Hello,
The Project
After the lian li 343 I wanted it different , to be honest I'm kind of bored with closed and black computer...
The case will be DIMASTECH easy bench table with dual side radiator...
To keep it short the dimensions published on the web site are incorrect, bad news to fit my old PA 120.3 longer than the case![]()
After long time i figured out how to fit everything inside anyway
Here is the plan :
Render :
Hardware
MB - Rampage Extreme 3
CPU - I7 975x
RAM - 3x2gb G skill Trident
GC - Xfire 5870
HDD - Raid 0 SSD Vertex 60gb
PSU - Corsair HX1000
Watercooling
2 x PA120.3 (old)
2 laing DDC + EK dual top
Ek Block
I strat a log already, so here are the actual pictures
And Now the custom power cord
If you find that the cheap one from your PSU doesn't look good...
Here is what you need :
Quality power Wire
IEC and Shucko
Sleeve, Heatshrink and regular tools...
After you can sleeve as you know how and tadaaa
The PSU
So after Three time i finally got my PSU like i wanted it.
First time - > To Much red
Second -> Wire two long :facepalm:
After some crimping moment i finally renounce to go single, and here she is :
Third time
And of course the sleeving gear
The Case after 2 week of work :
