding cables, what a nasty job.
    Scythe fanguards, maybe temporary
    Need sata ?
    Topview
    Getting tired when i see this again
    Filled up !
    Youtube - Filling it up
    http://www.youtube.com/watch?v=lfRiu3UnKTA
    Apr 2010
    Holland
    And the update of yesterday
    Hiding Sata(n) !
    And lift of
    Testrun 1
    Temperatures are better then in my Corsair 800D
    Now first some rest behind my d3sk, before it goes to the powdercoater
    Have fun all !
    Aug 2008
    Holy moly that is very nice indeed. I wish I had your skills and tool at hand to craft something like that. Simply amazing.
    EVGA X58 Classified
    Intel Core i7 980X @ 4ghz
    EVGA 590 GTX x2 Quad SLI
    Corsair Dominator DDR3 12GB PC3-12800C8
    Western Digital 150 GB Velociraptor
    Corsair AX1200
    Asus Xonar Xense
    Custom Watercooling
    Lian Li Pc-P80 Armoursuit
    Apr 2010
    Vietnam
    What a sweet work station
    /btw: 6 HDD and 3 SSD?
    Rig: P5Q Pro | E7400 | V8 | 2x2GB Ballistix Tracer | XFX HD4770 | 2x Seagate 1TB | eXtreme Power 650W | RV01 | HP 2009F
    Plan to go: Epiphone SG400 | Fender T-Bucket 300CE
    May 2009
    That is just awesome...would it have made more sense to make the tale smaller, as it seems a bit empty overall.
  18. #18
    Apr 2006
    This is the best build I have ever seen of a totally custom job. Most custom jobs are silly but this is an immensely practical idea. The only part I found odd was where you put the radiator. I have always considered utilizing a mini-fridge as a way to get un-natural temperatures. I still think I might give that a try.
  19. #19
    Apr 2010
    just checking, but that desk is secured into 2.4s, right? I'd hate to see her pull herself outta the wall and take a few square meters of drywall with her.
    And a suggestion, but if you tint the glass/plastic top, you could make it so you only see the insides when the internal lighting is on(like magic ^_^). Might be an interesting addition.
    Excessive and overwhelming tactical response
  20. #20
    Xtreme Design
    Aug 2009
    Central Texas
    Awesome project--I have seen many wall mounted desk cases actually, but yours blows them all away. Very professionally done, and also very artistic.
    Quote Originally Posted by anachlores View Post
    This is a fantastic idea. If it were my rig I would put window tint (probably silver) on the inside of the acrylic, so when the system was turned on you could see the hint of a computer via the lights. If you used elwire to trace some of the important outlines and some LED strips around the perimetere of the interior edge you could get a killer effect.
    But this is your mod, and you have already shown that your creativity will make it look awesome in the end anyways. =)
    Not From Concentrate
    All Projects
    Previous Projects:
    S3 Mini ITX Chassis
    The ArK
    Uriel
    Israfel
    Veritas
    Eldritch
  21. #21
    Apr 2010
    Holland
    The desk holder is secured with 11x 8x70mm bolts so the desk will never come down
    About that glass ... indeed an interesting addition .
    But i cant start playing with light before it has been powdercoated in black, the alu reflexes all the light now
  22. #22
    Apr 2010
    Holland
    No big updates this week, lots of mailing to do this week, maybe new sponsors, and had to sell all my old stuff
  23. #23
    Apr 2010
    Holland
    Found a nice connector for my Bulgin power and reset button to be disconnected easily.
  24. #24
    Apr 2010
    Holland
  25. #25
    Xtreme Enthusiast miptzi's Avatar
    Feb 2008
    Not sure if...
    This gives me the Idea of makina a smaller table with thick plexi/ALU cornerings
    Something like 90cm wide, 40cm depth and 18cm height....
    Just for the 24" monitor and I'm done.
    Would be much lighter, easy to move, and with removable feet, could even take it to the LAN's.... ( dreammode ON)
    Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
